Everything posted by markc
Yorkshire water installed my water meter in the middle of the access, their justification was that it won’t get overgrown and tyres never go down the centre … fair point.
Anyone considered a compact tractor?
markc replied to Drellingore's topic in General Self Build & DIY Discussion
Compact tractor is a great “toy” but no substitute for a digger. As above, forks on a compact tractor are hard work and nothing like a forklift, but easier than carrying stuff around by hand. Hire what you need and keep the toys for after your build. -
Never had a self build mortgage but I can’t imagine them simply putting money into your account - I would have thought it would be stage payments after stages were completed as a mortgage is secured on the property. im sure others will be along to confirm or otherwise.
Help, Chimney 'knee' construction
markc replied to Post and beam's topic in Roofing, Tiling & Slating
As above, the chippie bit of this is simple stuff, getting the lead/flashings right is the important part. -
Who can dig the trench for my new electrical supply?
markc replied to Bancroft's topic in Electrics - Other
I don’t know of any accreditation for trench digging, at the end of the day can you trust them? I would say do it yourself so you know it’s being done with care and respect for your neighbours etc. there are many construction jobs that should be left to the traddies but trench digging (assuming it’s not in the road or around other services) is a great DIY task -
Great description - I know exactly what you mean
That’s quite a bit of water getting in, and looking at the location I reckon it has to be a flashing or missing pointing on the stack. Had it been part way down the wall then yes it would likely be water from inside the stack getting out but this is too localised. Has to be water on outside of stack or close by that is collecting above ceiling. Have you been in the loft? Wet insulation? Cold water tank in loft space leaking or collecting condensation close to stack?
Is the stack in use? Open pot or a cowl?
Put the details you know, you can’t sign as the installer but you could scribble not known etc. that would look like a signature.
Yes it dries very quickly and you can re coat as soon as the colour changes, you could do one thick coat but then you just get heavy runs and sagging.
Naarrr, that’s easy … they are all helical retaining units
As an apprentice sparky in a steelworks we were told a Bulb if it has a simple filament, Lamp if it is an assembly or has an igniter built into the “Bulb”.
Best filler for floor joist holes
markc replied to DKenn's topic in General Self Build & DIY Discussion
If the holes are in the centre then the loss of material does not affect the beam as this area is not in tension or compression. If you do want to fill them use wood down or whittled to size and glue in with wood glue -
Is the dimmer suitable for LED’s ? Assuming yes then you are looking at a faulty fitting (if just replacing the lamps but keeping the same fitting), heat or humidity are also factors for premature failure especially with dimmed lighting.
Good morning and welcome, getting reliable people is difficult in UK, rural France must be a nightmare. the learning curve is all part of the fun and process of building
New connection - where to find existing network?
markc replied to worldwidewebs's topic in Electrics - Other
Any maps or plans are often useless for anything but roughly finding services especially out in open ground. In a street / residential area it’s pretty easy but out in the sticks you need to be looking for supplies on poles or asking any locals. -
Bungalow knock down and rebuild in Worcestershire
markc replied to mads's topic in Introduce Yourself
Good morning and welcome, knock down and rebuild seems like a big drastic decision but you will thank yourself later on. -
Seals can be replaced and doors (hinges and locking plates) can be adjusted. If the door is still sound I would get a local window place in for a couple of hours to sort it out, plus re seal around frame.
I can’t see a couple of fence misdemeanours being any problem, building a house too high, wrong place, wrong aesthetics etc. then yes, but a few years down the line, is anyone likely to complain about a fence?
How to fill small gaps in Herringbone flooring
markc replied to _Alex_'s topic in Wood & Laminate Flooring
Don’t worry about it. The floor is going to move over time and small “gaps” will never be noticed by anyone else plus they soon fill with dust etc and are forgotten. -
Unbelievable brickwork , will this pass building control!
markc replied to Jamo73's topic in Bricklaying, Blockwork & Mortar
A breeding pair of brikkies … ok, I’m mentally scared now -
I cannot build anything on my green belt area unless it is skid mounted and can be moved around. PD application on the curtilage and planners and wanting me to keep my workshop/garden room under 100sqm (I wanted 160sqm) to prevent future conversion into a dwelling. They are presently looking at possibly allowing me to build 2x 75sqm with a 1 metre gap between them.
