markc
    22
Everything posted by markc
  1. Fast cutting speeds in timber require large teeth gullets, but that means nails or screws can end up in the gullet and jam the cutter. the multi material hole saws tend to break the carbide teeth because most drills won’t spin fast enough to “mill” through nails etc. ive had some success using ordinary bi-metal hole saws (starrett out perform most) with 2 or 3 large teeth gullets cut with an angle grinder . These allow more swarf to be cleared and make cutting faster. Also works well for holesawing aluminium which clogs the small teeth.
  2. Now that’s a term I haven’t heard in many years. We always called the big Makita a rip snorter (used for cutting big glulam beams
  3. Hi @Doz, a lot depends on what is underground, well or borehole. Also what you are wanting the water for? And how often. converting your existing pump isn’t practical, motor, crank connecting to the arm etc. but a submersible or bore hole pump are pretty straight forward and could pup out through your existing fuxture with a bit of modification
  4. You only need a masons mitre if you have a pre formed chamfered or rolled edge. If doing solid top, mitre is great glued and bolted, then if you want a chamfer or rolled edge it can be done with a router after joining.
  5. Hi @slystallone, the wall shoulld have the soil side waterproofed with a perforated pipe running around the bottom “French drain” style and backfill with pea gravel, pebbles or similar to allow any water behind the wall to go down into the perforated pipe and then away around the side. idea is to take any water away to prevent the wall from being a Dam and being subjected to water pressure. It would be worth doing a bit of digging at the wall ends to check for any existing drainage that may have been blocked etc. failing that you are looking at water management which means a lot of digging or back to cutting holes in the wall and then collecting the water to take it away in visible pipes on your side,
  6. To do this right you really need to be excavating behind the wall and installing drainage to take the water away rather than through the wall. A pored wall of that size really should have had the drainage installed, any chance there has been other work at the ends possibly blocking the drains? Drilling holes will reduce pressure and water level but then you will be managing the water on the good side of the wall - with pipework
  7. Road planings work well, not the best looking but consolidate to a solid, tough surface allowing water to drain through.
  8. We find the dewalt corded stuff awkward - battery versions are bullet proof but the corded stuff is like it’s missing the battery to make it balance. track saw, I have an erbauwer one and it’s been great, not Festool smoothness or finesse but at 1/4 of the price it’s a good saw. If I was using it finish cutting cabinets etc. on a daily basis then I would have the festool, but for hobby stuff, trimming bottom of doors and breaking sheets down before table saw cutting I will stick with the erbauwer. corded drills, hand circular saws and grinders - I will only buy Makita. FYI, plunge track saw is a great machine, but heavy and cumbersome for a lot of jobs so a small light circular saw is great
  9. Really, the ones I picked up are 2.5mm, sorry @saveasteading I just opened the link but didn’t check details. You do need 2.5mm2 minimum on the cable at 25m long
  10. Yes, these are decent quality, couple of those so you are running parallel supplies, transformer on each and you are sorted.
  11. +1 keep 110v runs as short as possible. 2.5mm or even 4mm arctic cable for the 240v flexible extension to the transformer or even add another dedicated to the lights … saves going dark when they trip the transformer
  12. If you need to cut into the down pipe, holesaw for round holes, dremel type machine with a cutting disk for straight lines / squares etc
  13. I wouldn’t worry about that, no signs of settling away from first brick course, loads of bearing either side and brickwork above looks good. Lintel looks to be cast in situ so good chance it cracked while drying out.
  14. I reckon this is just wind blown water with you saying stormy weather.
  15. I’m guessing detergent .. looks too white for anything else
  16. Inchworms are the larvae of geometer moths … 2.54cm worms doesn’t have the same ring to it.
  17. You should use max. “Potential” voltage or open circuit voltage
  18. I use Tapo plugs and you can control by app but also turn on/off using the button, nice bit is that if you manually over-ride, the next schedule cycle reverts back to auto control.
  19. I would go simple heater (thermostat) and add any control for timer etc. far too much stuff now that requires an app to use it. i have just put two oil filled rads in my workshop but controlled with smart plugs for timing
  20. A guy I used to work with was ok in metric as long as they were whole numbers in 100mm increments - everything else was an imperial add-on. 3500mm - 3.5m 3600mm - 3.6m 3612mm - 3.6m and 1/2 inch it made setting out conversations interesting to others.
  21. Generally you don’t want any “pooling” points in ductwork, but if air is always moving then any condensation that does form should be quickly moved as it evaporates again.
  22. Really depends on whether you need the drain, if it’s all redundant, seal it up. You don’t need to excavate anything if the end is in your house and it’s not used, just pour some concrete in. If you cannot get to the end that’s in your place, dig as close as you can, find the pipe and break it, then backfill the hole.
  23. Keeping the post inside of the thermal envelope is the best option. A post inline with the outside looks great but presents you with a big thermal bridge.
  24. Do you mean the glazing bars or the capping strips that retain the glass? Glass on outside keeps windows cleaner and easier to clean. In the past when glass panes were smaller, glass would go in from outside and finished / sealed with putty.
  25. To keep cost down, Keep It Simple. If you want the brick facia, why not double skin blockwork and front / fascia using cladding although the design / render must be above 3m high so you will probably have to lose the step and thin down the roof / facia. definitely insulation under the slab and you might as well do walls while doing blockwork - or blown beads later on.
