Everything posted by markc
Can be overhead or even just above floor is fixed to a fence or wall. Only needs to be buried if likely to be damaged by pedestrian or vehicular traffic.
Guidance on how to word a legally binding document
markc replied to LovelyLoz's topic in Party Wall & Property Legal Issues
+1 -
Hello and welcome
Improving living conditions in my mum's damp and humid small bungalow
markc replied to minty's topic in Ventilation
Ventilation, ventilation, ventilation, stick a living, breathing, cooking person inside a box wrapped with plastic and you are going to get damp and mould. -
You could sister the joist one or both sides of the rafter, or double up as you say.
You do building work don't you? .. error, yes I do stuff. Could you have a look at my garden room, it's feeling damp and smells fusty. Apparently built and roofed around 10 years ago by a local builder - ledger board and dot and dab directly onto a retaining wall so ledger is rotten, PB is soaking wet and the concrete base goes right against the wall so nowhere for water to escape except under the flooring.
- 1 reply
- 2
You have rafters holding the roof tiles etc. the lower framework is there to fix the plaster board to. The vertical pieces could well be supporting the roof, is there a wall below that point?
Diamond core drilling through a slab is really easy, you don’t need the rig unless you are doing large diameter holes. 50mm dia. By hand is no problem downward. Core bits have come down a lot in price but the quality does vary. Hilti bits have always been good.
Definitely don’t need a pit and power requirements are generally under 10amp so a nearby socket is ideal. Never fitted one but I have taken two out and had to cut the mast because the hole had been trimmed at min opening size so there wasn’t enough wiggle room to get it back out on the angle. For a standing lift, trim at 800 (less 2x half joist width) and 1000 in length the give you space to get the mast in.
That’s H&S gone mad. The risk assessment should have highlighted that the risk of injury moving, erecting and dismantling that scaffold is far greater than the risk having a much simpler staging.
Good morning and welcome, many will say funding is the key, but finding the plot or (old place to knock down) can be very difficult. I have been looking for 5+ years. Hopefully you drop on a great site and can crack on with it.
Good morning and welcome, we all start somewhere. Loads of info on here covered by previous topics and questions. Good luck and have fun.
I have always worked on eaves height being the tip of the slates or tiles etc. making it the top edge of lowest part of the actual roof.
Rip everything out and start fresh, false economy to work around what you have. if you kept the existing it would get blamed for everything that wasn’t right later on.
+1 I reckon the tile line is not fully grouted or sealed behind the screen rail allowing water to go behind the tiles
When is a garage no longer a garage (for fire regs)?
markc replied to Sparrowhawk's topic in Building Regulations
If it’s not big enough for a car but you could get a couple of motor bikes in there then you still have a petrol fire potential. If it’s not practical to get a wheeled vehicle through the opening then it can’t (surely not) be classed as a garage. -
LV cables are often shrouded but at 11kv, plus the transformer etc. shrouding is not practical (if it was further away you could erect a crash fence but again not possible in this case). It comes down to - how will you protect your employees and how will you protect the pole, cables, transformer etc.
This is one of those what should you do? What would you do questions. Good few wraps of insulting (insulating) tape and you will be ok. As you are using a core for earth then yes tape or sleeve to identify.
Cracking between extension and original house
markc replied to Jemlou's topic in House Extensions & Conservatories
Are there any gaps appearing? Or cracks wider at the top or bottom? From photo it is difficult to be specific but my first impression is that mortar has been run down the joint and the crack is just mortar shrinkage. -
Anyone used Alloy Aluminium Splashback?
markc replied to KitchenPotcher's topic in Wall Tiles & Tiling
Scratches easily and then grease and discolouration are a real pain. -
Repair gap between external wall and concrete slab
markc replied to Oxbow16's topic in General Self Build & DIY Discussion
Trying to visualise this, a couple of pics would help. -
You really need a gap between wall and path. Sounds more like a drainage problem. Is this an old house? Outside ground above inside floor level?
