markc
    22
Everything posted by markc
  1. Good practice to noggin any end joints that do not drop on a joist, any middle ones are supported on both sides so don’t need anything
  2. Couple of recent break ins near us on industrial units .. battery nibbler and recipro saw straight through the cladding
  3. Hello and welcome, as above, look at permitted development first.
  4. Are you intending having pedestal basin or wall mounted/floating basin with concealed cistern etc. in a false wall?
  5. Assuming you won’t be running large vehicles over the patio, MOT straight over, compacted and you will be ok. Slabs over the top are likely to cause more damage as they settle.
  6. I would go 30mm thin wall, 1.5mm ish for stiffness. You won’t be having high compressive or tension loads so no need for thicker wall thicknesses.
  7. Is a wago and tape “text book” ? No! But it is insulated and protected from accidental touching of conductors so no different from a cable. Looping back against the cable and taping looks neater.
  8. Has to be a plumbing issue, tank overflow, pipe connection loose, pipe chewed by rodents?
  9. Cheers John, I asked vendor to leave the heating etc on and was then told the Honeywell controller is too complicated so they have been doing both heating and hot water manually. looking at the photo it’s amazing what can be missed, yes it looks like all the uninsulated pipework is in a cold space 🙈. give me foundations and structures anyday over faffing around with heating controls lol.
  10. Still haven’t found a suitable plot to build new so bought a small farm in the meantime 🤔. Nicely refurb bungalow so not going to do anything too drastic but changes need to be made so looking for suggestions. part electric UFH, not water unfortunately. Rest has rads. Boiler is oil fired. Hot water tank as photo. short term, need now :- need new controller for hot water and rads (oil boiler), need programmable immersion controller, To decide over next few month :- have loads of south facing roof space to add PV loads of outdoor space for ASHP etc. Would love some ideas and suggestions from you guys as heating and controls etc. is not my forte.
  11. The Mammotion Luba (few variants, 2WD, 4WD and area covered) are excellent, I don’t have one but trying to justify getting one!
  12. Good morning and welcome, I would be raising it slightly above the lawn, stops turf migrating onto the patio area and helps drainage
  13. Is the carcass side panel distorting? The hinges could well be fine but the load may be twisting the side panel into an ‘S’ shape moving the top hinge towards the door and the lower one away so the door effectively sags but the panel may return to vertical when the door is opened.
  14. Any covered area attached to a garden building is included in the building floor area, I’m guessing this is to prevent 36sq/m garages having another covered space at the side.
  15. Beam can be above joists to keep a clean soffit / ceiling line, it does make connections somewhat more complicated tho. padstone looks ok, a little off centre but I have seen much worse. back to the underslung joists, what is above them? Is it just roof space or a usable room? Because this affects the loadings
  16. It’s a garden shed, as long as it’s not habitable then no regs or approvals apart from dimensions (floor area and eaves height) so you can just get on with it.
  17. Morning, this is one an SE because your BCO will (should) ask for the calcs.
  18. Cable on surface or buried without the conduit
  19. No you don’t need planning “consent” to abandon a project and return to original. However you could find yourself on the wrong side of BC if the original didn’t comply and you put it back as it was I.e the original foundations would now be deemed insufficient so to reinstate you would need to put in new founds with BC sign off etc.
  20. Yep! They look very close to some precast benches we were asked to lift in. When the guy said they were around a grand for each 2m block he was told to “drop them in place” his self.
  21. Reinforcing is tied together so it acts as a continuous piece, overlap and wire together.
  22. Pretty typical ex council house outhouse, concrete slab roofs were lifted on in one piece usually. Good concrete little reinforcing. Will happily self support over a single doorway but would need support for a double door size opening.
  23. @Pocster with Mod power …. Be afraid …. Be very afraid! But it gets my vote just for the sh#£s and giggles.
  24. Hi and welcome
  25. Morning, for your 6 or 8 holes I would be hiring the cutter. If it’s new then won’t be distorted or side worn so excess wear isn’t going to be an issue. concrete especially war time era around steel producing industries can contain a lot of slag which is very abrasive and a PITA to cut through. Keep the water flowing to flush the cut and let the cutter go at its own pace. And yes cores can look amazing, I used to have one we took from a bridge pier - it was more steel than concrete!
