Everything posted by markc
Concrete lintel for window in blockwork wall
markc replied to tvrulesme's topic in RSJs, Lintels & Steelwork
A couple of lintels are overkill loading wise but as they cost very little and are convenient they are the way to go- 1 reply
- 2
That could well be Keruing … can vary hugely in colour, it’s like cutting iron and the dust is horrible
Looking closer I reckon you are right, but to use the roof it will likely need to come off anyway not least in order to strengthen the structure and install upstands and edge protection etc. Making a roof a usable space is much more than gaining access. doh! Just notice @Roundtuit bet me to it.
Had a few bespoke pieces of glass made by Glassandstainless.com and they have been really good, wasnt walk-on and it was the right size.
Not the best detail to fix to but the job that has been done is terrible and will never be solid, as mentioned before it should have been taken down the side and through bolted or a spigot welded to the beam flange, and newel slotted over (boring a big deep hole in post is awkward but not that difficult).
Forget that, just re read post
Posts with alu channel works well too (great for steel posts) slide glass in and silicon or mastic to fix in place
It does look like lead, can’t be 100% sure without feeling/scratching it. I am curious why an access hatch? Unless this i a very tall building or difficult access.
I can’t see the top pic ? Assuming there is 2 and not just a big white area.
Switch fuses are all very similar, some are easier to make connections, some have thicker enclosures. The Hagar boxes do seem to last better exposed to the elements. If you are putting it into a box/shed/kiosk then I would be going for the Lewden box. Had a couple of the Electrical Direct Dist Boards and found them flimsy with rubber screws
Last nuisance tripping problem I had turned out to be electric UFH in bathroom
Jobsworths!
Water pipe and electricity cable in duct to carport/garage
markc replied to AliG's topic in General Plumbing
It may be frowned on but I don’t know of anything that says you can’t have water and cable in the same duct especially as it’s on your side of the supply. Both in the same trench is common and the trench will drain whereas a duct probably won’t (assuming ends turn up). -
Got to agree with the above, that roof doesn’t look bad at all
Bi-fold doors with glazing bars - that aren't wooden
markc replied to Wuey's topic in Doors & Door Frames
Easy in wood, bars would be too chunky and horrible in UPVC and horrendously difficult and expensive to produce in aluminium (and look right). I think you will have to go with bars inside the units or maybe fake bars on outside of glass after fitting units -
Compressor to blow it through works much better than sucking
I can see where you are coming from, either way if ok so go with whatever makes you more comfortable or what the installer recommends
@patp octopus are renowned for taking time to connect to 3 phase meters, and as Joe says, use your readings to estimate your bill or post here and we can estimate for you.
Leave the breather as it is. The grip upstand is a solid barrier so the breather is doing nothing at that location
Easy to get units with internal bars for the “Georgian look” or are you wanting fully built multi pane panels?
