Everything posted by markc
Good morning and welcome, you are not alone, we all go through the “How hard can it be”, “Why did I start this”, Oh God I’m going to die phases … well maybe not the last one. loads of info on here by searching past topics and failing that, ask away
Whilst population control is a touchy subject it has to be addressed, in nature boom and bust (in population terms) is common. waste! Production of and marketing of waste is big business, everyone (majority) have to have the latest gadgets, tech, phones, excercise ‘thingy’ etc. good design of housing and buildings that don’t need ever increasing amounts of AC to keep them habitable, as kids we never saw AC even in 1976 when it was very warm but now people will die if they don’t have AC at work or countless fans at home. basically, we have all been taught to be soft and we need to toughen up and as above, leave a little footprint as possible
Space needed for truck deliveries and turning?
markc replied to Alan Ambrose's topic in Project & Site Management
A decent driver will get into places many would struggle to get a car, the turning circles are space needed without shunting so forget these -
Howdens vs DIY Kitchens - which one to go for?
markc replied to johnhenstock83's topic in Kitchen Units & Worktops
Go with who you “feel” best. Chipboard is all pretty similar, most fittings are similar (unless you are prepared to spend a lot of money). A cheapie kitchen fitted well will outlast and out perform an expensive one fitted badly. painted finishes are one area you can spend a bit more. Next white kitchen I do for myself, I will paint it myself using 2 pack car paint -
On a small build or extension doing all the work is common. Raise your concerns and tell him you will be having it inspected and if it isn’t right he will have to put it right and pay for the inspection. If it’s all done correctly then the inspection is at your cost. there is a good chance the local roofer would do a worse job so have a contingency but don’t cause problems beforehand
We have supplied machines to the plant in Sherburn and the disregard for cost and waste is shocking
+1, ply is more tricky to fit than T&G but is clean, neat and very durable
Water main replacement, fittings and weeping joints
markc replied to MarkyP's topic in General Plumbing
No tape on the MDPE end, the threads do nothing for sealing, you probably pushed the o ring into the fitting. just re read and it’s the threaded end into fitting. sorry my mistake -
Or get a conservatory but call it an orangery because they are so much classier lol on a serious note, pics please including the surrounding area. Any flood defence work been done recently if you live anywhere near a river or canal? Any major construction projects close by? Change in water table or land drainage can have a big impact on tied but independent structures
I would never be a LL again … ever! Several bad experiences years ago, it must be horrendous having tenants now.
Intumescent paint has to be thick to get the film thickness as it works be swelling up when exposed to heat. The can or spec sheet should give you the applied thickness to be effective, usually 400 microns (0.4mm) and upwards.
How to estimate self-build costs before starting
markc replied to selfbuilder91's topic in Costing & Estimating
The plot itself can have a massive impact on costs, access for deliveries, ground conditions, distance and availability of services all affect your build cost- 23 replies
- self-build
- budget
(and 2 more)
No, just allow for and make a decent fit half lap joint because it will be so much more visible with 100x100
laying laminate - looking for some know-how
markc replied to johnhenstock83's topic in Wood & Laminate Flooring
Morning, fibre underlay does not need an expansion gap but I always leave it around 20mm short of the board to reduce chance of underlay soaking up any water that runs off end of board. if you stick to 1/2 or 3rds staggers people will be drawn to lining them up, random stagger lengths prevent this. Timber shrinks when hot and dry and expands with moisture, expansion is less along grain and more across it so unless you have a very wide area across grain the 5mm all the way round should be plenty. you can go around door frames but looks terrible, easier to cut the frame and let boards go under at least a few mm. -
BCO shouldn’t have any problem with 2x stacked timbers, stagger joints and nail together and you have a sound fixing
Good morning and welcome, at 3 feet high and stable (looking) ground behind it the wall doesn’t need to be anything special. Laying bricks is an art form, blocks much easier and sleepers even easier. Cost wise, blocks cheapest followed by sleepers and brick most expensive. Brick and block needs a good foundation, sleepers will happily sit on some gravel or hardcore for drainage. Any wall needs water to drain from behind and out at the bottom or at the ends. Build the wall, dpm (damp proof membrane) sheet behind and back fill with 6 inch or so clean gravel between wall and soil.
To build off neighbour extension or not?
markc replied to Narthecius's topic in Party Wall & Property Legal Issues
No minimum as far as I know. New build not far from me and I don’t think anyone other than a tiny child would get through the gap, seems stupid. -
Exactly, just had a conversation with a 30ish woman and she thought interest rates were now an all time high, she didn’t realise double digit rates were quite common pre 2000
Do yourself a huge favour and keep your structure independent. You will need party wall agreement for digging footings close to theirs but much simpler than connecting to it. -
Q: Rendering: how steep was my learning curve? A: Vertical.
markc replied to ToughButterCup's topic in Plastering & Rendering
For a first go I would say that is pretty damn good. Render and plastering looks and sounds easy till you have a go at it. -
Lithium battery fires are fierce! And produce a lot of smoke and fumes, halon, co2 or similar fire suppression systems have little to no effect as the fire is a reaction rather than combustion. Personally I wouldn’t have any large lithium batteries in a loft but if it was necessary they would be in a large fireproof (hardybacker etc) crate with the top vented/chimney to atmosphere.
Anyone else remember interest rates around 15% ? When you got 10%+ on your savings. mortgages were roughly £10 per month per £1000 borrowed
Opinions on best way to drop a ceiling
markc replied to Thorfun's topic in General Construction Issues
If it’s not already boarded then no, makes life really easy attaching the additional battens, do them at 90 degrees to the trusses to stabilise the bottom cords -
Battens and PB will be fine, the additional load is well distributed and static.
