Everything posted by JohnMo
Mitsubishi Ecodan Air Source Heat Pump - Low Efficiency
JohnMo replied to TimToos's topic in Air Source Heat Pumps (ASHP)
Keep an eye on room temps. So if the thermostats start controlling the temp the temp in that room is too high. If all or most room are controlled by the thermostats the flow temp is to high so reduce a degree or two at a time . If only one or two room are not getting to temp or are too hot, you need to increase flow at UFH loop flow meter at the UFH manifold or at the rad to make room warmer, reduce flow to make cooler. -
Not sure, but they say at over 3m3/m2 leakage rate the benifit of MVHR is small. You have to consider the energy use to drive the MVHR unit compared to recovery of heat. If air is coming into the house in an uncontrolled manner, but at an acceptable rate for ventilation, you are just adding additional ventilation, which you have to pay electric for.
Seal loft hatch, ensure all windows are draft sealed, if they have trickle vents these would need to be sealed. No cat flap Seal all wall sockets and light switches Even with all that, it could still leak like a sieve, due to the gap left at behind the skirting
That's a good price, but the Trianco company has closed. Pity. I was looking at an inverter Dream heat pump. It connects to smart life app so I was going to build a simple control logic in to that.
If you heat load is that low I would suspect it would be off. The average heat demand is around 1.8 to 2.0kW for the months of the heating season.
I am sure MSC has a complains process, you have a look in to it. Read up on heat geek, lots of free info on how set things up, well worth an hour of your time. -
I noticed cool energy do a package consists of ASHP plus an exhaust air heat pump cylinder. But if you have an oil or biomass, just use that with a UVC for DHW. I have a theoretical heat demand of 3.2kW. I am thinking of getting a 3kW heat pump just for my underfloor heating. No buffer. Just need to get around how to make the gas boiler fire up if and when I hit a shortfall from the ASHP. But it is big enough for most of the heating season, just not the extremes. I can also then use it for cooling in the summer. Electric demand is 0.7kWh, so would run on solar most the time.
It doesn't mean having the temperature the same 24/7, that's why all system have a set back. The set back reduces the flow temp and by default the room temperature, still doesn't need a thermostat. But as you say you need to work at to get it set to run correctly. UFH and rads is not an issue, as you balance the room flows to get the temp you want. Thermostats just get set a degree or so higher than the target room temperature. -
If your heat pump was MSC installed the performance output sheet they gave you with quote is a guarantee of performance. If you are meeting the figures they gave you, you have recall for them to repair / replace at there cost. As a note You cannot operate weather compensation correctly with zones shut off and thermostats controlling temperature. Thermostats and trvs are there only to limit overshoot if for example the sun's out heating the room. -
vent axia MVHR advice
JohnMo replied to David-1712's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I really wouldn't start messing with any settings, as these should all be configured, you cannot just change one thing without messing most other settings. You need to know what you are doing, with the correct test kit. Things you need to check Extract ducts, may have a filter at the extract point. The nozzle just slides out of the ceiling if there is a filter it will be cone shaped. Remove and hoover out 6 monthly replace annually if installed. The main MVHR unit will have filters inside, inspect every 6 months hoover out and replace annually. Make sure there is no accumulation of water. If you have boost switches use these prior to a shower and during cooking. In trickle mode the extract nozzle will just about hold up two sheets of toilet paper -
Static pressure calculations
JohnMo replied to LinearPancakes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The system pressure are worked out for the extract and supply. The route for extract with the highest pressure drop determines the extract pressure drop, the same is true for the supply. You need the datasheet for your materials, ducts, manifold, nozzles etc. and your target flow rate. From this you should get the info you need. Basically the high the flow rate and the longer the run the higher the pressure drop. -
Noise requirements and planning consent
JohnMo replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
Not sure you have done the calculations. See attached calculation sheet. MCS-020.pdf -
There may be a few issues Reducing flow temp to hot water cylinder will increase CoP, store water at a lower temp. Slowly over a couple of days reduce the temperature until the last use of the day starts to go cold, then add a couple of degrees. Cold rooms in the house increase the heat loss in warm rooms as they are experiencing heat loss external and internal. So the heat pump has to run harder to make up the difference. Also you end up making the heating circuit smaller so the heat pump cannot flow at a high enough rate, so suffers frequent shutdowns or short cycles. Both are no good for the CoP. Go on to heat geek and read up on how to balance your heating system. You really want the system to have an open system to flow against, but set the flow rates to get the temperature you want. The thermostat then are set higher than you need and operate as limit stops only, not as temperature controllers. You then need to get your heating flow temperature as low as you can, do the same as the DHW reduce over a period of days, then when it's not heating as you want it bring back a degree or so Can you set up weather compensation? Again have a read on heat geek site. -
Sorry lots of comments as I think your being taken for an expensive ride. I would say the scheme way to complicated for its own good and your sanity. The boiler only ramps down to 7.1kW if you have only a couple zones operating your boiler will be shutting down and starting up like no tomorrow, using lots of gas and provide little or no heat. You need to make sure all the pumps are hydraulically separated, a series of close coupled tees will do. You may need to look at the return flows also. First thing is dump all/most the room stats, they will just cause the boiler to short cycle and use loads of excess gas. Also operating as one or at most two zones will let you remove the motorised isolation valve from upstream of each manifold. The pump will pull the water through as needed. I would dump all the smart stuff and use a single glowworm controller in a central location and outside temperature sensor and enable weather compensation. Then balance the room flows to get the temperature you require. You don't need UFH in the halls or landings, they will get heat from the pipes going to rooms and borrow ambient heat from everywhere. We have UFH in the bedrooms and I would say to anyone don't do it. Way to slow respond, radiators or fan coil, then at least you can implement cooling later when you have a heat pump.
- 1 reply
No I mean the company called Roof Maker. Airtightness details same as any windows
Roof maker also. That what we have. Ours are fixed, having them open would have been an advantage with ventilation on hot days. Only thing to watch is the amount of solar gain you get, can turn a roof room very hot, very quickly. So think about paying extra to limit solar gain, additional coating etc. However your look a sensible size.
Bet that was nice
Where is the kWh price heading in 2022?
JohnMo replied to epsilonGreedy's topic in General Self Build & DIY Discussion
But we will all know what's occuring on Thursday, or so they have just stated on R4. -
And as they scrape that man from the pavement, his mate kept hold of the panel, but is stuck on the roof and can't get down as he has no hand free.
Not heard that one. The other way to look at throttling is A lot of the year you will not get 5.6kW out of your system, even on a good day you will only get 5.6kW for an hour or so. Your 3.6kW should be output for most of the year depending on angle and direction
If your panels are on the roof, could you bring the optimisers/inverter inside the roof, then it's just a loft ladder to get at them
But 3.6 kW inverter will have a small tolerance for over locking possibly a few 100W not a couple of kW. Then if you want 5.6kW you get into an a correctly sized inverter, but with export throttling. Or you go G99.
If we are selling overseas they pay market rate for importing the energy, we also pay market rate at time of import into the UK. Just normal commercial transaction. Import and gas electric will fluctuate in price the average price would be passed on to the consumer at some point. They should be able sort that quite easily,as the system has been used for decades. -
All they need do is delink the gas price from nuclear and renewables. At the moment the wholesale price of electricity is all based on gas generated electric. Why should the tax payer support extra profits for generators where it costs no more to generate than it did prior to the gas price rise.
