crispy_wafer
Everything posted by crispy_wafer
Tank in and nearly ready for the static
crispy_wafer commented on flanagaj's blog entry in Contemporary Dream
Love it, well done. -
I guess it depends on the damage, repair could be just tape, or cutting a patch of membrane to cover the damage and tape up the edges. Breather membrane tape is available, cant advise of which would be best for you though.
Ingress of Water into Inspection Chambers
crispy_wafer replied to Arrenite's topic in Waste & Sewerage
https://www.drainagesuperstore.co.uk/product/accesso-ic110-450mm-single-piece-adoptable-inspection-chamber-1500mm-invert.html?ppc_keyword=&gad_source=1&gad_campaignid=22291034282&gclid=CjwKCAjwi4PHBhA-EiwAnjTHuYGbRQ2uc_O_SIFjCE4ec5OjeIdvk3QPTyu2zdoLGYQ9ZLhafKKjghoCK5gQAvD_BwE -
Best approach for drilling 20mm terrazzo tile?
crispy_wafer replied to markharro's topic in Bathrooms, Ensuites & Wetrooms
Oh yes, I like this, genius. -
Flood risk - refining risk level; mitigations
crispy_wafer replied to Drellingore's topic in Surveyors & Architects
as above, we did, 600mm above an open internal drainage board drain that runs through the land. Having multiple floors for refuge in case of that 1 in a 100 year event also helps. -
You've pretty much just described my install... 1ph to crappy bungalow, 1ph to new build, 1ph unused, but it will be a big garage with living space above. I guess it comes down to metering and the properties are they staying in your name, or are you looking to sell one?
I bought a few of them steel rectangular, slot together jobbies of FB marketplace, not suitable in anyway shape or form for trade use, but for DIY use and hedge trimming up to about 2.5m platform height they are perfick! £200 or thereabouts Easily create a platform long enough for a 3.9m board to span. If you want to go any higher than that forget it get a proper one like those above!
Polypipe, hit your local civils place, often worth their weight in gold through experience and advice.
- 1 reply
did you try or think about what @Nickfromwales suggested eps at the bottom of the cavity, xps board against the outer leaf to insulate against the cold bridges then fill with concrete.
use a 135 junction and shove a 45 in the end of it.
DHW/CW Manifold location & configuration
crispy_wafer replied to SelfBuildSmurf's topic in General Plumbing
I did similar, kept accessible, because I’ve put stop taps on the two feeds off the main. Saves me having to go out to the road to kill the individual tails. I’m in the process(2 years, because not important just yet) of building up a chamber, it’ll be something along the lines of 700*1250 ish so I can get into it should I ever need to. There’s probably a better way, maybe theres a manifold for mdpe which could simplify matters, haven’t looked tbh. -
Alterative option to 150mm celotex + 50mm celotex?
crispy_wafer replied to flanagaj's topic in Heat Insulation
Just be mindful, I wasnt... With trusses you may get cross bracing included! makes insulating a pain in bottom as the bracing can get in the way, it can be done though, just takes a little more time. -
22mm T&G first floor install advice required
crispy_wafer replied to ruggers's topic in General Flooring
I’d say that he’s right to concerned that screw/nail holes can be affected by rain/moisture, no different to the board joints really, so put a small dob of d4 over the nail/screw will help. A floor scraper when watertight to lift the foam. -
I cant add too much, but in the first instance i'd ask, does the HP have a pump built in, if it does, then does it have enough grunt to supply the needed litres per minute for the install.
Cold water feed passing under new concrete slab
crispy_wafer replied to maznaz's topic in General Plumbing
Personally, under the slab I wouldnt run copper, i guess many have done in the past though, Me, I'd run a 110mm soil pipe and push 25mm mdpe through it, rest bend where it comes back out of the slab. No pipe joints where you cant get to them. -
Wall for floating staircase?
crispy_wafer replied to flanagaj's topic in General Self Build & DIY Discussion
Nice idea, yeah I'd run it past your SE for peace of mind, or even @Gus Potter might lend an ear for his thoughts. I cant help too much, because I've gone with central spine, however when time comes for manufacture, assuming you don't fabricate it yourself, don't be afraid to look up local fabrication firms and joiners for treads. -
downpipe at one end or in the middle of the run?
Leveling old ceiling with GypCeiling MF
crispy_wafer replied to Annker's topic in General Construction Issues
Would it be easier to just batten with 3*1 or 4*1, using the lowest spot as your zero point, and shim out the battens at the high spots. -
Wont lie, got two, one had to be swapped 4 times because of stone resin that had set on the underside of the drainage outlet that I wanted to use, I was unwilling to sand/grind it off incase I fubar'd the tray. The company I purchased from were first class in dealing with the issue for me, even though the tray had sat for 6 months or so without me unpacking or installing. This was the first time I'd actually rejected the replacements before they even got off the delivery van. All good in the end though. In terms of the tray, yeah it looks good, don't even notice it now!
