crispy_wafer
Everything posted by crispy_wafer
just been at the backer boards in the bathrooms, already getting ocd with the straight edge. I wont be tiling no way, absolutely not. Tried dot and dabbing at the weekend, did one wall, came out alright, got brave and went to do another, about perfectly flat, but 5mm out of plumb, that's it, not doing anymore cant face it! I've had a go, so now the pro's can do the rest.
yep š¤£, usually have a few going round my head at any particular moment during the build.
Yes, I did too. Fill the space the best you can, full sheets staggered, then half sheets and offcuts to fill remaining spaces. Square edges get most joints nice and tight. Any rocking will get flattened out with screed, foam any gaps where you cannot realistically fit insulation. Don't worry too much about it, you are not aiming for instagram/marketing levels of finish, do the best you can, then get it covered over with plastic sheet and crack on with the UFH if that's your path.
Speak in person to the merchants to get best prices. Do a rough work out of qty's and get yourself a baseline price. Also, make sure your builders would be ok with you purchasing materials!
Keep gas boiler or install heat pump?
crispy_wafer replied to Walshie's topic in Central Heating (Radiators)
if you want to run a cable for future use, I'd either run a duct so you can pull a cable at a later time, or get a heat loss calc done so you can quickly spec up the right size range HP and what it's cable size requirements are before you start pulling cables. -
Nah, a squirt in the end about 30mm or so each end and a very quick trigger, how far into the conduit the foam spreads I don't know. once two cables are in, the nozzle will only go so far.
That's a useful tip/thought. How deep would you say the track is on your blinds? I meant the inner leaf, but yes your point is valid and stands. The reveals are taped over and the corners painted with soudatight. I have 80mm to play with, so if I want 40mm frame to sash, 15mm plasterboard (got a pile of 1200mm offcuts to use up) + skim leaves me with 20mm or so to insulate behind. I've over ordered on the jackoboard, would this do?, or should I PIR it - guess I could ct1 insulation to the PB, I've got some sheets of 20mm left over from when I did the screed perimeter? Sounds like you had fun achieving that...
yep, then ct1 over each end, if insects want to get in they are gonna need strong digging tools
my confusing wording wont be helping š¤£, yes to window reveals. Lets say before plasterboard I have an 80mm of frame on show from block to the bit that moves when you open the window. I was thinking after boarding to leave myself 45mm of frame showing? Would that be too little, too much, or just about right?
Ta muchly, cable ran, thatās saved me from dog house.
Morning all, In my excitement of boarding up have forgotten to wire in another switch to control a separate light. Situation is a Bedroom with wall lights either side of the bed, each side have its own switch to control itās side light. Now Iāve ran the looped in cable to switch 1 on one side and ran the loop out cable to another room and totally forgot about switch 2. Can I run a 2nd cable to loop out again from bed switch 1 to bed switch 2. thx marek
Iād give the top of the plasterboard a knock with the side of your hand or a fist , you should be able to hear/feel where there is adhesive, sounds are different to where there is none.
What kind of poziās, are they the metal web jobs or the I beam type? The metal web jobs are a PITA, to get between the webs on the joist without making a mess of your hands, or material, itās doable of course just increases the amount of labour time to do it right without gaps etc. Just my thoughts just so you go into this with eyes open!
Help needed setting timber frame window hole sizes.
crispy_wafer replied to G and J's topic in Windows & Glazing
@Iceverge I need to get hold of some of these J beads for my window reveals, do you have a picture of what they look like? I mean if I go into the merchants and ask for j bead, I want to end up with the right stuff! -
Youāve got ventilation going on above the roof insulation which is good, however the detailing of the pir install is not so good, which may well be allowing this ventilation a path down behind the plasterboard. For me, the gaps need filling then taping over before any hint of the ceiling plasterboard goes up. Because there are gaps the cold outside air is making its way round the plasterboarded wall. Tiles off or ceiling down. Fill the gaps, tape up jobs a goodun. Save it for the summer though A common method for fixing the plasterboard not having continuous ribbon of adhesive round the perimeter of each board is to drill a series of holes at specific intervals and squirt a low expansion foam (Illbruck or soudal) what have you got on the ceiling? Is it insulated board or just regular board? needs rectifying really, donāt want to say youāll end up with mould issues but itās possible where the colder spots are.
Just want to say a thx for posting this, I have a small section of flat roof to which doors open and needing a balustrade without puncturing the covering was my preferred solution. I had thought about having a deck frame fabricated and balustrade fixing to this. This will help immensely with my idea. š
Recommend a shower tray please
crispy_wafer replied to Post and beam's topic in Bathrooms, Ensuites & Wetrooms
Kudos connect 2 will give you a get out of jail card if you have troublesome joists⦠-
Do affordable(to buy) work towers exist?
crispy_wafer replied to YodhrinForge's topic in Tools & Equipment
Yep, invest and treat like a long term rental, stump up and buy wisely and come the end you'll get your money back. -
Steel beam installed - padstones look tiny....
crispy_wafer replied to Sunil237's topic in RSJs, Lintels & Steelwork
My steels were installed onto pad10 stones like these https://www.builderdepot.co.uk/102mm-x-330mm-x-215mm-concrete-padstone-pad13?gad_source=1&gclid=CjwKCAiA74G9BhAEEiwA8kNfpW7AdykZ7lJQ_1MUWQcu2QTXVMIk3iRFiHalWnLcnY_Lss5WgQ5kxhoCRcIQAvD_BwE builder ought to be following the SE guidance, and not deviating, unless he can prove categorically what he has done is equal to or better than specification. -
Best type of trowel for Dot Dab
crispy_wafer replied to crispy_wafer's topic in Plastering & Rendering
I've given that some thought too (the framing, that is)! I've got a smallish wall in the dormer bedroom to attach, couple of sheets trimmed down will do it, I cant really bugger that up. That'll keep the Mrs. happy as then it's one area that'll look something like a room š¤£. You'll have to pop your thoughts in your thread about the wall liner system, ease of use, gotchas etc. I've got a block wall downstairs that will be lined as I've got 28mm copper pipework to my UFH manifold down it to conceal as my staircase is now going to be an open tread jobby and don't want to my lovely pipework on show.. -
Simple really, what's the best/easiest trowel to use to get the muck from the bucket onto the wall? Had a go with a plasterers/finishing trowel and hawk which is all I have and while I managed to get adhesive on the wall I struggled with consistency in size of the dabs... I mean the finished result was fine, just felt a harder job than it ought to be. Could be this apprentices cack handed technique too! Many Thanks Marek
What is a good backer board for brick slips
crispy_wafer replied to Post and beam's topic in General Construction Issues
would say any of the cement fibre boards eg hardie and others would be suitable. No experience myself so would wait for someone who has trodden this path before to chime in. What's the substrate?
