Dave Jones
Everything posted by Dave Jones
wouldnt worry about it they are both big companies. Bigger things to worry about!
radon can also come from made up ground. Check your planning conditions to see if it was specified, if not dont bother.
where is that from ? plug in solar is double! https://www.pluginsolar.co.uk/?product=plug-in-solar-3-75kw-3750w-new-build-in-roof-bipv-solar-power-kit-for-part-l-building-regulations
https://www.victronenergy.com/inverters/phoenix-inverter-smart
looking at the picture id say 6-8k in block bit more with nice brick outer skin. Timber frame was cheaper than that ?
last build went 7106 on windows outside, white inside and a black front door to key in with black dry virges. looked good. I'd recommend flush sash windows as well, more expensive than normal upvc but the profile is soo much better. https://www.eurocell.co.uk/specifiers/windows/modus-windows
im amazed you find a timber frame cheaper than block or brick. What size are we talking and timber frame price ?
Door Threshold - Internorm Sliders
Dave Jones replied to canalsiderenovation's topic in Doors & Door Frames
looking at the second picture you posted can just see the lintel over what looks to be another sewer run, guessing it goes to the outlet in the middle of the room ? I'd get the builder to cut out that bit of floor inside and connect into that run and do away with that 90 hanging out the wall will look so much better. -
Stove Hearth/Chamber Inspiration
Dave Jones replied to canalsiderenovation's topic in Stoves, Fires & Fireplaces
bit late now but we had ours built of brick so no need to plaster. Went to the local reclamation yard and found some ancient flag stones 4" thick for the hearth. -
did same above a gable window lintel, struct eng specified a HD catnic, the brickie wasnt happy with the defelection in it and added a pre-cast conc little to the inner skin at the back of it to stiffen it up. Cheap way to belt and braces it to stop any movement.
sodium hypochlorite. spray on with 10 quid garden sprayer and leave it overnight. hosepipe it off or let the rain do it will be like new. No scrubbing required. https://www.ebay.co.uk/itm/Sodium-Hypochlorite-14-15-Patio-Cleaner-Swimming-Pool-Chlorine-10-Litres/293530139736?epid=11037962208&_trkparms=ispr%3D1&hash=item4457c27c58:g:r7cAAOSwRsJehe7e&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkvjzWOStkxwnlDuxSI1PVVu8e5rlRA4HwQngsX5udberl6rRHs%2FMOJD89a35nRa2ilDubBNc9iASqP4F72mvHidM9vQ1Z9QMtIcU0mVQP24860dJKaXYXLXtz0RIzgKnX7jBBvFfVLHlxIhGmicbtM%2BAdWsFrEoMhWY2TTrrxJzInoZPOAgHSMvWmcPU0Hi6MVTWNnbzUsgXC1FKCqyRbeeOyZ4YeGeR8M7ItR%2Fn6Jwf09Fzll8dbfe7dlOOQPCI0cT8Rm3b4astrBVCPSVF0EQoNETEtT4bX4t20JbyI00OmvyZKEcQ23YrbPTVfIY1s7q8KEyKqpENP7ezld99QZGO0xwxa0PjqLuJfLZjkQxPs6p0IDI3V5gy%2FjQ97IpDuMhSS46D9%2BlbSe2wvaEixTR0h1S2e11sRco4pvicx5KM2aEmxl9VRfD90V%2BJFNg0C2bJyFBiR%2BNY8dWwilDp42ce9FMEnu%2B0gD7a0FwV0YobiEO88i0ZKit6EpfktrHxp5YXpT03vw%2BG5FuxJbarkoAOAQOcbEMmLKIbA5bYVT9WU0cNW1gkPUqqrjWKI8u%2BGxM56%2BmVfY9nN0U6XEw%2BwIXIFA6m7IwsoZvAVtb%2BP2KzfjZNTFKa1SrBlIC6PhDBBvPZmPNfQW1DbrL9ILqIJLDsI00b%2FTuxwhahwfG26%2Bspi0RwibHrWWPEojUiBnytz431rxp1KAO8zz4IQGatonNnel0vSbCtBJ5ejGPByxL1c3t47PfA8Vl8I9%2FmDuCk6Xiu5XkJhL07ANxOk2EfDUQ%3D%3D|cksum%3A29353013973641e3d213656a429db185ab70e2c2cacc|ampid%3APL_CLK|clp%3A2334524
training Backhoe loader/180 Excavator Training.
Dave Jones replied to BogBeast's topic in Tools & Equipment
i cleared all ours with a 3 ton digger. Really doesn't matter how big the stump is dig all way round, use the narrowest bucket to give most force to snap all the roots. Then pull it out, the object being not to lift but drag roll the stump. Leave it dirt side up to dry out for a week (or 6 months the way the weather is at the moment lol) then pull as much dirt off it as you can to save weight on the muck away. If the hole is where you will be driving then stone it up with hardcore not dirt as it will settle a lot no matter how much you track over it. I wouldn't bother a 3cx they are so much more cumbersome than a mini, more fuel, make more mess moving around, cant get into small places, expensive to fix etc etc. For a self build id hire the mini and buy a telehandler. -
Noticed your sewer coming out very high through the wall, appears to be through the screed on the inside. Did the builders forget to put it in before the foundations or a late addition ? Cant see a lintel over it either looks core drilled ? Has your building control seen it, maybe they are less strict your way ? https://nhbc-standards.co.uk/5-substructure-ground-floors-drainage-and-basements/5-3-drainage-below-ground/5-3-14-protection-of-pipework/ 90 bends are a big nono for our building control, cant see from that pic if it has a rodding eye built into it for unblocking but make sure there is one as it will be impossible to force a rod up two 90 degree bends from the chamber. Will also be hard to hide that as slabbing over will bring you to more than 150mm to DPC level unless you have a vertical DPC all way round ? Keep your eye on the builders !! -
Chains ? you dig them out not pull ! 3 tonner will tackle pretty much anything here you don’t need to lift stumps , drag them. -
thats a lot of muck away, bearing in mind bulkiing could be looking at 80 x 8 wheeler loads. Try and find a local farmer and make friends!!!!
why goto the hassle of level threshold and still have the sill on the outside ? Maybe im missing something. -
Recommend Me a MVHR system
Dave Jones replied to Dave Jones's topic in Mechanical Ventilation with Heat Recovery (MVHR)
interesting.... Want to be fully prepared for the 3 days a year it gets more than 20.... -
tell more! Can ASHP cool the slab as well ? Say 7c ? -
Starting our next build in Jan, It will be a traditional brick and block construction and I'd like to incorporate MVHR with cooling and heat recovery. Heating will be underfloor on both ground and first floor. Pozi joists so will have plenty room for ducting. 275 m2 of floor area to service. thanks!
