Eric
Everything posted by Eric
  1. @markocosic gutters look fine, building looks spectacular 👌🏻 Is that larch boards? Are they stained \painted?
  2. Did you ever get it wired up?
  3. Will it cut 100mm using the rail or are you just using a straight edge when cutting?
  4. @Thorfun do you have a link for these recessed ones? All the plaster in ones that I have seen seem to sit proud & your ones look to be recessed perfectly. Do you have any photos while fitting them also?
  5. Take before & after photos. Getting ripped off sucks, trades are getting worse!
  6. Would you mind sharing plans/photos? I am looking for ideas for a garage with room above.
  7. I had an integrated one & it never moved, I fixed ply to the floor for it to sit on. It came with a bracket that you could fit to stop movement but being the professional that i am I didn’t fit it
  8. Did @Pocster sell him the walk on glass by any chance 🤔
  9. Something like this?
  10. Anyone got any photos of their glazed gables?
  11. I am looking for suggestions or photos of how to detail the glazed gable windows, above, between the windows, and under. There will be aluminium cills fitted to the windows. Kit is blocked in & then there will be 120mm stonework on the blocks, I presume the trim will need to be finished before the stonework?
  12. Welcome to the forum. Are you doing any of the work on the new build or having it done?
  13. Do you have any photos of this? Currently looking for ideas.
  14. Plus 1, more expensive & would be my choice as well.
  15. I had the same with my vent axia unit, I found that the filters were getting wet with moist air being drawn in causing it to boost. I just increased the humidity until it stopped doing it, think it was high 60’s
  16. My kit & partitions are spaced to use full sheets then cut out openings. Yes, there is waste but a lot of it can be used in other areas but it’s a better job with no risk of cracking.
  17. We have quite a large family room & kitchen & could do with some input to get the lighting done properly 🙂
  18. Sheet over openings & cut out window/ door
  19. Have you tried Internorm?
  20. Not to derail the thread but do you have any photos of this Nick? I have a kitchen & family room 10m x 7m with double JJI joists @ 400centres, I was actually wondering about fitting plywood before plasterboard?
  21. I installed a Vent Axia in my last house & was very pleased with it. The controller was pretty old school. I didn’t use the boost switches as it had a built in humidity sensor which worked well. Edit, You can also boost from the controller.
  22. Scaffold will be up until all the block work is finished, roof is finished, soffits & facia finished etc. It depends on the scaffold company as they will dictate if they have to remove it, which is very likely due to risk/insurance etc. Builder will do the render.
  23. Yeah that’s going to be a PIA job for sure, finished treads are much bigger than the steel so there plenty of room to make the cuts oversized. It should be really nice when it’s finished 😬
  24. Yes, the wall will be plasterboard, then the oak treads will be made.
