Eric
Everything posted by Eric
Insulating under rafters, service battens & plasterboard
Eric replied to Eric's topic in General Self Build & DIY Discussion
Thanks for the info, I am curious as to how I should be fitting the PIR under the rafters though. Is there any specific way the sheets should be cut/positioned to line up with rafters etc. It is 15mm plasterboard. -
I am at the stage of fitting insulation under the rafters, vcl, 45mm service battens & plasterboard. Is there any particular way the insulation under the rafters should be fitted? Is it better to stagger or is it irrelevant due to service battens? Do the ends of the sheets need to be joined on a rafter or are they ok just on the insulation between the rafters? What is the best spacing for the service battens? 600mm seems quite a bit. The height from the top of the wall to where the ceiling will be is 1280mm. Any photos of previous work or suggestions would be appreciated.
Installation cost
Eric replied to Mr Blobby's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It’s really not difficult to do, sounds like you have all the routes sorted. Give it a go & save the money for something else, plenty of help available on here. -
Maybe attach some photos, someone may be able to help.
Can you put up a photo of the sockets once fitted please.
@Pocster’s favourite 😳
Big one yes but there are two smaller ones…
Looking good 😎 What are the small rectangular cut outs for?
Welcome to the forum. You have a bit of work to do there but loads of help & information on here to help you out 👍🏻
MVHR Unit Suggestions
Eric replied to Tumble's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I installed a Vent Axia, very pleased with it. The humidity sensor worked well. Personally I don’t know why you need an app, it just runs 24/7 & you have humidity sensor & boost switch/controller. -
MVHR help water in pipes!
Eric replied to hotnuts21's topic in Mechanical Ventilation with Heat Recovery (MVHR)
An absolute bodge as you have said. Water is probably condensation in the hoses. That type of hose shouldn’t be used, should be plastic pipe installed with flexible connections on the unit & silencers etc. I have installed a Vent Axia unit previously & was very pleased with it as with others on here. Probably best to disconnect all hoses & stop the water/condensation first. Edit. Unit in a cold attic needs to be well insulated along with the ducts. -
CLS or general carcassing timber for studwork
Eric replied to BadgerBadger's topic in General Joinery
Doesn’t matter if you pick the best ones you can, they still go out of shape 👎🏻 -
CLS is fine for internal partitions, I would go bigger if you need space for MVHR ducts etc. -
Welcome to the forum. I can’t answer your questions but there are loads on here that will 🙂
- 7 replies
- listed building
- off grid
(and 4 more)
Choice of insulation for under rafters on attic trusses.
Eric replied to Chanmenie's topic in Heat Insulation
What does it say/show on your building warrant drawings? I think I understand what you are saying but it would be better fully insulated with pir as Thorfuns photo above. -
DIY Vent Axia Sentinel Kinetic install
Eric replied to FrazK's topic in Mechanical Ventilation with Heat Recovery (MVHR)
As long as you use a waterless trap. -
First house project, going okay, but..........
Eric replied to Southdean's topic in Introduce Yourself
Welcome to the forum 🙂 -
Tiles look good, will they just fill up of dirt though?
I think you use a special primer/sealer on moisture resistant, I’m sure someone like Nod will keep you right.
Welcome to the forum. That is a good unit you have got, you could insulate the pipe work, I bought oversized insulated flexible duct and put the pipe through this then laid insulation over the top. -
You will need self drilling screws to fix your brackets to the frame.
Gutter slope / fall - will you see it?
Eric replied to markocosic's topic in Rainwater, Guttering & SuDS
Wowzer! Serious amount of work but also very impressive 🙂
