@lizzieuk1 Our insulated raft sat on 250mm compacted type1 with 50mm granite fines on top. The insulation was 300mm thick. The inspection chamber was around 3m from the edge of the raft. The pictures show before and after sub-base was laid.
Changes to the grid proposed
Gone West replied to Temp's topic in General Self Build & DIY Discussion
What is the date today??? -
For a newbe self builder I would have thought that full plans is a very good idea/essential.
We used Schneider Lisse fittings in our new build and wanted to use them in our current house but unfortunately they are not exported to the UK any longer. We chose Hager Sollysta as an alternative. As @jack says buy samples before deciding.
Sticking insulated plasterboards
Gone West replied to Arnold9801's topic in General Self Build & DIY Discussion
+1 for Soudabond, I've never had a problem with it. -
I would want to know what the actual air tightness is now. So I would have a test done, and then you know what you are working with. If it's really bad you might want to react differently.
Yes, that's right. Also, I can see there's another mistake made when installing those plastic fittings. It looks to me like the plumber used Speedfit pipe and fittings and there should be a collet in the groove on the fitting. The collet is there to prevent the fitting from unscrewing by vibration and is a good check that the fitting has been installed correctly.
The easiest way is to use a short length, 70mm, of copper pipe into the brass compression fitting and a straight plastic connector joining the copper pipe to the plastic pipe.
Where a brass compression fitting is used with plastic pipe you will likely get a leak after a while. So this is all the places where you have white pipe attaching to a brass hexagon fitting, which is several in your picture. I would remove all the mouldy/damaged materials and have it replaced with new, and get a decent plumber.
@Nickfromwales should look at that. It's his favourite, compression fittings on plastic pipe!!
What are these and how should I use them?
Gone West replied to Crofter's topic in Doors & Door Frames
Very similar to the type I have. There should be a slot around the outside of the frame. The steel strap should be put in the slot so it is parallel with the edge of the frame and then turned through ninety degrees so that the two protruding lugs lock into the slot in the frame. -
Raft foundation - close to existing structures
Gone West replied to WisteriaMews's topic in Foundations
Sixteen years ago we had an Isoquick 300mm Peripor insulated raft foundation installed. The Structural Engineer specified 200mm compacted type 1 with 50mm thickness of 3mm granite fines on top, type 1 to be extended 700mm beyond outside edge of raft. The raft was 200mm thick with two layers of A393 reinforcing mesh and an additional third layer, 1200mm wide, around edge of two storey part of foundation. All this was for our ground conditions, yours could be very different. -
It’s coming out the hole
Gone West replied to Pocster's topic in General Self Build & DIY Discussion
Bolt the bottom fixing to a steel plate and screw the plate to the stonework with four screws. -
MVHR. For sign off.
Gone West replied to Russell griffiths's topic in General Self Build & DIY Discussion
I self installed and commissioned and the BCO wasn't even interested in seeing the paperwork, but that was eight years ago. -
Vaillant ashp (my battle with).
Gone West replied to zoothorn's topic in Air Source Heat Pumps (ASHP)
I suggested that on pages 14 and 16 but apparently a 30kW oil boiler won't do the job!! -
So many people have been drawn into this rabbit hole. No one listened to, no opinions changed. If you don't have the kind of understanding of science needed, then just accept what you are told and act accordingly. -
Wasn't the Strangford Lough turbine a rotating one?
1. Boxed in order, small receipts stapled to a sheet of A4. Check receipts thoroughly before putting in box to make sure they have a VAT number and are proper VAT receipts. Each receipt was numbered in order to match the spreadsheet. 2. 385 3. Spreadsheet 4. No stress, my partner did it. 5. No That was back in 2018, things have changed now I think.
Our concrete slab had been down for nearly six years when we tiled. We used BAL flexible tile adhesive and used door threshold expansion strips. No decoupling matting used. We didn't have any problems.
Yes, we achieved 0.47ACH with only the Icynene, combined with the 15mm OSB3 exterior racking, as the airtightness. We didn't use any tapes or membranes in the structure at all. The windows and doors were sealed using two strips of Compriband and the Soudal SWS system.
