Was the Geberit system you used FlowFit?
I plumbed my last self build using Speedfit, which went well, and I was planning on using it for the rest of the plumbing here.
I'm only planning on plumbing one room with MLCP because of space for fittings, although if I like it, I might end up using it elsewhere. I was hoping to be able to hire the press tool.
I've not used MLCP before so I have some questions. I've looked at videos of Multipipe and Geberit MLCP systems and the Geberit system looks good for access in tight spaces. Can anyone give me some advice about makes they have used and how easy it is to use an adapter to go back to existing copper or plastic pipe.
When I built my place I had a Senco 1st fix and a Senco 2nd fix nailer. I used 50mm stainless brads for cedar cladding.
Any recommendations for tanking this plant room?
Gone West replied to Great_scot_selfbuild's topic in General Flooring
When I designed our house, the plant room was next to the ground floor wet room, so if there was a leak, the water could flow down the shower waste. We also had all the water in one quadrant of the house, so all the pipe runs were relatively short. -
We had a similar layout and our ramp ran from the left, in front of the house.
https://www.gov.uk/government/news/london-pioneers-first-virtual-power-station Looks like it started around six years ago.
Isn't it possible to fork out a bit more and have a full SAP EPC calculated rather than an rdSAP version.
After a long chat with Grok it seems the monthly cost of the Residential 100 subscription is increasing to £40 in the UK. It also told me how to see my billing preview for the the next month, which at the moment, is still £23. Grok indicated that the preview might change, but that the email was probably sent in error as the price was in dollars. I'll wait and see.
I've just had notification from Starlink that my monthly payments are increasing to $40 (~£30) from next month. I thought when I signed up that I was getting the first six months at £25, and then onwards, £35 a month. There is no record of that agreement as it was on the order form that I filled in. So now I have actually paid £23 a month for the first three months and I will then be paying ~£30 a month. I hope it doesn't keep creeping up. Just a warning to others to keep a record of any agreements. It is a rolling monthly agreement so I can cancel at any time.
MVHR Design And Install
Gone West replied to Adrock's topic in Mechanical Ventilation with Heat Recovery (MVHR)
To DIY MVHR is an option for self builders if they are willing to spend the time doing the research and planning. I designed, installed, commissioned and produced the required documentation for our system. The BCO wasn't that interested to be honest, although it was nine years ago and I suspect things have now changed. I would challenge the BCO on what qualifications are needed to commission a system. -
I have TP Link Deco M4 units in the house and I've bought a Deco X50 outdoor unit for the garden.
Or, I'm told, the omnibus on Sunday is good.
I've bought an outdoor unit to add to my mesh network, as the signal is weak in the garden. Wendy likes to listen to BBC Sounds stories while gardening.
Grandkids these days, I wouldn't be suprised if it isn't Great Grandkids in the next year or two.
I've set up CloudFlare and everything appears to be working as it should. Many thanks for the suggestion.
So on my phone I have turned off auto DNS and in doing so my WiFi calling now works but I have removed a level of security. If I do as @SteamyTea has and use a private DNS such as CloudFlare then the security is improved but will my WiFi calling still work? I guess I can try it and see!!
Yes I have tried that without any success.
So I just changed the phone DNS from automatic to off. The calling and text services now appear to be working. Do you know if there are any security issues with the changes I have made?
Another update. Since installing Starlink we have an intermittent problem with WiFi calling. We are out in the sticks with no mobile signal and rely on using broadband for phone calls. I have searched t'internet and it seems to be a known problem to do with IP addresses but without a definite solution. Has anyone else here experienced similar problems or even better, found a solution?
