Everything posted by vfrdave
I have cemfloor floor screed with ufh, it doesn't appear to give off much dust. We are hoping to move in shortly with lots of uncovered floor and I don't want extra dust. What can I seal the floor with that won't be detrimental to future tiling or wooden flooring being laid? I have been told to avoid the traditional PVA as it will crack and peel off with ufh, not sure if this is true. Thanks in advance, can't actually believe I have just typed the words "move in shortly"
Looks well @nod credit to you both.
tinfoil wrap your existing cable where possible and see if that eliminates the issue Capacitor Guide:- http://www.capacitorguide.com/coupling-and-decoupling/
This is my plan, how easy are they to notch a hole in and what is best way of doing it? They strike me as quite brittle.
- 14 replies
I would need to rig something up temporary, although there is ballovalves in the kitchen I could open into a 5 gallon drum. The system probably has some air needs purged also. There is no garage on the multibloc though I think one can be added to it easily. I'm probably concerned too soon before the system is purged etc though there is auto vent thingies.
- 7 replies
- thermal store
- pressure
Sounds like I'm in a not to dissimilar position to @Shell820810 just don't know if she got sorted. Our setups are very similar as well. https://forum.buildhub.org.uk/topic/1107-no-pressure-in-pressurised-system/page/2/?tab=comments#comment-14279
- 7 replies
- thermal store
- pressure
I don't believe so as they quote different flow rates based on pressure received up to 5 bar in their document. The cold and hot are balanced and reduced to 3 bar for the thermal store. The shower is the only outlet I have currently just seems to reduce in flow heavily when you turn the mixer round for hot water. Lowest temp setting isn't wonderful either.
- 7 replies
- thermal store
- pressure
I have my thermal store in although not heated yet. First shower is in and I am a little concerned that the pressure/flow is low and it drops noticeably when you are looking for hot water (even though it isn't hot yet). Water is a balanced supply through a thermal store for hot and balanced off a multibloc pressure reducing and relief valve for the cold. Pressure at mains outside is 4-6 bar and flow somewhere around 40l/min. Can't keep the water in the bucket when running full bore at the start Haven't had a chance to chat with plumber yet as it is the holidays in NI but feels like the water system is strangled when it is within the house. Anyone got any pointers for me.
- 7 replies
- thermal store
- pressure
Required warranties and insurances
vfrdave replied to Conor's topic in New House & Structural Warranties
You either need a warranty from the likes of nhbc if going down the contractor route, or an architect/engineer to sign off at stage releases and signoff. -
Never thought of it like that. I have stat pockets at third and two thirds down.
I eventually ordered my thermal store from Trevor @ cylinders2go. Super pleased and we'll impressed confirmed order Monday received thermal store today in Northern Ireland. Thanks for the recommendation @Nickfromwales One query the aquastat supplied only goes to 65 degrees, surely I will need one that goes higher for a thermal store? Can anyone point me in the right direction, any I have looked at are 65 max.
I'm going to highjack this a little. I couldn't find any regs in NI governing handle heights etc for new builds. The wife wants these doors which will only look right with the handles higher up.
Stage 1 Is Very Nearly Complete :)
vfrdave replied to Construction Channel's topic in General Self Build & DIY Discussion
Congratulations Proper grand designs getting her pregnant. -
I got caught with the same. Earthing was then a bollocks, 3 spikes later to get a good enough reading.
- 367 replies
- ireland
- timber frame
Even if the kiosk is in its final position they still will classify it as a temp or builders connection until the house is 2nd fixed. Mine is in final position but with a temp commando socket etc for builders connection. They also get caught up on location of these as they like them towards or on front of house for access to meter readers. Mine is round the back but they moaned alot to me.
Try phoning this number with the serial number handy 0800 0516363. Guy I work with returned something by calling this number and had a replacement sent to him.
Anyone any idea how to clean splats of concrete off a plaster skimmed wall.
Anyone used an electric stair climber?
vfrdave replied to Jeremy Harris's topic in Tools & Equipment
@JSHarris I have used one of these in the last few weeks to shift a few fairly heavy comms racks (non-standard) up several flights of stairs. I have to say I was a little dubious of it but it worked really well and was fairly easy to use once carrying the load on its wheels. -
So the quarry has come back to me with a few options. - Do nothing and get a partial discount. - overlay it with some ardex product (no data sheet provided as yet) They ruled out grinding it smooth as suggested by @JSHarris stating it would be cheaper to dig it out and do it again, at which point I suggested that has to be considered.
Thanks for the responses at least we are all agreed that it is a poor job. What would you expect the supplier to do? @JSHarris has suggested grinding smooth, I assume much like they do with polished concrete but not to the same degree. Any other options?
Thanks might try a replacement washer from there first.
Anyone know where I can get a 16 spline cartridge? Or can I get a 20 and do a mix and match with the old one to suit. Existing one working much better but now not sealing off fully leaving a constant dribble of hot water.
So just another update, this has still been an issue and we are persevering with it. Tonight I stripped the tap and the rubber stopper on the end of the cartridge isn't in great shape. Put it back together and tap working alot better but reckon the cartridge rubber washer thing, what's it called, needs replacing.
Concrete was in yesterday and levelled by shortly after 9. Power float was in the van and up the road just after 1730. I thought it was too early and he would have been there to 1900 at least. Question now is what do we do with it, or what do we get the quarry to do with it.
