Onoff
    206
Everything posted by Onoff
  1. Aerated, hollow, medium density etc?
  2. What are the blocks?
  3. Well that didn't last long! Controller is playing silly buggers again. This despite the new cap. Might try the battery if I can find what voltage it is.
  4. Skipping through your comments...30 tubes on a presumably clear winters day will feed a 300L then with a useful amount of heat? What about overcast days? I've heard you still get heat input with ST.
  5. Boy are you in for some questions when I do mine!
  6. I THINK the rules might be stricter if AONB, area of special scientific interest etc. https://www.planningportal.co.uk/wales_en/info/3/common_projects/34/outbuildings
  7. My experience of ST panels here is that could perhaps get too hot to feed some pcms and that you could cook them without some sort of temperature limiting and heat dump.
  8. I wonder if like me you'll be wishing you'd knocked it down and rebuilt from scratch! Oh, and welcome!
  9. I used to come across "light agg" on roofs around 30 years ago. At least that's how it was pronounced. Really thick, laid to falls on top of structural concrete and good in compression. Dead easy to dig through though. This was before "blue board" insulation so I assume it had inherent insulation properties.
  10. How a out something like this? https://www.ebay.co.uk/itm/FLORABEST-2-IN-1-CORDLESS-GRASS-Hedge-TRIMMER-LI-lON-TECHNOLOGY-3-6-V/223455384449? Had something similar in Lidl today but I didn't look too close.
  11. Cut a sliver of board on thd table saw and glue it in if that fussed.
  12. If you're not having UFH in the base slab why the perimeter strip of insulation? Not like it's going to heat up and expand....
  13. Try the cheapo S'fix spray adhesive if the foam won't have it. Try on a small area first. Looks like perimeter strip is it?
  14. You deserve a night on the tiles for that effort...
  15. Rubi Practic 60 here. Not all that impressed.
  16. You could still have a sill on some ornate brackets?
  17. Yeah, but it's probably the only correct one!
  18. Um...so is it the right one? https://www.ebay.co.uk/itm/Thermostat-077B2289-Danfoss-Gorenje-631237/222525840210?epid=1766688363&hash=item33cf92db52:g:iL0AAOSwK6RZKVh9 @recoveringacademic, have ein look for me would you pls? I want a 007B2228 part number 631237. I THINK this part from Germany equates. Cheers
  19. Are these specs for the stat OK for the freezer? Temperaturen: kalt aus: -30,0° C kalt ein: -23,0° C warm aus: -23,0° C warm ein: -17,0° C
  20. Not necessarily. If both 30mA then it's likely one or the other might go if selection (formerly discrimination) rules haven't been considered.
  21. I wet cut my diagonals. Tbh bloody amazed how well they came out. Abandoned the Rubi scribe 'n snap one tbh in favour for the wet cutter for everything.
