Everything posted by Onoff
I won't take anything out then in that case, build the platform round the diagonals but not touching.
Moving on... To keep the new platform from bearing on the existing roof structure, I thought to maybe add a couple of extra beams parallel to the binders sat in joist hangers sat in the stacks/wall. Then fit cross beams between them. (All shown in yellow). Then I thought maybe to bolt angles (yellow) to the opposing walls and run new beams (again yellow, only two shown) perpendicular to the existing ceiling rafters: I'll likely go with the second option but rather than fit angles (heavy and cost), fit a timber, then joist hangers on that. Someone elsewhere did suggest doing away with the angle or timber and fitting these directly to the end walls / stacks: Not sure of my ability though to put these direct onto the brick/block (possibly loose) wall keeping them all dead level and not hit a mortar joint etc. They also suggested using these to do it, which I've never used before: Hence my favoured idea is a timber on the wall first with bolts into the wall to miss the hangers that get nailed to the timber. Then to aim for this sort of structure adding timbers at the apex and new webs outside the platform area so I can get rid of the existing ones:
Just look for one with "manual override" e.g: https://www.alertelectrical.com/ovia-lighting-recessed-360-low-profile-flush-pir-with-manual-override-ovpir009wh.html They're all going to be much the same, the ceiling mount ones. Tbh Steinel is the brand for all things PIR imho. If you can accept fugly then maybe something like this? https://www.lights.co.uk/steinel-ir-180-up-easy-motion-detector-switch.html? Shop around on price, links picked at random.
Turncoat! How long before you can join the Cornish Republican Army? Aka the "Ooh R A" ?
What fittings do I need to connect to my shower mixer and heads?
Onoff replied to Conor's topic in General Plumbing
See page 46 of my mega thread and what @Nickfromwales said on Jan 14: -
Get him to fill up lots of 25L containers so you can easily count and gauge the amount delivered...
Yes, they'll take 15mm copper too but be sure the ends are clean and no burrs. With plastic pipe you need inserts. -
I used compression fittings: I did 20 turns of tape and a smear of goop (Jet Blue Plus) on top of the tape. That's the 1/2" male into the valve. On the 15mm compression I did just a smear of goop around the seat in the brass (with the pipe in) but before the olive sits down. Then seat the olive, then more goop after round the outside of that. Pays to put your tape on the right way! -
Those fittings are 1/2" BSP. Does this help -
Cheapest way to build an extension
Onoff replied to Danielle007's topic in House Extensions & Conservatories
Pallets! ? -
Why not hide it behind a hinged painting or something?
Disabled access ramp.
Onoff replied to Russell griffiths's topic in General Self Build & DIY Discussion
Have a look in Part K, there's ramp drawings there and it makes mention of Part M. -
Decant into a plastic Lucozade bottle.
Pre Brexit it was cheaper to bulk buy screws from here even taking into account the delivery. https://www.klokow-gmbh.de/en/
I think I have the diagram at work, maybe in an earlier Part M? Won't be able to look until Monday. I had to make a removable wheelchair ramp a while back to keep the fire office happy. All TIG'd ali to suit the asphalted, laid to falls, floor. -
My upstairs 18mm, t&g floor was "screwed" up with PVA and angular ring nails and squeaked like a barsteward. It's a lot better since I put a load of proper, Spax flooring screws in.
...thought I was in another similar house.
? I'm a twat. I got disorientated in the loft. I was 180deg out. They're my stacks!
That is the plan but I won't be able to get there now until the new year.
Don't know. I measured 3100mm wall to wall, think somewhere I have the room measurements I've suddenly remembered. As an aside, not tempting fate but there's plenty of instances in this type of house where the stacks have been removed downstairs but left in the loft still. Scary!
My stacks are the loft hatch side. Almost as if that Celcon wall has been built too far to the left where I've shown the dotted lines. T = top landing below my loft hatch: I'll have to have a measure up! It's not as far fetched as it sound if the previous owners of my place wanted to gain a crafty foot of loft space. Next store is a derelict shop, has been for umpteen years. Can't imagine the loft was ever used. Bear in mind all these lofts were connected when originally built in the 1860s. The first one of these I bought years back, a kindly neighbour ran an extension lead from his place to mine via the loft hatches!
