Everything posted by Onoff
Wall hung WC with horizontal outlet - possible?
Onoff replied to JIH's topic in Bathrooms, Ensuites & Wetrooms
Pretty much what I have: The black into grey is push fit: The grey straight to grey bend, grey bend to grey bend then grey bend to brown straight joints are solvent weld. I made the mistake of using brown, "underground" pipe instead of grey . Although all pvc the brown is a bit more "rubbery". I used gap filling pvc cement there and even then went over the top with a smear of something. If using push fit always have the male above the female fitting on the slope. -
You need to try new things even if destined to failure. You've always been rigid and unable to move fluidly... ?
Because these flints are quite thin as in not fist size "blocks". Many are basically conical. They've been selected for their feature face rather than suitability for a "wall". Just don't think I'll have the "sticktion" with straight mortar. Hence trying to find something super sticky. Flints are notorious for being impermeable. If you use a cement based mortar it will shrik away from the flint leaving it "rattling" around in there. Water gets in the gap between flint and mortar, freezes, blows and the flint falls out. A lime based mortar retains flexiblity which is why it's traditionally used. I'm using a part lime mortar mix with modern admix. Once in I'm going to overpaint the whole lot with some sort of a sealer. Hopefully that'll creep into any gaps and aid them staying there. Where no man has gone before etc!
Clear silicone (not cloudy)
Onoff replied to SuperJohnG's topic in General Self Build & DIY Discussion
Geocel Pro Flex Soudal Transpacryl. Everbuild Crystal Clear DL Chemicals Paracryl Some go on "cloudy" then cure transparent. -
Bought a cheap Aldi 50". Sound was crap. Had an old PC speaker system: & some plastic primer / black satin: Should have gone matt black. Made a new top for the old telly stand: Sounds better than it did.
Looking for internal dimensions of Wago wiring center (L32 L60)
Onoff replied to joth's topic in Electrics - Other
You can get a strain relief plate 222-505 which has holes in to screw down: https://www.wago.com/gb/installation-terminal-blocks-and-connectors/strain-relief-plate/p/222-505 To which you clip mounting carriers: Good old chunky 222 connectors in a 222-500 carrier: Or the newer 221s in a 221-500 carrier, so the same plate fits both: You can see with the 221s you can flick the lever still/access the wire. With the 222 you have to faff and slide them all out potentially to get to just one. Which is why I designed my grey 3D printed ones. Now if I had some orange filament...and it was fire retardant...? Tbh I find navigating the Wago website and part numbers only slightly less confusing than Geberit! -
I think you're taking the pi$$? ?
All I got from that was cars & babes, does it for me. Like this too:
Ducts for wires through external insulated walls?
Onoff replied to Dreadnaught's topic in Timber Frame
Better than ordinary "mastics": https://www.tlc-direct.co.uk/Products/WKONEGEL.html? -
That was done to take a 3+2+3+5. Could do you whatever combination pretty much at the drop of a hat. What about a mounting tag etc? Always interested in a hand job... ? -
Use a standard enclosure and some printed holders? I could graft a DIN rail clip onto the model easy enough. -
Can't you just put Bluetooth speakers in (the ceiling) and control the Alexa via the phone, telling it to output to the Bluetooth? That's what my kids do. These similar to mine: https://www.ebay.co.uk/itm/284239807434?hash=item422e0343ca:g:RO4AAOSwSuVhzqzC
Generally seems to have dried ok. If the resin sticks to the flints like it does my hands I'll be well happy. The odd lighter coloured blob (though not all of them) is still wet, uncured DeWalt resin from the tail end of the tube, when it was just resin coming out with no hardener. Maybe as it was a bit out of date? I'll live with it as the tube was a freebie! Resin is horrible to use from a normal gun imho. Much prefer the Fischer, space shuttle esque resin tubes. My daughter couldn't squeeze the DeWalt stuff in the standard gun. With the Fischer gun it's a doddle. The "towers" are a concern as in where the distance from mesh to flint is such I've had to build up the resin in height to bridge the gap. Now to try and "hang" one without everything falling off! Edit: Must get laddo to print up some pads for the clamps so they sit over the "+" of the mesh and don't slip off.
OMG! Ran out of the "proper", need a special applicator gun, Fischer resin and had to use a tube of DeWalt stuff that fits in a standard mastic gun. (Got it free as slightly out of date). It stinks to high heaven! No hiding I'm doing this in the kitchen.
Tears as in rips? She had your number! ?
Said like a true believer. What I lack in cash I make up for in faff.
Something like this: Then rope in No.2 daughter and let loose with the resin gun: ...whilst I watch Hidden Figures with a glass of Wainwright The Golden Beer! Hopefully the resin will stick like the proverbial to the flints and mesh. I'll then be able to lift the whole thing into place like a mosaic tile mat and hang from some resin studs.
Won't a ledge have sitting water on it? How about sloping the ledge bit and "decorating" with hanging, fake plants?
Quite like that idea but I'd use something a little more durable than Perspex. Pity you can't get some walk on glazing and use that.
10 Year Rule and immunity under the 4 year rule.
Onoff replied to ToughButterCup's topic in Planning Permission
Just waiting for my half pack of Celcon blocks then I can get the walls up. Still waiting on the Pozi joists so I can make best use of the high ceiling space. -
Fair enough & to think I have my 18th ? Why am I thinking 500mm? -
Next time someone wants to stick a flint to something they'll be thanking me for this! ?
Erm...500mm
