Everything posted by joe90
It’s an old cottage, that’s what they looked like. I remember my first attempt at bricklaying, renovating an old cottage and I was less than pleased with what I did, not as straight etc as I wanted to do but my BCO said if it was dead straight it would stand out like a sore thumb on the old “character full cottage”. Very often working on old properties is a compromise.
I have some slate cutters, older version of what’s posted above and they work well. I have cut slates in the past with a large trowel on edge using a chopping motion, works well but takes time. Angle grinders will leave an un natural “cut” edge and not look good (IMO). mine is like this https://www.ebay.co.uk/itm/Tubela-Tile-slate-Cutters/294080302729?hash=item44788d4e89:g:6IQAAOSwSqRgWctV but found this https://www.ebay.co.uk/itm/32cm-Slate-Cutter-for-roof-tiles-Slate-Spring-loaded-handle-rubber-grips/114764930971?hash=item1ab885df9b:g:6KMAAOSwgZJf-zuR
@zoothorn good job that, if the paint/lime won’t budge don’t fret, just paint it again and it will match the cottage outside.
Bankrupt sub contractor - gut says no
joe90 replied to Moonshine's topic in Project & Site Management
Be honest and offer him cash on a daily/weekly basis, he may prefer it that way. -
I have never seen discarded bottles on sites. They are swapped for full ones (with payment) ?♂️
My block paving patio was laid on ground granite chips (about 3 or4 mm) on top of well compacted road scalping which my builder says is less likely to settle out than sand but sand was swept into the gaps.
https://www.ebay.co.uk/itm/NEW-BIRCH-PLY-VICE-JAWS-TOP-FOR-BLACK-DECKER-WORKMATE-WM550-Spare-parts/114768076889?hash=item1ab8b5e059:g:czkAAOSwEK9TuYfN I am sure you could make your own, perhaps I could start a business (on seconds thoughts I have enough to do.......)
https://www.ebay.co.uk/itm/Habilis-Work-Bench-Wooden-Portable-Handmade-Workmate-Eucalyptus-18mm-Ply-Top/324259442619?hash=item4b7f5e6fbb:g:T44AAOSwXzBfNACa
Yes but have you read the reviews, rubbish ?♂️.
+1, my original one broke so threw it away, the newer one (plastic handles and pressed steel) is not as good but still has done sterling service for many years. It’s not like me to renew, I usually mend old stuff ?♂️ ha, just looked on Ebay and loads there to choose from BUT the old ones are now collectible!!,!, who would have thought.... https://www.ebay.co.uk/itm/Used-Vintage-Black-and-Decker-Folding-Metal-Workmate-Bench-Free-UK-Post/203272143081 ?
I have a black and decker workmate that I have had fir donkeys years and found invaluable, dual height, large jaws ?
98% sunlight reflecting paint
joe90 replied to Ferdinand's topic in General Self Build & DIY Discussion
That’s because so much energy is used to run air con units in hot parts of the country (I guess) what we need is a white paint for hot weather that turns black when it gets cold ?. -
I always brush a little water on the surface with a paint brush or little garden sprayer.
????, thats so funny, the only thing the council may pick up on is “fitting in with the local vernacular” and this is totally dependant on the planners personal opinion relative to your area. Let us know how you get on (we have lots of knowledge here about planning refusals and even going to appeal!!!!).?
Complaints are not necessarily proper planning objections, “I don’t like it” is not a relevant planning objection. Can you list the objections for us?
Maybe a bit late but I bought my stove from “stovesonline “ and they have an in-house flue designer who was very helpfull for my installation.
Yes, chipped surface is better so don’t go wire brushing (and coughing all day). The wall has to be damp and the mix fairly sloppy, try mixing a little at a time to get the mixture right. Make sure the new Mortor is mixed well, try to get air into it. If the wall is damp the action of it drying out pulls the new Mortor in so gives adhesion.
Right, see if you can scratch the first coat with a pointy old screwdriver or something to give a key (this is why it’s often called a scratch coat!). I much prefer SBR to PVA, give the first coat a brush with it, let it dry then give a second brush and apply the final coat before the SBR is completely dry. I have even heard of adding a little SBR to the water when mixing the Mortor. Dry brush the final Mortor coat with a brush before it’s hard but still damp to give a good finish.
Architect has done a wonderful scheme but-
joe90 replied to DragsterDriver's topic in Surveyors & Architects
I second this, as I have said before when I worked as a small time builder my quotes were very detailed, no ambiguity about what I was required to do, lots of communication. Most builder/customer problems I came across were because assumptions were made and not enough detail talked through. -
I admit I am generally not a fan of architects, come across too many problems with designs in the past. I did use an architect for my self build but only to convert my drawings (proper drawing board jobbies) into CAD as I can’t do that, he got so many things wrong several times but at least he didn’t try to charge extra (he recognised I was not impressed ?). -
Conservation Area Glazing Bars on Velux Triple Glazed
joe90 replied to ashthekid's topic in Windows & Glazing
Just ask the BCO! I still say a stick on glazing bar (if the BCO insists on them) perhaps a drop of CT1 each end rather than screws (if Velux says it invalidates their warranty). Thing is, no one will get that close to notice. -
Do I need a tv aerial
joe90 replied to Russell griffiths's topic in Networks, AV, Security & Automation
Never heard that before, with this digital age is that not out of date (if true?). -
Bpc upgrades - would you recommend?
joe90 replied to eandg's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I don’t have any but some here do, for example one in the kitchen will enable you to select boost in case of burnt toast!!! Or one in the bathroom when having a shower instead of waiting fir the humidistat to kick in (if you have one). -
Yes I am a Luddite too, I put my aerial in the loft but don’t have foil backed insulation and it works well. Depends on the signal strength where you are I guess. I keep seeing adverts for television series on various “other” channels so one day I will have to join the 21st century. ? -
Major Issues Octopus App
joe90 replied to canalsiderenovation's topic in Energy Efficient & Sustainable Design Concepts
At least they have “found” the problem, just keep checking the meter till the problem is resolved. Ha, smart meter? DUMM METER !!!,
