You will need to remove the whole roof structure and start again tiles off, rafters off, ceiling down ceiling joists down. then you wil need all new rafter done to the correct spec for that span, the rafters either side of the roof windows will need to be doubled up to take the load. it will all need fixing down correctly, as you have removed the ceiling joists which are acting as a support for the roof and to stop it spreading. if you just remove the ceiling joists you will end up with your roof tiles sitting in the kitchen.
Should we put a sink in the island or against the wall?
Russell griffiths replied to CalvinHobbes's topic in General Plumbing
We have built what is called a butlers pantry its a separate room beside the kitchen, it has the biggest sink I could find, it will fit the full width tray from the oven for a soak, it also has the dishwasher in it. so prep and cook in the kitchen and chuck the pans into the pantry to hide because we have an open plan kitchen diner and don’t want to stare at pots and pans while we eat dinner. its a foreign idea normally used in America and Australia. -
We have gone a bit off piste and fitted two sinks. a small nice looking thing for veg chopping and prep, then a dirty big one for washing up. -
Increasing size of sewage treatment plant?
Russell griffiths replied to flanagaj's topic in Waste & Sewerage
Get a camera survey done. -
If turning this garage into a habitable room, just make sure you have a fire escape plan in your head, before you finally commit.
cable through to exterior- conduit required?
Russell griffiths replied to jpadie's topic in Consumer Units, RCDs, MCBOs
Yes. You need to protect it from chafing and also provide air sealing to the hole you just made. -
I think your getting your piling techniques mixed up. he’s talking about vibrated stone columns to build a house on top of.
Unless I’m wrong which I’m happy to be. you won’t get a vibrio rig on your site without knocking the bungalow down, I’ve never seen a small one. you can get small piling rigs to drive a steel driven pile, or a small rig for a bored pile, but all the vibrio ones are huge bits of kit. ask @ToughButterCup I believe to underpin with a steel driven pile they smash it in close to the original foundation and underpin the original with a concrete cap.
The other thing to consider is get planning for a demo and rebuild and sell it, go and buy another rough one and do the same until your happy you have the funds to do it yourself. or forget that quote and build one of the extensions, wait a bit and build another then take the roof off and go up. will take 5 years of living in a building site, but by employing smaller builders you could probably split the financing up a bit. sell it, all the while keeping your eye out for another cheap one in the same area.
Talk to an estate agent and find out how much all those neighbours houses are worth, then show him the pics of your ideas, try to get a feel for the finished value. then go from there.
You have your answer. you beat a developer in buying it, what do you think he wanted it for. it looks like the cheap house on the block. you always aim to buy the cheapest house in the best street, then turn it into the best house on the street. The big problem is getting the finance.
Having just flicked through your previous thread the one with the picture of your bungalow in it. that is definitely a plot in a nice street, if you put that up for sale somebody will grab that and flatten it. do you have room at the back to push a new house backwards in line with next door. show us a pic of the street view, the bungalow definitely looks like the poor brother to the house next door. knock down and rebuild looking at your design could be anything upwards of 650,000- 800,000. what would it be worth.
Best smart doorbell?
Russell griffiths replied to ashthekid's topic in Networks, AV, Security & Automation
I have 4 wi fi points in the house. but we also have 2 external points under the soffit, should be good for 50m radius around the house. -
Large shower tray spanning UFH
Russell griffiths replied to Kelvin's topic in Bathrooms, Ensuites & Wetrooms
Handy for when I do my legs. -
If you have loft access which I believe you might, you can put a data cable up there going out of the facia board to a TP link external device. we are able to pick up the house wi fi from a great distance across the garden, well beyond 30m, but not measured it. -
Can you run it on the surface or in the ceiling joists it all depends where your outside unit is going and your tank inside mines all surface mounted, but it runs through a garage and outside.
As far as I’m aware in a mains fed hot water tank this problem doesn’t exist.
What air in pipes. does your house now not have pipes in the loft. the bungalow I live in now certainly has pipes that go from a cylinder up into the loft and then down to a bedroom
Presence detection
Russell griffiths replied to Pocster's topic in Networks, AV, Security & Automation
I have absolutely no idea what you are talking about. -
Keeping cavities clear.
Russell griffiths replied to syne's topic in House Extensions & Conservatories
Lay a batten on the last row of wall ties you installed and lift it out to clean off any droppings. if you put a cavity closer in you will need to put in a cavity tray above it to shed moisture to the outside, this could create a weak joint all around the building. -
Really this is all a bit pointless without knowing what it’s to be used for. it may well be better to put it up on 4 ground screws with a timber floor with insulation between the floor joists.
@sam I’m not keen on your walls being so low in the ground, I would put both layers of insulation inline on top of each other so the outer edge is flush, then fit the sole plate on top of both layers. I would look at a denser insulation for the perimeter maybe xps300 or eps 300. I would stagger all the joins in the insulation and glue it all together to form one big slab. I would also glue the chipboard flooring down so it all acts like one big chipboard insulation sandwich, sort of. your bigger problem will be stopping it blowing away. 1m long threaded rod buried in the ground below your drainage layer, coming up through your sole plate could fix this. what do you want to do in there as 4m square is rather small. and the cost per m will be extremely high, it won’t cost much more to make it a bit bigger.
This weeks Short Read: Population
Russell griffiths replied to SteamyTea's topic in Environmental Building Politics
Didn’t we have something that could have thinned down the aging population ?
