Absolutely horrible, they are on show at the Swindon self build centre, I have been twice in the last month to just look at windows. Dismissed them straight away. Went to rationel on Friday, very nice for the budget, middle of the road price range.
Lead trays for windows & doors in a timber frame?
Russell griffiths replied to Nick1c's topic in Windows & Glazing
You should really have a tray, or cill pan below all windows and doors IMHO but I think there are better materials than lead, unless he wants you to weld all the corners you will get water penetration at the corners. You can buy specific tapes that stretch for forming the corners with no cutting, so no weak junction areas. You can also get a liquid flashing, this is what I will be using. Go to you tube to look for some horror stories of badly fitted windows. -
Corrugated Roofing Guttering
Russell griffiths replied to canalsiderenovation's topic in Roofing, Tiling & Slating
What are you having as a facia, as it’s a bit of a vicious circle, plastic gutter will look like plastic, but putting metal gutter on plastic facia may look odd. I personaly hate plastic. Have just got a load from gutter crest, will see what it looks like on Wednesday if it turns up. -
Duct hole through cavity wall - shape/size?
Russell griffiths replied to andyscotland's topic in General Structural Issues
Won’t have any effect, make it any shape you want. How will you fit a square airbrick in a round hole ?? -
Should I buy this autofeed screwdriver for plasterboard?
Russell griffiths replied to Roz's topic in Tools & Equipment
Not if the resale price is good, how long do you want it ? -
Why is this plaster peeling?
Russell griffiths replied to H F's topic in General Construction Issues
It’s because you have a cold bridge between outside and inside window reveals are notorious for this as the actual cross section between cold and watrm is so thin. -
I wanted to avoid GRP if I could, I did my old kitchen roof in it and it worked brilliantly and is very robust, however it is very weather dependent and also time restricted, I was running about like a blue arse fly keeping it all together at the same time. So so looking for a product that is not so finicky.
Damp penetrating from the outside via the reveal, probably a solid wall. -
Can anybody recommend a liquid applied roofing membrane, the type that you add a mesh or a matting to for strength. I would like something that you sort of roller apply, then lay matting to and then roller again. This is for a porch roof with very minimal fall, outside the house so cold roof, substrate either ply or osb. Cheers russ.
Batten, cement board and render is certainly a way to do it, but I wouldn’t want it. Cavity, concrete blocks, render has anybody done a price comparison?? those cement boards are not cheap, then the fixings are not cheap, then the bagged render is not cheap concrete blocks are not that expensive to have laid and is a far more robust detail IMHO.
If he has strip foundations, he won’t need a raft. There could be some confusion here with terminology.
How can you use the icf walls to retain the slab ?? what are the icf blocks sitting on??
Balancing Weather, Comfort and Laziness
Russell griffiths replied to puntloos's topic in Landscaping, Decking & Patios
1/2 bottle of jack Daniels and I don’t care where I sit. -
High density insulation
Russell griffiths replied to Russell griffiths's topic in Building Materials
@JSHarris I have been doing the, how much does the builder squash the eps when he stands on it test today, all 70kg of me barely puts a dent in it. I have been thinking of making a cill pan to go under my windows for extra weather protection and I think this combined with all the side fixings and the strength of the eps itself will be plenty, I think I will be leaving it alone. -
You are nearly as inventive as me @scottishjohn but not there yet keep trying. Going to cut out 90mm diameter holes in the eps, then fit a 90mm fibreglass tube, then replace the bit I cut out into the centre of the tube. So in effect I will have little fibreglass load cells every 300mm along length of window. -
Board on board vertical cladding detail
Russell griffiths replied to jamieled's topic in Timber Frame
My neighbours workshop is Douglas Fir, it looks very good and was a good price also. -
I suppose it depends how rustic you want it to look, my neighbour has just built a huge 500m workshop all clad board on board, it looks very good but it does have a rustic character to it, it would never go with what we have in mind, but probably cost him a quarter of what ours will. I think it really depends on the LOOK you are after. -
Buy the 18 volt dewalt and I will have it off you in 4-5 months time. ? -
Hi, 90% of the windows we are looking at are Ali clad timber, is it possible to get an all aluminium window that comes near the spec of timber Ali clad or is this just snake oil marketing. Ta very much.
You really are top shelf @JSHarris a proper legend. ????
The Design
Russell griffiths commented on Red Kite's blog entry in Self Building two in North Wiltshire
I do hope you will have time to make more of that excellent marmalade. -
Frame width is 4200mm @JSHarris i was going to do the sums to tonight, and ask the window company on Friday.
@Adam2 I plan to support my doors on marmox blocks, I would not even consider using wood under your doors. I was just a bit concerned when a window quote came in and it included weight of the windows, I have 2 that are around 400kg a piece.
They will be attached to straps, but I cannot see how a strap attached at 90 degrees to the load stops the load going downwards, yes the straps hold the windows in place, but a couple of hundred kilos of glass must need support from underneath ???? meeting with a couple of window suppliers this week, I will ask them.
Thanks all.
