BotusBuild
Everything posted by BotusBuild
We are now in the position of having an Architectural Engineer who my wife thinks I'll get on with ? and so we have asked them to provide their services. They are different from the Architects who worked with our land vendor to get the FPP that exists. We are seeking to get hold of the editable drawings from the original Architects for which they want a large sum of money. So, I want to make sure that we get every last thing from them that will help the Architectural Engineer to make the changes to the plans that we would like to get through the planners. What information - drawings, surveys etc. should I be asking for the original Architect to supply in exchange for the large sum of money? The AE is going to provide a list as well, before anyone asks. Thanks Stuart
If it is a new and self build, you can apply for an exemption. The timing of all this is critical - read all the guidance on the appropriate council website (Mid Devon). Now, because you have a Class Q, but now want to demolish (?) and build something in its place, it may not count as "new". Again, check the website, the guidance and it may even help to call them and speak with someone.
Help - can this door handle be converted? Pics included
BotusBuild replied to Roz's topic in Doors & Door Frames
When you remove the stop plate, replace it with a washer (or something similar) that is of equal thickness to the stop plate. It'll stop the handle "slopping about" (technical term ? ) BTW: Can you actually continue to use that handle as it appears to have an end date in the past? ? -
Statutory mains pressure should be around 1 Bar (enough to raise water to a height of 10m). "As a guide, if you have a suitable single service pipe, the first tap in the home (this is usually the kitchen tap) should be able to fill a 4.5 litre (one gallon) bucket in 30 seconds, with all other taps and appliances turned off." - from Watersage.org.uk Mains pressure in a closed system will reveal leaks. For higher pressure, yes, either a compressor or I have seen an adapter created by a plumber that allowed an air pressure test with a car foot pump. Note: another recommendation is to fill the pipes with water before you pour the concrete to stop them being compressed by the concrete.
Q: Why do you think you that conduit? Is space tight? You think it will look neater? My experience is that the actual UFH pipe is reasonably flexible and if where it comes out of the floor and is connected to the manifold (direct connections are highly recommended) it is hidden away or boxed in then the "look" is not so important. Q: To protect the UFH pipe? I would recommend having different loops of UFH in different section of solid floor I strongly recommend pressure testing the pipes before you pour. If there is a problem once the concrete is set off, then you are in a whole load of misery to find and fix the leak. Connect the loops to the manifold, open all the valves, fill with water and leave for an hour or two. Fix any leaks, try again. Rinse and repeat (pun intended) Yes. Just be careful See answer regarding expansion joints.
Fitted a new kitchen just over 11 years ago. Borrowed a router and worktop jig - tested on some offcut to learn the process, then cut what I have been told are two very fine joints. So yes, you can DIY. Just be confident in your abilities, but do practice before. Oh, and use the correct tools.
Should I plane my own Cladding/decking ?
BotusBuild replied to Tin Soldier's topic in General Joinery
How much time have you got on your hands? How much is your time worth? In other words, can you earn more doing your job than it will cost to get someone else to do it for you? If you are a control freak, or have OCD, then doing it yourself may outweigh the earn vs. cost equation of course ? Personally, I love a good new power tool and would just not consider the equation at all ? -
Finishing tile edge around window reveal?
BotusBuild replied to 8ball's topic in Floor Tiles & Tiling
There is also a plastic (aarrrgghhh - run for the hills) version that you could use. But yes, something like that. Or, do the tiles you intend to use have a finished edge or option tiles for finishing the edge? -
VAT rise on PV systems coming
BotusBuild replied to MikeSharp01's topic in General Self Build & DIY Discussion
and of course there is always the article that says "The government also hopes to encourage homes with solar panels to install batteries." in the very same publication, two weeks prior ? https://www.theguardian.com/environment/2019/jun/09/energy-firms-buy-electricity-from-household-rooftop-solar-panels But I do note from the 24 June article if I install after 1 Jan 2020 (highly likely!) then I get to benefit from being paid for feeding into the grid. Again. Just bl00dy perverse - what happens for those who install between April 1 and Dec 31 this year? No wonder there has been a massive fall in installations. -
Heat recovery efficiency
BotusBuild replied to lizzie's topic in Mechanical Ventilation with Heat Recovery (MVHR)
What you experience @lizzie is fairly normal. Have the woofer (and maybe yourself) run around the house for 10-20 minutes to create some extra heat. Or throw a party ? -
You'll definitely need to know what category it is currently, so press on with finding that out. Next step will depend on that category - some changes of use are allowed under Permitted Development Rights, but always check with the LPA, don't take anyone else's word. So keep on with those phone calls ? And, irrespective of the current category, if you're going to make physical changes to the property, it is almost certain you will need a planning application anyway. Good luck
+1
This says to me "be patient, and let things run their natural course".
Toppers, I would say yes you will need a manifold. The main reason is that as you are connecting to a conventional (dare I say legacy ?) heating system that is delivering hot water at high temperature (60C++), the manifold needs to have some way of bring that temperature down fo use in the UFH pipework which is usually designed to work at flow temperatures of around 35-45C. This is achieved by mixing the return flow from the UFH pipe with the incoming flow from the boiler and the mixer valve that does that work is usually incorporated in the manifold.
opinions on this workmanship please
BotusBuild replied to lizzie's topic in Bathrooms, Ensuites & Wetrooms
I think that should read "we deserve to get better" as ultimately its our council taxes that are paying for this rubbish. Personally, I would be embarrassed doing something like that, particularly considering the person it is being done for. -
Thanks @SteamyTea. I've made contact
Welcome - hope you get the advice your need Best to post it in the relevant section - I think that is good etiquette
Peter - I was talking about the silicone, not the sanitary ware, answering the OP question (I should have quoted) ?
To answer OP question "I have not purchased any acetic silicone and so was looking for recommendations on what brand to buy?" ... I've done a bathroom (our current house) and the mother-in-law's cloakroom (finished a couple of weeks ago). I used a mixture of B&Q's own brand and some other branded stuff that I had left over. There is not really much difference between them as long as you think that "white is white is white" ? Good Luck with the fit out
Hmm ... after contacting them to arrange a meeting, were then told they could not start work with us until mid-December, so now on the hunt for another architect ?
Polished concrete floor recommendations
BotusBuild replied to Bumble's topic in House Extensions & Conservatories
The people we just bought land off, who have built their own house, polished their concrete floor themselves. I say themselves - I was told the lady of the house did most of it as she handled the polisher in a more gentle manner ? So, consider hiring a polisher and DIY- 9 replies
- polished concrete
- floors
Garage green roofs / wildflowers
BotusBuild replied to Moonshine's topic in New House & Self Build Design
install a manually controlled sprinkler system, or hydroponic type pipes to keep it watered? -
We have sourced a plot of land in Cornwall with FPP plans drawn by ARCO2 of Bodmin. These were drawn up for the vendors of the land, and we are considering using the architects to undertake some amendments and to create our building regs drawings as well. Our question is, has anyone else here used ARCO2 in the past and would care to share their experiences. By all means use private messaging rather than publish your feeling in the forum. Thanks in advance Stuart
They can do either - each tester has their preference. depends whether you like to see the "magic smoke" flowing away from a leak or into it ?
