scottishjohn
    23
  1. anyone local with a digger and a tree shear attachment.?
  2. I dared-- correct me if wrong ,but it looks like a glass wall with a reflective surface on inside which allows solar to come through from outside and heat the "THERMAL MASS" the reflective surface (on the glass) stops it exiting as quick as it came in
  3. could well be right --but if you asking me to work out what I would think was fair 3 men @£300 a day each --insurance for if they break things £300 van mileage etc £70 TOTAL £1270 + abit ==£1500+vat=£1800 you know you should have ASKED for a quote for anything that is quantifiable
  4. thats a non starter then as a commute vehicle in uk weather
  5. yes a city car --cheap and easy to park
  6. and this is the other end of the range in ev cars https://www.uk-car-discount.co.uk/vehicle/70604/renault-twizy-coupe-13kw-expression-6kwh-2dr-auto/technical
  7. thats for sure --that is one of the reasons why the landrover as we know it was killed solid bumpers attached to a solid chassis --no crumple zone and why "roo bars " disappeared on 4 x4 ,s edit _ and why the 2cv was killed --it had no crumple zone --it just all crumpled and squished the driver
  8. connect--not even worth thinking about I am similar situation but my power connection will be close to 30K- even then it don,t makes sense cos i would still need a gen etc and want to live a normnal not hermit life style and i,m getting older If you had a reliable 3kw or more of hydro --then maybe --but you will be replacing batteries every few years -- --so its not a one off spend with no work have pv panels to sell power back if you like --but if you not diy man doubt it will pay back inless then 8-10years
  9. I could to a point could get very messy if they have other life problems ---- not even sure you could write a water tight agreement these days so you could repossess it if it all went wrong in a reasonable time . certainly could not afford to wait 20 years --I might be dead b y then
  10. wouldn,t worry --easy to seal that up in the roof build ,especially if going laid GRP just a 4-6"upstand of GRP round pipe and a hat on it
  11. Is this possible --someone making me offers for one of my ruins, but needs finance
  12. I can honestly say ihave never had a problem swopping dif makes of nuts on diferent make of compression fittings at same size be it 22mm in line srvice valves or angle 22mm -- all seem to be same just never had a reason to find out -- plenty of 3/4bsp to 22mm fiitngs out there if thats what you wanting to do question still stands why do yo need to know --what are you trying to do ?
  13. are you trying to mix bsp +metric? and why do you need to know ?
  14. so tape round all the pipes and extend that down onto the plastic sheeting --having a foam shoulder to sit on will help and you know they are air tight where they penetrate the wall or as @joe90 flex conduit poking through air barrier -filled with foam and then tape to conduit
  15. would it be simpler to use builders foam around all of them to a height which you can trim off where you air tight barrier is going to be --then just tape that to the foam ?
  16. check this out for your waterproofing of basement https://uk.video.search.yahoo.com/search/video?fr=mcafee&p=waterproofing+a+basement+on+icf+west#id=13&vid=532e8dd4b58905f10b550c4bd7514ad2&action=click
  17. I was wanting to say that LOL
  18. A guess on my part the walls will not have a damp course in them and no doubt rubble infill so they will act like a sponge and suck moisture up from ground and if roof is not good ,maybe water going down into walls from there as well
  19. yes but not for PIR
  20. look again you can get 6" long blades https://www.amazon.com/Bosch-T313AW3-3-Piece-Special-Materials/dp/B001J0U1HC
  21. https://www.amazon.com/Bosch-T313AW3-3-Piece-Special-Materials/dp/B001J0U1HC
  22. or maybe you can rent a pro hot knife -to buy they are £2-400 can cut up to 300mm some of them
  23. Iwould make an extrra large base plate for jigsaw --so it keeps it sat right angle to foam -bit of ply fixed to std jigsaw base.
  24. https://www.zoro.co.uk/shop/power-tools/power-tool-spares/replacement-saw-blade-set-200mm-foam-cutters-2607018011-pk-2/p/ZT1219266X
  25. hot knife? or a pupose made foam cutter blade for a reciprocating saw
