scottishjohn
Hmm, what to get on with…?
scottishjohn replied to Dreadnaught's topic in General Construction Issues
1mm =38.7thou --so your rinmgs are just plain worn out --probably due to the esay atrt --zero lundbrication - then add no one has given a crap about chanign the oi lfor 50 years and theres yuor excessive wear ,which will mean low ring pressure on the bore as well basic rrule of thumb is 4thou per inch of bore -more for a highly streesed and hot running turbo motor . it is allways advisable to measure ring gap and file if they are too tight -something alot of people miss or think they are gapped at factory . my guees is new rings in that old bore they will be wider due to bore wear --but not 3mm=120thou If you getting picky then the grooves should not be worn EG about 4thou max wider than ring . I would not clean out piston ring groooves until you try new rings inthem first ,or even the carbon off the top or sides of the piston ,but maybe a new piston is not expensive anyway. you maybe find new piston comes with rings anyway -
yep --its like a drug # it will remove all the oliy buld up around the pistons+ rings ,so they become a loose fit-- that biuld up of carbon and oily reisdue is good on an old engine it makes up for wear -blow that off with the big "knock" you get when it fires up and thats where your comp has gone probably --bad piston and ring fit -cylinder leakage test would have shown that before stripping too much of the "drug" and you can bend a con rod. If it had an elctric start you could spray it from a distance at the air filter and feed it in --but a squirt on an engine that is stopped is not good I will use it if really required ,but my favorite is propane from a plumbers torch thats not lit- put torch in air filter and turn it on then crank engine an engine will run on gas --quite often use it when changing a diesel filter --some are a real pain to bleed through ,butane will work as well--but NEVER oxygen -that will blow the head clean off diesel or petrol it works -
my brother had one like that --and as he is even older than me -hand cranking was not good so i machined a saxo gearbox bell housing with a starter motor on it to get rid of all the actual gearbox -attached it and a saxo flywheel to the lister one --fitted a battery +bingo electric start -
If you have not taken head off yet and have access to compressed air and can make upan adaptor to feedi ncompressed air through and injector hole then get cengfine ontdc with vlaves shut on cylinder you are testing -put it ingear and block wheels .appl y90psi and listen to see where its going --up the inlet manifold ,out the exexhaust or icoming out if oil breahter . by doig this you will know what you need before you strip it looking ta istripped your bound to see things that are worn ,but they maybe are not your problem .this way you know where yuor comp is going . if you can borrow a proper cylinder leakage tester ,then unless its over 20% leakage it will be fine once its going - perfect engine will be around 4% could be simple as a vlave stuck open -
simple they fit meter -read it at same time as normal one -if itshows usage theyt charge you Ican,t see the cost for water on the insurance claim for a burnt house being a big in the scale of things without meter its just asking to be be abused
my brother had a customer for his hoilday let ,who when they came decided it was no good ,cos thier old dog could not climb stairs --and they expected a full refund 2 chances of that slight and none even though details clearly show it is 3 storey
Previously developed land - yes or no?
scottishjohn replied to KevinTreg's topic in Planning Permission
that sounds like it is being treated as farm land ,where you can build a house for a small holding ,but now you have to prove you can make enough from the land to make it a "sustainable" biusness usual guide lines used by our council is 60acres for sheep and cows etc I suppose if you could prove you were going to have big green houses to grow veg and sell --then maybe ,but they would them them built first.before any habitation of house takes place -
but if not applying for 3 supplies there could be more costs late rto connect to other houses,thats all I,m highlighting --ask more questions once you make real application you hsould get a drawing shoqwing all lines they are installing and where they terminate --could be all are quoted for is power line to site ?
so is the 23k for a supply to one uniit or all three ? and do they know its to supply 3 units
I would have jusat used the tigerseal as the lubricant and sealer all in one go -not just applied a bead to outer edge as you seem to have done as long as it works
hope you cleaned all the silicone gel off before using the tigerseal --if it leaks it will be because the surface was not clean ,notihng else that stuff sticks like sxxt to a blanket
If mon ey is a problem --build 2 now and third later and have mains power
I may not be scotish by birth -but by inclination i am
then build a purpose dog shower somewhere--even better selling point
same goes for the advice to wash hands under running tap how you going to get a lather if you running water on hands all the time wet hands -use soap for 20seconds then dip to remove it ,then running water to rinse off while sink drains
I don,t see how turn on shower let it run warm ,get in --get wet ,then use shower gel -but turn shower off while lathering up --or it just washes off the gel before it has time to be woorked properly -then turn it on again -staret from top and work areas downwards -- this method came about from being very oily and greasy from being a muckhanic and head +hair could need 2 goes to remove all the crud then repeat with different areas of body --no way it uses more than a bath to wash
no horizontal cylinder is gong to work as well as a vertical one- technically you need a tall one to get thermal layering ,which allows better heat filling of the cylinder as transfer coil is always in area with lowest temp water. It is used with great effect in solar thermal systems where you also have a normal high temp heat coil from another heat source in the same vessel but solar coil is always at lowest point,as hottest water will always rise to the top . yes it will work but not be as good . think where the input and outputs are cold in at lowest point --hot outlet at top further apart they are they less mixing of cold and hot in tank as you draw off the hot water
looking at grants that are claimable for commercial rated properties Iam guessing that that will be the decider and if it is rated as non deomestic --then up here you can claim a 25K grant-check locla council covid grants
that statement says it all to me-- -
what summer season --thats gone for this year going off grid will be worst mistake you make -- but hey you asked for others views ---
suck it up-- get grid power and yes water board will want to supply them all individually .think about this carefully --if you never going to sell them or just sell them all to one person ,then can you have one supply,make it a bigger one , to your ground and you split it . BUT if you ever want to split+sell them --then you need to have 3 supplies
no, but we got wild boar in some parts of D&G. who knows when they make it a national park they will want to re introdcue them along with wolves etc
thats just what my road and house clearing has felt like .LOL
shutter it and use readymix ? I,ve got 400yds and although it was tarmac60 years ago I am getting the feeling there will not be much left of it by time I get all cleared --i know its granite base undeneath ,so my guesstimate is i would need 160cum to give 100mm thickness --,just do it in bits --maybe ok with 75mm due to base --time will tell 160cu @£80 cum =£12800+my labour to lay it
why you waitng -? nothing going to change very soon
