scottishjohn
suggestions for TF house supplier in scotland
scottishjohn replied to scottishjohn's topic in Timber Frame
I have no problem with that if price is right -
preferrably -if you have some dealings with the suggested supplier
or pay for kit and get them to store it till you can be sure of at least getting a wind and water tight build done --finish off later when things are better?
I think that will very much depend on how much of it you are going to do yourself and what type of build I really do not see a shortage of things to get the founds and drainage systems done what type of build you thinking of and how much of it will be self build ?. ICF type of build lends itself to stop start much better that TF for example, especially the woodcrete type systems and if you are self building If its going to be contractor built --then i suspect there will be problems --maybe just do founds to start with you got plans and PP ready to go?
already talked to transport scotland and they maintain it ,but do not own solum should make it very hard for planning to stop any access to a75 when somone goes for planning --but no i cannot block it and charge a toll
Kirkmabreck Quarry - Plan (3).pdfI attach the site plan notice the A75 is actually owned by me -LOl maybe need to take some expensive legal advice on how to maximise its value certainly will make dealings with planning for access much easier i think some one suggested a truck stop? 40miles from stranraer --40 from dumfries --so maybe --but not for me to do
yep the jetty would be ideal spot ,but i would want to sell it as one lump and you can work out the details. maybe an a gated ECO village would make planning happy
the calculator they put on site --says different -which is why I,m waitng to speak to a real person -it say about 0.04 with compacted foam glass shards we will see
(Un)Reliability of Contractors
scottishjohn replied to LA3222's topic in General Self Build & DIY Discussion
having the sdame soort of problem --but not a real problem yet with the guys clearing the trees and road --they keep going to other jobs and coming back maybe its the price theyt quoted they do alot of work for DNO.s and railways in clearing up after storms etc still my archictect thinks i got a very good deal --so maybe this is what comes with it they keep telling me MONDAY -but not which one LOL -
was thinking of the foam glass chips --not the sheet have messaged them and will see what they come back with -not seen any prices yet I suspect that my house will be built on solid rock -so may be that will already be better than mud etc should be dryier -- so maybe do not need that thick a layer
anyone looked at this looks like its better than insulated raft- or is it me
How to stop water coming through soil bank
scottishjohn replied to rpuddle's topic in Garages & Workshops
6" deeper than the top of garage slab--that should work -
I don,t see any easy way with the floor level below ground level --too late now but the slab should have been above ground level you could i suppose use blocks to jack up garage all round -then throw some plastic sheet in and just make your floor higher --that would be best solution -probably don,t even need to cement blocks if you going to fill with concrete--and don,t forget to put a run on floor to wards the doors If you work out the other proper soutions I think you will find what I suggest as alot cheaper than trying to tank or lay franch drains ,which need to connect to somethinbg lower -like main drains -
Securing PV panels to shipping container
scottishjohn replied to NWGEAR's topic in General Self Build & DIY Discussion
to secure my 2 x30 tube solar thermal array on my garage roof i used 8" wide 1/2" plate and bolted them to that -makers required 100kgs to hold them down in storms --and these sat at 50degrees --so were much taller than your PV will be I just made sure I sat them on DPC--just as well cos when iremocved them 16years later they were stuck to it -- but came off with no damage to flat roof felt-the DPC became part of the roof -
tiger seal is same ,just dif make -
Powercut, sun shining, PV not generating
scottishjohn replied to vivienz's topic in Electrics - Other
they will say get an elctrican who is fit for the job to start with -
so if they were half charged you used over 7kw with minimum things turned on how many hours --how much usage per hour? and no heating you say -
clean surfaceof container --make up something to attach panels to -then stick that to container with tiger seal If everything clean it will never come away other way is to weight your PV frame down with bags of ballast or big lumps of concrete -
what capacity is your battery storage -
thats a question for your electrican -
someone from tesla will ring me later - https://empowerenergy.co.uk/tesla-powerwall-backupgateway2/ -
I,ll ask the question
