scottishjohn
Borehole's (particularly Scottish one's)
scottishjohn replied to SuperJohnG's topic in General Plumbing
what ireally need is to find out the pressure inthe main on the A75--if that is 5-7 bar -which isuspect it might be -cos it supplies right along to gatehouse --then that would mean i can have my pump house a lot futhger up the hill --making plumbing and electrics and pump size smaller--all scottish water will say is "we only have to supply 1 bar" -
yes I know the smoke house one its 35m --talked to the man who owns it--it has no artesian pressure -so still a pumping job . -
my problem is that with my house being so close to the quarry and I can see water coming out of the lower quarry walls isuspect there will be none left for me If idrilled a bore hole Iwill see how thesequarry walls flow in the summer . this is why I,m almost convinced only way is to pump it up the hill from the main road --and cost might not be that much different --just more power to get thew 200psi+ i need to lift it to house -
all the ones shown above were done when a75 was realigned and none of the actual water bore holes I know are there are not shown .other than one which I know is a wter bore hole -
I have been studing some old OS maps for my build i have found that things marked as wells are not always wells ,maybe just "issues" for a water suppy if you have the option of a mains supply --take it drilling bore holes and then all the treatment the water might need to be drinkable --its not just UV -One man here has had to put expensive chemical filters to get rid of arsenic in the water I am pretty brave at tackiling jobs i have not done before --but a well If ground is easy to dig then it will need stone liner so it does not collapse in If it rock then you going to have to drill and ideally you want water that is not just coming from top soil ,but water that has taken time to filter down through the layers ,which help clean out the biologicals -
already sorted out what i will do at new house mobile router for all phone and internet will be cheaper than running a land line in and no call charges £100 equip +setup charge -thats it my phones at work now run over internet --cheaper and NO call charges
Exposed stone walls in a barn conversion
scottishjohn replied to Geoffrey's topic in Introduce Yourself
you still going to have to line or build stud walls + PB and interior finish ,but price up a proper tanking solution and it will not look that exspensive- 20 replies
- stone walls
- pp
going rates I have been quoted is about £35 sqm--so not cheap --but it is also has high insulation value as well- 20 replies
- stone walls
- pp
the first post said there should be no off gassing --thats limits choices
closed cell foam is quite a popular way in US to waterproof basements from the outside instead of tanking etc and internal drainge systems painting outside of walls -should then something that can let the moisture in the wall go outwards ,not seal it in- 20 replies
- stone walls
- pp
only if you can get at them easy in future --otherwise welded type
use sixflex or tiger seal --that will take an hour or so to stick firm and up to 24 hrs to be solid --depending on thickness--stuff they stick windscreens in with
foam glas chips -- between joists www.dreieck.co.uk £85 cubic m bag
I,ve been plotting same problem with my house the favoured solutiuon by all --If i want to keep exterior walls is to dig out floor spray all internal walls with closed cell foam min 30mm --that water proofs it and build TF inside with new floor slab. OR most popular suggestion from architect and buulders-as it should be easy to be accurate with costings flatten it -rebuild how ever I like -then use granite as exterior cladding Kirmabreck House old (9).pdf- 20 replies
- stone walls
- pp
tipex --i what iuse on cam pullies when doing a cam belt
you could have dry assembled and marked all fittings how theywanted to be orinentated before glue was applied
expect extremly high heating costs and possible damp problems in walls lime mortar does allow moisture to evaporate out ,but also allows it to get in from outside or up from the ground below (rising damp)- so trying to have bare wallls on a house with no damp proof course or foundations or insulation is a non starter ufh seems a bit of a waste of time ,if reasonable heating costs is in your mind . not sure how you will keep planning happy with no insulation- 20 replies
- stone walls
- pp
Any experience using spreader plates?
scottishjohn replied to Doodlehime's topic in Underfloor Heating
what idid was to fix battons to sides of floor joist then infill with pur -clip pipes to that so they were hard up against the 22mm osb flooring-proud by 5mm before floor laid ---been working fine for 15years,just make sure you blank off the ends of the joist so heat cannot esacape somewhere else. not saying best way --its what i did and it works fine -
or if buying --then auction prices should be low for the forseeable future
this week --If i get time i wll be ringing around to get a deal on long term 8-10t digger hire --should be some great deals to be had I already have bought a 3ton benford swivel tip articulated dumper
he specifed phenolic for a reason --to get required insultaion value --so yes use pur by all means --but it will need to be thicker to get same value
If I were doing it all myself --i would agree --but if you employing men to do it --then no -
the clever bet says house prices will fall and less people will be moving about while they get over the finacial shock of this thing so if you are in a postion you can hold at ,thats what i would do -then wait and see
just me maybe --but don,t like edpm for roof after I saw result of seagulls peckinbg at food(bones chucked out for dog ) they brought up to roof --made holes inthe apdm would be GRP for me
