scottishjohn
what make is it link please?
the gyproc jumbo 150 stud walling I had to use that to split a showroom up as i was making 3 units out of one big building for fire proofing as the units were different tennents the spec was one layer of 19mm plank dry wall followed by 2layer of fireline dry wall -- this was onboth sides of the stud frame work ,with a fire curtain hung in centre it is absolutly sound proof and the wall is 5m tall sloping down to 3.5 at other end . so yes if you want sound proof use jumbo studding and thick layers of plaster board . I was worried that it would not take the weight of all that plasterboard 19+30=49mm per side --thats alot of weight still there 10 years later and no cracks in skim coat
looking for construction tools -no rush
scottishjohn replied to scottishjohn's topic in Tools & Equipment
I just assumed thats what they would do --not asked for post code just an idea how how far way -
Joist Hangers: too many holes?
scottishjohn replied to ToughButterCup's topic in General Construction Issues
there are screws +screws as in all things you need to get correct type and for the job, they would have a flat faced head ,not a countersunk head as in std wood screw + not from screw fix-or other cheap crap supplier with no wasting under head . I would just use the nails --but he wanted an option -there are options correct-- screws to correct torque --not a problem cos they have more surface area to grip than an nail of any type--as you found when using nails on your cladding as i remember screws don,t work them selves out as nails can in some applications I agree though I would use the twist nails --its the cheapest + simplest solution -
common sense would say a screw of similar gauge will hold better than a nail any day --go up a size if you wish they spec nails cos they are cheaper+quicker with correct tool to put them in --saving costly labour --but you work for nothing!! -
any nail gun use in a factory situation is always air powered -cheaper to buy and use -paslode is just convenient if you got no electric on hand for compressor and no air line following you around its not better or cheaper in the way it fixs nails -
think 40mm would be better choice https://tradefixdirect.com/sheradised-nails/sheradised-square-twist-nails-40-x-375mm -
maybe if they didn,t make the hangers out of old bean cans they wouldn,t need as many fixings -
all the usual things . telehandler,dumper ,small digger/bob cat ,20ft container ,concrete mixer,mule -etc tell me what you got and where you are nail gun ,table saw --what ever you want rid of
yes i know about these things from car spraying etc--you can get away with a smaller compressor with a LARGE reciever every now and then you might need to give it a minute or 2 to catch up . basic rule of thumb 1hp =4cfm for continous use. If you want to rent a generator yo will find 3phase garage compressors very cheap s/h, even screw types now my guess older hydro vane or something like that 40cfm --£300
the answer I saw when searching this subject of hangers and twisty nails was a nail in EVERY hole -
Which heating system in our old house?
scottishjohn replied to Dee J's topic in Boilers & Hot Water Tanks
this reminds me of when i was a boy and my first car--changed exhaust ,brakes shock absorbers and fitted new tyres etc and when i went to buy another one from a dealer the offer he made me seemed bad after all the money i had spent " must have needed it son" --but it dont, alter the price i,m offering you he says with a smile . chances are who ever buys it will want to knock it about anyway . bottom line is you can always come down in price by the amount you would spend I have been told that any improvement you make to a house you will be lucky if you get 50% of its value back when you sell - so easier just to do the buyer a deal and move one -
remove concrete he is unhappy with NOW- and perform a soil test ther and in another part of your plot and give him some info , you have to suck up to him a little add something to counteract the leaching if the test at the area is much different than the surrounding ground and tell him what you have done could be you just got to wait till next spring and see if trees are happy --then another visit from tree man to confirm they are ok. there is no way you can turn back time
you are correct ,but it must meet certain level to even qualify for RHI to start with same as fitted solar thermal --if you doing ASHP your rate will drop if you declare solar thermal . on a very good house its hardly worth going RHI ,if you fit yourself savings there will far out weigh RHI payment
in scotland they quite often put a tag on a tree that has aTPO on it if its in a build site so no excuses for builder to say he didn,t know
I just went to kensa site and filled in the rough quote guide with details 150sgm floor area and new build house--came out at £25.6k --i knew you were not even close to proper price for gshp
not a hope in hell to do a GSHP for 10k --borehole or holes will be more than that . and if you thinking slinkys you need a lot ground for that and trench type is right way not slinkys --if contractor quotes for slinkys --find one that knows what he is doing I could be wrong but i have not seen a GSHP pump unit for under 10K and if you get sizing wrong it will not work . same goes for bore hole --you try and get someone to guarantee what depth hole you need --they won,t do it --they will just say they can,t be sure how much heat till it dug + tested and you might need another one . I looked at that long time ago and discounted it due to possible variances in ground which affects how much heat you get and no warranty from contractor as to how much drilling would cost --and that was 3 different quotes i asked for --all said the same . now if you got a nice boggy field or a lake --that is perfect for trench type GSHP --- any way you go get your quotes and you will see the reason why the RHI is so big for GSHP is the price it costs to do it -- just no need for GSHP in uk with the winter temps we get .
surely money would be better spent in wrapping the house in insulation first to drop the energy requirement . If its a BIG old house with lather +plaster and high ceilings , you could always bring your rooms in by 6" on each wall and make an air tight insulated house inside that house by making stud walls + new insulated ceilings +vapour barriers to seal it all seen that done very effectively in a big house --no demolition just all new walls and new wiring etc ,dead easy to do while you live in it then the money you save on running the house will pay for the ASHP just a thought if its BIG old house no point in ashp till house is at least have decent thermal wise
DO NOT go gshp --it is not the way in uk climate --cost to do will never be economical -- £20-30k for that If in canada ,where you get -20c for months yes --not in uk ASHP 2-8k depending on who does it will still run down to -18 --but not as effiecntly as GSHP --but thats one week every year ? ASHP is the way --but you need electric for that now you need to say how big this is going to be and can you bring it up to nearly passiv insulation values -- that will dramtically drop your energy requirement
wave a cheque usually works .LOL
not saying this is the best one, but all work the same added to solar pv +batteries you got it sorted all year round no matter the snow etc www.homeheatingguide.co.uk/central-heating/baxi-ecogen-micro-chp-combined-heat-power-boiler-replacement
"chips" system actually CHP micro boiler--plenty of makes about and you get RHI as well boiler that makes electric as well as heat add that to all other modern techs and you are there -just got to feed that with oil,or gas in depths of winter
clay is what they used to use to make the canals water tight -+romans used it for aqueducts -works very well if kept wet and don,t dry out
Buying metal roofing from France: advice
scottishjohn replied to albert's topic in Roofing, Tiling & Slating
email them --but use googgle translate and send it in both english and french -
the "amptec" boiler already has temp controls etc simple loop with divertor valve+ pump and it will just deliver water at temp you set. I used one as my inline back up for solar thermal UFH system found one very cheap compared to normal proce --brand new on ebay or use an electric shower unit maybe would work the same . from what i can see a willis heater needs a tank to fit it into and then you back to thermal losses
