Everything posted by jack
What does your home cinema look like?
jack replied to Adsibob's topic in Networks, AV, Security & Automation
My electrician installed a piece of protective steel plate across some 240V wiring that supplied the external blinds on a window. It was close to where someone might drill to install supports for a curtain rod, so clearly pretty important. I walked into the room after the boarder had been through. He'd clearly realised the steel was going to slow him down a bit, so he'd just ripped it off and threw it on the floor. Lazy and stupid? Sure. But literally so lazy and/or stupid that he'd made no effort to conceal what he'd done. I raised it with the contractor who'd got him in and he started getting cranky with me for being "unreasonable". First (and from memory the only) time I lost my rag at a tradesman onsite. -
When the box is entirely sealed, that's roughly right. It's quite frequency dependent - some purists build "open baffle" loudspeakers, which are literally a large, heavy board with the loudspeaker in the middle of it. Nearly all modern loudspeakers are "ported", meaning they have a tuned length port through which sound from inside the enclosure is directed. The interaction of the box, port, loudspeaker driver boosts certain low frequencies, at the expense of introducing phase issues and a less even frequency response. For once, I actually got my act into gear in time, and ran ducts for loudspeaker cables and wiring, from a recess in the back corner of the room, over to the front of the room where the TV and loudspeakers would go. There was one duct for each cable - centre, left and right. I then came home to find that they'd double-boarded everything up with the ducts hanging out through holes they'd chopped into the ceiling against the top of the wall! WHY!? -
I was convinced it had to be a rat (if not a badger!) based on the noise. I sounded like someone loudly gouging out wood with a chisel.
It's that time of year I guess. We were woken a couple of nights ago by an ungodly scraping noise in our pantry. It was so loud that I thought it was the dog scratching at something, but when I got down there I realised something else was chomping on a wood panel behind the pantry cupboards. I've now found mouse crap under the units, but I can't see any evidence of the chewing. I can only assume it's on the back panel of the units that I can't get to, where it's trying to chew through to where the food is kept. Humane trap down but so far no hits. This isn't the first I've found in this general area. They seem to enter along a gap in the internal service void behind the plasterboard. How they're getting into that void from outside (through 300mm of cellulose insulation) is the bigger question, and I don't want to block off the gap until I know the answer!
I no longer wish to stick a flint to anything. Thanks!
Anybody have 75mm depth polished concrete floor above ufh?
jack replied to KillyfadNewBuild's topic in Floor Structures
What's your 75mm concrete going on top of? If it's to be the sole structural slab, that sounds thin for concrete. I have a ~65-70mm polished concrete layer on top of a nominally 100mm slab (with many deeper ribs and a couple of spines along structural walls) with 300 EPS insulation underneath. The slab has the UFH pipework. We were told 75mm minimum, but didn't have the height available, so we were required to sign something saying we understood the risks. We do have cracks in a couple of places. -
Did they give you a specific reason for recommending you not use ASHP cooling? Condensation would be the main potential issue. We only heat/cool our downstairs floor. The ASHP pipework comes into the plant room and is connected to the manifold only a couple of feet away, so there's very little exposed pipework. I run the cooling at a temp of 15 or 16 degrees, from memory. In this situation, we get a slight breath of condensation on the metal parts of the manifold, but nowhere else and there certainly isn't enough to drip. I'm certainly not worried about condensation on the floor surface itself, as I doubt it ever drops below about 19 degrees. It might be more worrying of you're running long sections of pipework inside walls and within floor cavities. But if you keep the temps reasonable, I doubt it'll be an issue.
It's a lot of fun. Even without getting into the programming language (pico C?), it's amazing what you can do with it.
You've never been in a house in the UK that you thought was too hot? I find that surprising. I've been in several. As for cooling the floor, to save me repeating myself, have you read any of the several threads on floor cooling? Having worked in air-conditioned offices for many years in Australia, I find floor cooling to be a much more comfortable way of cooling a space than air cooling. One hot day is fine. A couple is okay. It's when you get a run of several hot days that the heat gradually creeps up. Having cellulose insulation in the walls and roof is a blessing and curse - it buffers heat really well, but when it eventually warms up, it has a lot of energy to re-radiate into the house. It takes days to heat up, and days to cool down. We don't have insect screens (something I'll definitely be addressing eventually), so we can't ventilate at night. We do have an ASHP and concrete floors with UFH, so it makes sense to cool them. We also have a lot of PV, so on sunny days, cooling is effectively free - I only tend to run the cooling during the day when the sun is up. These are more interesting questions imo. This year, much of summer was mild and very overcast. We only used it for maybe a week. Maybe two or three years ago we had a couple of multi-week hot, sunny periods with high overnight temperatures. I believe we ran the underfloor cooling for at least a month or maybe even six weeks over the course of three or four months that year. At a guess, I'd say we've averaged three or four weeks of cooling across the summer over the last six summers since we moved in.
We were looking at reclaimed parquet blocks on eBay on and off for a year leading up to the build kicking off, but it always seemed like a lot of work and a fair bit of risk. They were generally stuck down with a bitumen based adhesive, which is an absolute pig to deal with. You could buy stuff that had been cleaned etc, but that was always crazy expensive for what it was. Edited to add: we did consider the best of both worlds with porcelain wood-effect parquet, but I don't remember why we chose not to go with it in the end.
Yup, porcelain all the way. Decent porcelain tiles will last forever. Worst case you can always dig out a broken one and replace it. I really like parquet flooring. We were very close to having our downstairs floors being parquet throughout. I'm still not sure whether we made the right choice going for concrete.
The thing that would swing it towards an ASHP for me is the opportunity for cooling. We have concrete floors downstairs, and the ability to run the ASHP in cooling mode makes our downstairs a very pleasant place to be in a run of hot weather. In fact, if I were building again, I'd consider tile throughout, including the bedrooms. I'd buy a load of fitted rugs to lay down in the bedrooms in winter (with no or minimal heating), and cool the bare tiles in summer.
UFH is definitely something I wouldn't be without in a well-insulated house, especially downstairs.
My setup is nearly as simple as it can be - single thermostat, single downstairs zone - but I do find weather compensation to help. I run 25 degrees when the temperature is above (from memory) 7 degrees, with a linear rise to 28 degrees as the temperature drops to 0 degrees. Could be my imagination, but I found that running at 25 degrees fixed would leave the house feeling a bit cool during a long cold spell. It adds almost no complexity. I set the curve once on the main ASHP controller, and haven't really looked at it again in several years.
Nice looking project. I'd definitely be looking into getting three-phase power onsite if you have two electric cars and are considering running your house solely on electricity.
I can barely hear our 6 year old unit standing right next to it when it's running flat chat. I can't hear it at all when it's modulated down to do space heating. Nearly every post above yours says that an ASHP at best isn't a drop-in replacement in these particular circumstances.
I don't recall either, but HMRC has a long history of not changing their policies in response to tribunal decisions. If a higher court issues a decision, they might do, but based on how they've behaved with the DIY VAT reclaim system over the years, I suspect they'll change the rules by the absolute minimum amount possible.
I hadn't really thought about those limitations, but I guess 4 hours isn't a lot of time in which to stuff an entire day's heating into a slab using a low-temperature-difference heat source. I'll one day get around to putting energy monitoring in place so I can see what my ASHP is actually doing all day! I'd completely forgotten about that option. Definitely worth looking into now that we have Octopus Go.
For comparison, we have a 289m2 house with similar insulation etc, and a 5kW Panasonic Aquarea that's about 6 years old. 1. Is my understanding of the basics correct? Yes. 2. Would the buffer thermostat require a wide hysterisis, or maybe two thermostats one at top the other at bottom of tank? Not sure why you'd need two thermostats. 3. Some buffers have a coil (like @joe90's), while others don't. Which one is best? Which one is easiest to set up? Using a coil means you only need anti-freeze in the loop to the ASHP. You can get away with just corrosion inhibitor in the UFH circuit, which is a lot cheaper. 4. For buffer tank without a coil then should it be configured with a 2-pipe or 4-pipe connection, or does it really make much difference? Not sure. 5. Does the panasonic range of ASHP allow seperate water temperatures to be set for DHW and heating? Yes, I believe they all do. Mine has a minimum settable heating temperature of 25 degrees, which is about right. I have it set with mild weather compensation - it runs at 25 degrees when the weather is about (from memory) 7 degrees, and then increases the temperature up to (again from memory) 29 degrees when the temperature is a 0 degrees or below. I wasn't sure that this was really needed, but the recent cold spell has shown that it does work. The house was a little cool for the first day or two until the slightly higher water temperature caught up. 6. Some ASHP require a minimum volume, how does a buffer tank with a coil, hence very low volume, satisfy that requirement? The coil acts as a heat exchanger, and anything it exchanges heat with can be considered part of the same hydraulic system. Assuming the system is set up and working properly, the ASHP can't tell whether you're directly heating water in a tank, or transferring the heat into the tank via a coil. 7. Does a buffer tank with a coil support a defrost cycle ok? Yes, shouldn't really make much difference. I don't know how big a DHW tank you're planning, or whether you're planning PV. We have a 250L tank, which is arguably a little small for the size of house, especially given we have a lot of PV. However, we also have a decent shower waste water heat recovery unit, and I'm absolutely convinced that this is why we very rarely run short of hot water. They don't cost much and are a very low tech + low maintenance way of reducing energy consumption. We're on the Octopus Go tariff, and I've been thinking about this too recently (because it's gotten cold, basically!). Given the thermal capacity of the slab versus that of a buffer, I'm genuinely unsure what impact this would have compared to intentionally allowing the slab to "overheat" by a degree or two during cold spells. My initial rough analysis concluded that raising the temperature of a 200L buffer from 20 degrees to something like 40 degrees would require something like the same energy as raising the slab from 20 to 22 degrees. I'd be interested to see what sorts of numbers others are getting for this.
Absolutely no idea, sorry. I've only ever tracked the anemometers.
Bear in mind that it isn't just your neighbours who'll be breathing in all that crap. Even with an "efficient" woodburner and good extraction, you'll still end up far higher particulates in your house than if you didn't have a fire. I can't stand the things. I hate the smell, I hate the watery eyes, and I hate the sore throat I end up with when I walk around the neighbourhood during woodburner season.
All boundaries are shared, otherwise they wouldn't be boundaries! If she's saying it's a shared fence, that's possible, albeit unlikely in the absence of specific evidence, but it's a complete red herring in any event. The boundary is a line. The plant is clearly on her side of that line (assuming the fence is in the right place), hence it's solely her responsibility to get rid of it. If she's spoken to a professional about this then presumably she knows this has to be (literally) nipped in the bud. If you won't contribute - and you shouldn't - then she'll need to handle it herself. She's already shown her hand with allegations about your distant topsoil being the potential source of the knotweed, and now trying to get you to pay for removing a noxious weed that's clearly not on your property. Given her behaviour so far, you shouldn't be helping her to treat it, other than perhaps advising her that she can do it herself for a lot less than the quote she's had. If she pushes back, I'd be tempted to say that if she doesn't take care of it and it moves to your side of the fence, you'll sue her for the cost of getting rid of it.
Yes, we did this. To be honest, we rarely keep doors closed long enough for it to make much difference. We were a bit worried about noise transfer, so we lined the inside of the aperture with some corrugated sound-absorbing foam (peaks and troughs aligned in direction of air travel). There's very little noise transfer, but I can't honestly say what impact the sound absorbing foam makes.
When is "4 metres" not 4000mm?
jack replied to ProDave's topic in General Self Build & DIY Discussion
