Everything posted by jack
Reducing accidents for elderly
jack replied to CalvinHobbes's topic in General Self Build & DIY Discussion
Remembering names has always been a serious issue for me, and it's absolutely been getting worse over the last few years. -
Discount Offers of the Week
jack replied to Ferdinand's topic in General Self Build & DIY Discussion
You're welcome. -
I'll probably get my HA system to control it, which perhaps counter-intuitively might make things simpler. Still requires some upfront thought.
Good point. If I were still building, I'd definitely be grabbing this deal, despite already have two batteries, an impulse driver and a heavy drill. A lighter drill like this would be ideal for lighter-weight repetitive jobs, plus as you say, having two drills is useful anyway Also, 5 Ah batteries are great if you ever plan on buying battery-powered garden tools, or use heavier power tools such as a circular saw (mine chews through battery life like no-one's business). -
Yup. The question is whether I actually need to heat outside the off-peak period.
Yes, a COP of 4 isn't very likely during that time of the year, so it's slightly cheaper to use the immersion off-peak than the ASHP during peak hours. The main question will be controlling it all, and keeping it simple.
Interesting you found this to be the case - I'm planning on trying this out next winter. I'm on Octopus Go, and my peak rate electricity is about to go from 13.8p to nearly 30p per kWh in May. The off-peak rate is only going up from 5p to 7.5p, to there'll be an even bigger incentive to push things like heating into the four hour off-peak window. I need to do some maths, but the modest reduction in COP caused by a slight increase in flow temperature will be swamped by the 4x cost difference between peak and off-peak rates. The only question now is whether our 5 kW ASHP will be able to both heat our DHW and put enough energy into the slab during the four hour off-peak window during cold periods. I suppose we can just add a bit more if needed during the day.
Very possible. I've seen dumber behaviour from eBay buyers! -
To give some idea of how good a deal this is, Screwfix is also selling a single 5 Ah battery for £100. A pair of these batteries on Amazon is £150, so as you say, it's literally a free drill and charger on top of a better price than you'd generally be able to find for just the batteries. If anyone's thinking about getting into the Makita 18 V ecosystem, this would be a great way to start. -
We used rapid racking too. Can't remember which flavour - maybe the one above their base level? - but it's absolutely rock solid. The chipboard shelves probably won't last forever, but easy enough to replace (probably with thicker plywood) in due course.
Yes, something like that. As suggested above, there's a lot to getting this sort of lighting right. Colour temperature, power, output angle, etc, will all play a role in how effective the lighting will be. My general feeling is that small uplights are always visually annoying unless they have screen or are recessed such that light is blocked from directly hitting your eyes as you walk by.
Couldn't agree more. Constant current if at all possible. With decent dimmers, you can dim smoothly all the way down to zero. I played around with an EldoLED constant current driver when I was thinking about switching from mains dimming, and the quality of the dimming was startling compared to the mains dimming I was using at the time (now since replaced with a White Wings multi-channel dimmer and a KNX multi-channel dimmer). Interestingly, the White Wings dimmer has let me dim noticeably lower than even the decent quality KNX mains dimmer I have running the rest of the house. I assumed the drivers would completely dominate dimming performance, but it's marked how much better the White Wings dimmer is.
I wouldn't leave a decision like this to an electrician with this unless they have experience with the different sorts of lights and driving arrangements that are possible. Get onto the Loxone Google Group if you aren't already there, and ask them for suggestions. They're generally pretty helpful. I have one of these and am very happy with it, but it's driving existing per-LED-downlight drivers. You'll be driving very low power LEDs (I'm guessing you'll want something like 0.5 or 1W for your application), for which this sort of dimmer isn't really appropriate.
Do consider what sort of driver you'll be using (which in turn will depend on what sort of LEDs you're using). Connecting all LEDs in parallel will be fine with 12 V (or more likely 24 V) LEDs, but if you're using constant current, you'll need to consider how many LEDs your drivers can run in series. From memory, constant current drivers might only output a maximum of maybe 45-50V per channel, so you'll want to make sure that's enough to drive all of your LEDs in series. This might be less of an issue with very low power LEDs. I experienced it when considering whether to move to DMX controlled constant current drivers for downlights in a couple of areas, but that might have been due to the relatively high voltages required per LED fixture.
New member, hoping to one day build an energy efficient house
jack replied to daydreamer's topic in Introduce Yourself
Welcome! We knocked down a very tired old bungalow after we got planning permission to rebuild. As others have said, the condition of the house is not relevant, but you do need to advise the council of your intention in advance of doing so. It's been a long time since we did it, but I vaguely recall you had to tell them so many weeks or a month before your planned demolition date, and if they didn't say otherwise, you were fine to proceed. Worth looking into the details before committing, of course, but no-one's going to stop you replacing a house unless (as @Bitpipe said) it's listed or perhaps in a conservation area. -
Are any energy companies taking on new customers?
jack replied to jayc89's topic in General Self Build & DIY Discussion
I tried to get an anonymous price from Octopus the other day, but their website took me to a page where they said they were no longer signing up customers in my area. I suppose that if you're losing money with every customer, there's no incentive to take on any new ones! -
Have you seen https://solcast.com/ ?
Funny you should mention that. Following my comment yesterday about the big jump in charges coming our way when our fixed tariff ends in May, I visited my account to see what sort of usage we were looking at. Turns out that, although they've been taking out our direct debit correctly, we haven't had a bill since September. Before that it looks like we were getting one or two a month. I've emailed them to ask what's going on. No reply as yet.
The best way to annoy him is to ignore him and get on with building the house. Pleased it's ended well for you.
Do you mean a hinged single pane?
Most of our downstairs floor area is polished concrete. While we have Passivhaus levels of airtightness and insulation, we don't have huge amounts of solar gain, and our house does tend to have a longer heating period than other Passivhaus-class houses I'm aware of. I turned off the heating last week. The floor temperature has been fluctuating between 18 and 19 degrees over the last couple of days. It definitely feels cold underfoot. I tend to walk around in socks, so isn't really an issue. So to answer your questions: We don't heat the floor in summer, and it feels perfectly comfortable. In fact, we cool ours during hot periods, and it feels amazing. No. We run UFH only when the house needs heating or cooling. I can't answer question 3, as we don't have wooden floors. I will say that the one carpeted room downstairs is the coldest room in the house during winter, presumably because the carpet reduces energy transfer from the UFH.
We had curtains priced for the two bedrooms that get the morning sun, and they've been put off into some future in which I win the lottery. It's absolutely eye-watering, especially if you want good quality fabrics.
The ones on the front of our house stay down at all times. The slats just tilt between closed and slightly open. I really like the way they look.
