jack
    41
Everything posted by jack
  1. Interesting. Would you call foil-faced PIR "foil insulation"? If so, I think even this carefully worded bit of misdirection is arguably inaccurate!
  2. We still have some cladding to do (eaves) and I think we'll just scrape by with our 10% over estimate.
  3. Personally, I'd keep the MVHR within the heated area to avoid potential condensation issues. I can live with a little bit of condensation in the external ductwork. I'm less happy with the prospect of condensation within the MVHR unit itself, mainly for the longevity of the electronics and fan bearings etc. The actual difference in heat loss between the two scenarios will be difficult to quantify. The performance of an MVHR unit is hit surprisingly hard by the length of uninsulated external ductwork coming into the heated area of the house (for an internal MVHR - vice versa if it's outside). The unit itself will also contribute some losses, but I suspect you'd need to know the exact makeup of the interior MVHR insulation relative to the duct paths to understand whether internal or external mounting will give higher losses. This is because the one side of the MVHR is at the external temp and the other is at the internal. When it's very cold outside, there's a big temperature difference between these two, and it's hard to model how the unit as a whole will act in terms of heat transfer. I suppose you could negate this issue by heavily insulating the unit itself.
  4. I don't think you want to remove it. Saturating it could work, although awkward to get to it before the walls come down (be a bit time consuming drilling holes for a hose or spraying water in through top of cavity if you can get to it). I'm not familiar with cotton insulation, but assuming it's a bulk product like batts, it'll likely be clumped together pretty well given how long it's been in the cavity. Can you knock a hole in a wall somewhere and see what state it's in?
  5. How expensive is "incredibly"? Our (Siberian, Russwood-supplied) larch has been up about a year and is so far weathering pretty unevenly in places. As you say, underneath overhangs has hardly weathered at all, plus we have places where there's uneven staining from water movement. It'll mostly even out in the end I suppose/hope. In the meantime, I just tell myself that wood is a natural product and this is how natural products behave. Sioo wasn't available when we needed our larch, although even with what we're experiencing now I'm not sure whether I'd have used it. The uniformity is very nice, but I do wonder whether there's a loss of longer term character compared to letting it weather naturally (with all the flaws that that might bring).
  6. I've generally got a pretty good memory, but within a few weeks of putting plasterboard up, I'd completely forgotten where just about everything was routed. Even though we took several photos of every wall before boarding, we've still had one or two situations where a crucial angle is missing and we've had to dig around.
  7. Ours was around £7k to knock down and remove a small bungalow and detached concrete prefab garage in Hampshire/Surrey borders, including disposal of (low risk) asbestos floor tiles. That was the cheapest quote by some way - wouldn't have taken it if we hadn't had a recommendation from someone else who'd used them.
  8. If you paid by debit card rather than bank transfer, you may still be protected: http://www.moneysavingexpert.com/shopping/visa-mastercard-chargeback They don't listen to self-builders, but they might listen to a bank.
  9. Ouch. Really sorry to hear this. Things inevitably go wrong when building. The real difference is when suppliers acknowledge their cock-ups and do what needs to be done to rectify them. Did you pay by credit card?
  10. Not on that clay it wasn't (well, maybe in a wet year!)
  11. A guy we had do some building work for us is working on his own extension to a Victorian house. He's just learned that the building inspector wants 3m deep footings due to the soil he's on. He pointed out that the Victorian house has one foot deep footings and is still standing without cracks 100+ years later. Oh, and he has no access for even a mini digger, so all has to be dug by hand (which I guess the Victorians did too!)
  12. Yep. We briefly spoke to a German architect at a building show once, and as soon as we mentioned a plant room he got very excited and started verbally laying out a basement for this and all the other stuff you list above. We backed away slowly. He's still there talking about it for all I know.
  13. Yes, to be avoided unless accessible for servicing.
  14. One of our smoke alarm mounts has a relay that closes when any of the alarms is triggered. Our home automation system takes this as an input and... presently does precisely nothing with it! But we could use it to kill power to the MVHR if desired (and wired). Personally I don't think it's an issue - building regs don't require it and I can see arguments both ways for leaving it on and turning it off. For me the main thing is waking up and getting the flock out of the house as soon as there's smouldering. By the time any fire has got the bit between its teeth, my family and I will be long gone.
  15. If that happens, then I imagine the pressure would completely overwhelm the MVHR fans. If you're right about pressure, then closing the inlet at this point will cause a further increase in pressure, and the smoke will therefore potentially work its way through the rest of the house seeking further exit routes as the outlet in the area of the fire (most likely the kitchen) is overwhelmed by the volume of exiting gases. I know you asked how you can achieve your proposal. I think Pete's offered one option there. But turning off the MVHR (the standard proposed approach) will do most of what you're asking. You've said that pressure increases greatly. If that's right, then nothing the MVHR does is going to make much of a difference. I'm not saying any of this is fact, because I simply don't have the necessary knowledge to do so. There are some interesting principles at play though, and I suspect there must be a reason that MVHR manufacturers recommend simply turning off the MVHR in the event of fire.
  16. Allowed by whom? That's a good question! Our (private) building control has seen our plans including the UFH being clipped to the steels. He's happy. Several other people have had MBC houses (which all use this arrangement) signed off by building control. I believe @Bitpipe had an architect (or perhaps engineer) who wasn't comfortable with this approach, but this was in a basement with some very stringent structural requirements. Don't suppose the steel would hurt heat movement, but bear in mind that with a very well insulated slab you don't tend to use high heat levels. Our ASHP is programmed to provide 25 deg C water to the slab during winter. I programmed in a mild weather compensation curve starting at 10 deg C exterior temp, with the ASHP supplying up to 28 deg C water at a -5 deg C exterior temperature. Never felt cold all last winter. You basically keep the slab largely at the same temperature all day and night, rather than blasting heat in morning and evening like with a screed.
  17. I looked at this before we started looking at raft foundations. I recall it being interesting stuff, but very expensive. I think it's produced somewhere in Scandinavia.
  18. I don't know all the ins and outs of combustion, but if something's burning to produce gas, surely it's consuming gas (ie, oxygen) to do so? Is there a net increase in the volume of gas, other than via expansion due to heat?
  19. I don't think you'll get very much airflow at all if you close the inlet and boost the outlet, as you're largely extracting against a sealed box. All you'll do is lower the interior air pressure slightly and draw in small amounts of air from around windows and doors (the main relatively leaky points in most airtight houses). That's why standard advice is to shut off the MVHR rather than boosting etc. I've seen inlets with intumescent collars, the idea being that the duct will close when the heat gets high enough. But frankly by that stage your smoke detectors should have been going off for several minutes and you and your family should have left the house. Have a look at the different types of detector. Some are better at detecting different types of fires (eg, smouldering). Given your apprehension (natural given your experiences), consider going belt and braces with both types in or just outside each bedroom, plus kitchen, utility room and anywhere else you need. Consider whether you want a sensitive smoke detector in the kitchen though - too many false alarms.
  20. No steel? Is it fibre reinforced? I'd have thought you'd need one or the other as an anti-crack measure.
  21. Right, gone back to source (invoice). I knew it wasn't 22mm - it's 28mm, like you were using. I can't imagine how difficult it would be to work with the JG Speedfit stuff if it's noticeably stiffer than the Hep2O!
  22. Actually, now I think about it, it's 32mm. Forgot this was for the ASHP runs
  23. 22mm Hep2O barrier.
  24. Is it the same thickness/stiffness? I used barrier pipe for a long run from our ASHP and it's surprisingly inflexible. It also tenaciously wants to hold onto the curve it acquired while coiled up. Perhaps non-barrier would be the same, but I didn't use any of that myself, so can't say.
  25. Perhaps oddly, the cheapest source for our Fakro roof windows was our local Travis Perkins (who we had a pretty good relationship with at the time). Also, Fakro's sales department were very helpful - might be worth a call to them to ask about distributors and who's likely to do them for the best price in your area.
