jack
    41
Everything posted by jack
  1. Yes, sorry, forgot to mention that one!
  2. Someone will correct me if I'm wrong, but if there's no tree preservation order on that tree, then the mandated protection scheme only counts until a completion certificate is issued for the house. Once you've got that, you can just remove the tree at will.
  3. Actually, we do have a circulating pump on our UFH manifold (I assume this is the one you're talking about?) This setup works fine to keep the house comfortable over winter, but I'm not convinced that the current setup is optimal. I have no idea, for example, how often or for how long the ASHP comes on for. I plan to look at it before winter later this year.
  4. I've heard of applying to the council for a demolition licence, but not this. I think the photos + invoice should be enough. If they really want to push it, cancel the direct debit and dare them to take you to court over it!
  5. When we had the ceiling in our bedroom re-done following the leak, it was repainted in a different paint than what we originally chose. It's still allegedly matt, but it's clearly got more of a sheen to it than the original stuff that's in the rest of the house. At this time of year, the bright morning sun makes this slight sheen really obvious, and I can see the (very) minor imperfections in the plaster. Put your foot down - the ceiling will be matt, or you'll slash her inflatable jacuzzi
  6. No help to you at all, but I personally can't stand non-matt finishes on ceilings. They drive me to distraction, as well as highlighting every little flaw (not that there'll be any on this ceiling, of course ).
  7. Welcome to Buildhub!
  8. Problem might be that it's a small market, and 3 for sale effectively floods said market. Amazing cars though - ahead of their time in many ways.
  9. You definitely feel the drop in temperature when you walk into ours on a hot day. The only thing we've done for cooling is to keep the external blinds closed and to throw all the windows and doors open first thing every morning to get rid of as much heat as possible before the outside temperature gets too high. Once that's done, the windows and doors are closed to keep the heat out. I'd love to do an overnight purge, but insects are a bit of an issue. Long term, we'll definitely be doing something with insect screens on bedroom windows and possibly a security screen door on a downstairs rear door so it can be left open for stack ventilation overnight.
  10. Under no circumstances should you wait until the bathroom is finished before starting this!
  11. Welcome back, great to see you at Build hub. It looks like we have a new took-the-longest-to-find-us-after-ebuild nominee! Exactly the right attitude imo.
  12. Welcome! We're probably not far from you (Surrey/Hampshire border). Lovely part of the world!
  13. Don't be so modest. Soz, just deleted the image before reading your comment. It was there because I was going to suggest you get a tool belt before you said you had a nail bag. Deleted it in-text, but forgot to delete it as an attachment.
  14. Can you tie a cherry stalk into a knot with your tongue?
  15. After 9 years, I hope you have an industrial vacuum cleaner! Ours can be vacuumed, and we got about 18 months of out the filters (vacuuming every 3 months or so) before they started going fluffy and didn't seem to clean up that well. I bought a couple of replacements and will buy some filter media to cut and attach to the original frame when I remove the old filter media. I now have three pairs, so each time I can put in a new/reconditioned one, and still have a spare to tide me over until a recondition the one I've just taken out.
  16. We have low temperature underfloor heating (typically the floor is around 21-22 deg C). The only carpeted room downstairs can feel a little cooler than the rest of the house, presumably due to the fact that the concrete elsewhere is a much better heat conductor. If your wet UFH is reasonably high temperature, the carpet will be less of an issue.
  17. I feel for you mate, this sounds very unpleasant. However, these things do happen in the course of a build. As you say just above, everything can be fixed. Soil pipes are often not quite in the right place, and so onsite adjustments aren't that unusual. If it's right in a corner, even being a few tens of mm out might be enough to require some sort of adjustment. That said, I'd have thought a pause to double-check would have been an appropriate action to take when this was noticed. Had they not measured the positions of soil pipe (etc) before starting the erection? That alone should have given them an idea of orientation, unless your soil pipe is dead centre of the building. Re: external membrane, as others have said, this stuff gets knocked around pretty badly during the build. I think replacing all of it is a fair bit to ask, although given how many errors they've made by this point, they really do owe you. I think you definitely want the internal boards to at least be flat, although the odd ding is no big deal. As Jeremy said, if you have pumped insulation, your inner board work is punctured all along every external wall anyway. I'm less sanguine about the glulam. It was specced, you paid for it (or at least it's part of the agreed price), and unless there's a very good reason to replace it with the proposed alternative now, they should supply what's been agreed. Is it on show?
  18. Put in 50% and see how you get on?
  19. To a point, but longer also means more resistance. It'll work either way around - look at the arrows in this diagram - one end of the tube is stale air in and fresh air out (interior) and the other is stale air out and fresh air in (exterior). You do need to arrange things so that it's easy to guide any condensate to a drain. If tube inlet and outlet are as you say, then the shell inlet is fresh air from outside, and the shell outlet is fresh air to the inside of the house. One possible approach (not to any sort of scale): Orange is air from inside the house being extracted, blue is fresh air from outside. The other coloured blocks are fans. There's no reason why you couldn't have the branches both facing down - I just did it this way because I copied the layout of the unit above. If you tilt the right hand side down, condensation naturally flows out without the need for a separate condensate drain, although of course you'd need to figure out how to direct it somewhere if you don't want it just dripping on the ground. You'd also need to think about insect screens. The main thing that gives me pause about this whole project is how you're going to access the heat exchanger to clean it. I think this is an important consideration.
  20. Congratulations! Now comes the easy part
  21. The point is, if the others don't turn up, you can show the judge that it's perfectly clear what was intended. I wouldn't be starting from the point of view of it being ambiguous.
  22. Generally a lot easier when the other side doesn't turn up, of course!
  23. Not bacon sampling methods?
  24. Welcome, Natalie! As you've probably seen, plenty of us have had problems with doors and windows, so ask away in the relevant sub-forum and someone should be along to help shortly.
