jack
    41
Everything posted by jack
  1. Fair enough, and a good idea when you have general moisture problems that you want to help dry out. However, if condensation was caused by the MVHR as you originally thought might be the case, then running it faster would potentially make it worse. Do you have any idea where the MVHR ducts run in the ceiling? You have damage on both long sides of the rooflight, but it seems very unlikely that there are MVHR ducts on both those sides. Can't rule it out, but some other form of leak or condensation seems likely. You mention it dripping out today. Even if it's a form of condensation, I can't see how you could have so much of it at current temps and humidity in Manchester (20 deg C and 37% humidity right now, accordingly to Google). Phone up through a downlight hole seems a good way forward. Try and see if you can take a video with the phone's light on.
  2. My first question is why you're running it at this rate. My house is 289m2, with high ceiling downstairs (so a lot of volume), populated by two adults, two kids and a dog and we run ours at 100m3/h. In fact, for the first year I ran it at 50m3/h and that was fine too. As for the water, are you certain it isn't a leak around the skylight? That seems a much more likely scenario to me.
  3. Interesting. One of our showers has always drained slowly - wonder if it's something to do with this.
  4. Can you please explain this a bit more Nick? You say to go 50mm (which I think is smaller than what's in the first picture), but then say to "oversize" to get an air break. Also, is "stohon" Welsh for something? Doesn't look like it:
  5. The problem with all of this is that these are complex systems. It may be that there's some sort of dynamic restriction somewhere further down the pipework that's actually getting the benefit of the air when it's allowed in. One problem is that any such restriction is far from where the air is being admitted, and there's a lot of air volume to reduce in pressure to get the durgo to open. You also have a relatively low water flow (compared to something like a draining sink or bath) relative to the size of the waste pipe, so it likely won't cause much pressure reduction due to air entrainment (moving water drags some air along with it = reduced pressure upstream due to removed air). I initially thought that putting a trap below the durgo would mean that the volume on the pipe side of the durgo is much reduced. That assists one side of the equation. The main impact would be to decouple the waste above from the part below the durgo, with a corresponding reduction in air volume, but as I think harder, I wonder whether the impact of slowing the water at this point due to the trap might make this somewhat self-defeating . As @CC45 mentioned, it might also be worth dropping vertically from below the durgo then back across to the existing waste lower down. That will give you more water velocity nearer the durgo, and hence greater pressure reduction to help the durgo open. As above though, these are complex systems. Given the fact that I'm just thinking out loud, it's probably best to ignore everything I'm saying and listen to those who have a better idea of these things in practice!
  6. Not quite - I was suggesting putting another trap at that location and leaving the shower as it is. Picture's worth a thousand words and all that:
  7. Air admittance vales are at their best when you have a large slug of water draining all at once - think toilets, sinks (if draining from full) and baths. In your case, you're draining something that will generate a steady but relatively small flow of water. It therefore won't build up a slug of water in the vertical pipe to which your durgo attaches. In that case, the only source of the vacuum is whatever happens below the vertical run shown in your pic. Because that's so far away from the durgo, the large volume of air in the circuit (all legs) between the durgo and the bottom of the pipe may be preventing an effective vacuum from forming. Whatever low vacuum is building may be enough to slow drainage but not enough to allow the durgo to open properly. The vacuum may also be intermittent if whatever's causing it down below isn't continuous (eg, if it periodically allows air to burp up from further down the pipework), which will again prevent the durgo from operating correctly. If any or all of this is true, putting a trap directly below the "T" to the durgo might help, and isn't too expensive or disruptive an option to test. Optionally, you might put an elbow on the left hand pipework to take it over to underneath the durgo pipework, then put a trap below with vertical up to the durgo, and then another elbow back to the existing vertical pipe (or maybe vertically down to wall, then across to the left lower down, if that isn't in the way). That would drastically reduce the volume of air in the circuit within which the durgo is operating. Please note that all of this might well be nonsense, as it's just based on me thinking about how all this might work, rather than having any real knowledge of how it does work!
  8. From memory, I actually spoke to them (or one of their members) at ecobuild after I joined, and got the distinct impression that they were only interested in commercial members and business to business discussions/transactions.
  9. Ah yes, now it's coming back to me. I joined the AECB and received the magazine that way. I naively thought that they'd be interested in having aboard people like me who were interested in passivhaus and low energy buildings, and who were about to build one. Bear in mind this was 5 years ago, when the profile of low energy buildings was much lower. It turned out they couldn't have been less interested. The forums were very quiet even then (I think I joined to access the members only parts of the forum, but they weren't much better than the public section). On the whole I found the whole thing cliquey and insular, so didn't bother renewing the next year.
  10. This seems to have been their model for a while. I first subscribed for a year about 5 years ago and continued receiving it for over two years. It just stopped at some point.
  11. Vertical battens, which fix through the outer board (of the outer stud) and into the outer stud.
  12. The equivalent of the brick/ block "cavity" is actually the ventilated space between the outer stud and the cladding or render board.
  13. It can if you run it too cold, yes. I only run 15 deg C water through the circuits, and the floor temp doesn't drop below about (I'm estimating) 18-20 deg C, so no risk of condensation. There isn't even a haze of condensation on the metal UFH manifold, so I think the floor is safe.
  14. Fair enough, although to some extent they should expect a change in circumstances when they sell someone a piece of their land!!!
  15. My underfloor cooling is working a charm - maybe that's why I'm so unusually relaxed!
  16. Couple of things (which you may already have thought about): Would high level windows (ie, lowest point say 1.8m) be acceptable, or could your neighbour still see in? We have a number of rooms with 2000 wide x 400 high windows that overlook our next door neighbour's garden, and they work very well. What about obscured glazing? Also, roof lights are great for light, but unless you have some form of blind, they also have a lot of solar gain in summer. In the wrong place they can also be quite uncomfortable to stand/sit under at certain times of the day.
  17. Moderator hat on for a moment: This thread is drifting a long way from being productive. Everyone - and I mean everyone - please take a chill pill and stop trying to prove whether you're right or wrong. There's a topic here, so let's try and stick to it for the original poster's sake.
  18. Bear in mind that there's a big difference between a timber frame and a brick/block with cavity on a raft. Brick and blockwork adds a lot of weight, so the slab needs to be engineered accordingly. Do you have a construction type (eg, timber frame, ICF, blockwork, etc) in mind yet? Here's a section through the raft we have (which is the same as Jeremy's):
  19. I don't think anyone said price literally doesn't matter if it's "your forever house". What was said is that your planned length of ownership will have an impact on how careful you need to be with the finances. I don't think that's an unreasonable position as long as it isn't taken to extremes. If you aren't stretched and you expect to be there for 20 years, you genuinely can spend more than if you hope to sell in a few years and trade up (or move for schools, or retire, or whatever). I agree with the sentiment, but I don't agree that a lack of consensus about one complex issue involves us falling short of this general goal. I think your comments about recklessness etc have been useful counterpoints to the other views that have been expressed (and you have to admit there have been a decent variety). Those views, and the associated debate, are the only sort of "useful advice" that the forum can provide on a topic as complex and subjective as this. Perhaps this topic has reached a natural pause until the original poster has had a chance to digest and come back with any other comments or questions.
  20. Edited to add: Welcome to Buildhub! Could you dig out the old concrete, lay a decent amount of insulation, and drop a screed on the top, maybe with underfloor heating? It's a fair amount of manual labor, but it wouldn't be hugely expensive, and the result would be much better than just dropping more concrete on top of what's there. It'd also be a lot lighter. @Onoff did something like this and documented the process. I'll see if I can find the thread later when I'm at my computer.
  21. The following photos are all from the same area in the house earlier today (took them but didn't have time to post). It's actually really hard to capture the real-life effect of the concrete! Relatively speckled area: Less speckled (+ crazy dog): Transition between speckled and less speckled area: Another view:
  22. You can take quite a bit off with diamonds, starting with a coarse grind and working your way finer once you reach the required depth. We have a "light" grind on our polished concrete floor, which barely shows pieces of aggregate. It isn't perfectly even - the aggregate shows up a little more in some areas than in others - but we really like the effect. It certainly doesn't have a terrazzo look about it (my wife was categorically against too much aggregate being on show). Can you experiment with gently grinding/polishing a bit of the slab that'll be out of sight and see what you come up with? It may be that you can get away with some sections (maybe per room?) with a bit of aggregate on display and other rooms with no aggregate showing. I'd personally be hesitant to scrabble back the entire surface as a first step.
  23. @lizzie, I checked with the missus - turns out she made a mistake inputting the order! No biggie - the spare shelves we have now can be used in the wardrobe for which we're about to submit another order.
  24. 9.5m x 5m is not "large-ish" - that's a properly large space, and the ceiling height needs to be proportionate imo. Forget 2100 and 2400 imo. We have 2850 ceilings downstairs, and I wouldn't go much less than that in a reasonably large area. If you go for a touch over 3000, you can use 600 wide boards in conjunction with standard boards to reduce cutting. A friend of ours has 2400 ceiling heights in their new large open plan kitchen and dining area and I think it feels claustrophobic.
