jack
    41
Everything posted by jack
  1. I feel for you mate, this sounds very unpleasant. However, these things do happen in the course of a build. As you say just above, everything can be fixed. Soil pipes are often not quite in the right place, and so onsite adjustments aren't that unusual. If it's right in a corner, even being a few tens of mm out might be enough to require some sort of adjustment. That said, I'd have thought a pause to double-check would have been an appropriate action to take when this was noticed. Had they not measured the positions of soil pipe (etc) before starting the erection? That alone should have given them an idea of orientation, unless your soil pipe is dead centre of the building. Re: external membrane, as others have said, this stuff gets knocked around pretty badly during the build. I think replacing all of it is a fair bit to ask, although given how many errors they've made by this point, they really do owe you. I think you definitely want the internal boards to at least be flat, although the odd ding is no big deal. As Jeremy said, if you have pumped insulation, your inner board work is punctured all along every external wall anyway. I'm less sanguine about the glulam. It was specced, you paid for it (or at least it's part of the agreed price), and unless there's a very good reason to replace it with the proposed alternative now, they should supply what's been agreed. Is it on show?
  2. Put in 50% and see how you get on?
  3. To a point, but longer also means more resistance. It'll work either way around - look at the arrows in this diagram - one end of the tube is stale air in and fresh air out (interior) and the other is stale air out and fresh air in (exterior). You do need to arrange things so that it's easy to guide any condensate to a drain. If tube inlet and outlet are as you say, then the shell inlet is fresh air from outside, and the shell outlet is fresh air to the inside of the house. One possible approach (not to any sort of scale): Orange is air from inside the house being extracted, blue is fresh air from outside. The other coloured blocks are fans. There's no reason why you couldn't have the branches both facing down - I just did it this way because I copied the layout of the unit above. If you tilt the right hand side down, condensation naturally flows out without the need for a separate condensate drain, although of course you'd need to figure out how to direct it somewhere if you don't want it just dripping on the ground. You'd also need to think about insect screens. The main thing that gives me pause about this whole project is how you're going to access the heat exchanger to clean it. I think this is an important consideration.
  4. Congratulations! Now comes the easy part
  5. The point is, if the others don't turn up, you can show the judge that it's perfectly clear what was intended. I wouldn't be starting from the point of view of it being ambiguous.
  6. Generally a lot easier when the other side doesn't turn up, of course!
  7. Not bacon sampling methods?
  8. Welcome, Natalie! As you've probably seen, plenty of us have had problems with doors and windows, so ask away in the relevant sub-forum and someone should be along to help shortly.
  9. The caveats are often used by the ignorant as evidence that scientists don't know "for sure". And then you have the flipside, where papers report about some new health threat caused by (making something up here) bacon increasing stomach cancer, until you look at the details and realise it's a 5% increased risk on an already unusual cancer.
  10. I personally doubt the book has done either of those things to any significant extent, but I haven't read all of it, so you may well be right. Even if it is everything you say, some of the conclusions didn't ring true to me, and more importantly I wasn't particularly enjoying it at the time, so I stopped reading. Google straw man. Of course it is. Only the ignorant and/or mental think otherwise.
  11. Underlining the snarky bits, you actually called it:
  12. I suppose so. Certainly has the advantage of simplicity, even if the plastic in Coroplast is perhaps a bit thick.
  13. There are commercial (domestic) MVHR extractors that do this. Some work on regeneration (single fan that changes direction periodically, with a heat absorbing labyrinth in the single path), but I believe there are others that just blow the incoming air in a direction away from the outgoing. Not ideal, but it'll work to an extent.
  14. There's not a huge pressure difference in this situation, and it's air/air, so I don't think perfect sealing is required. A small amount of leakage probably wouldn't hurt anyway, as there isn't a big temperature difference between any pair of points on the adjacent paths in a counterflow heat exchanger (for example, as I understand it, a 90% efficient exchanger when it's 0 deg C outside and 20 deg C inside will only have at most a 2 deg C temperature difference at any particular point. That's why you need so much surface area and reasonably good conduction for the tubes). You can seal the "straws" to the plates they pass through by pouring in a sealant (maybe use a temporary collar, or better yet surround it with a seal that will fit into the pipe you're using). 15mm pipe feels a little big and thick. Ideally you'd use a larger number of smaller, thinner-walled tubes. Aluminium might work (it's less conductive than copper). Plastic might work (you want it very thin, like drinking straw thin). All complete and utter speculation on my part, and again I'm definitely not saying this is something you should do!
  15. Just to confirm, we're talking about the housing for something like this: Heat exchange is via the internal pipes, which would likely be the size of drinking straws. 110mm drain pipe was actually my first thought for the housing, and has a few additional advantages including the availability of fittings and the fact that it won't retain any condensation that might lead to mould. My initial thought was that it wouldn't be big enough, hence my suggestion of something larger, but now that I think about it, it's only for a single room, so I expect drain pipe would be fine. That said, I agree with @PeterW that this is a solution looking for a problem. You'll need a lot of ductwork (two full paths: in and out), plus two fans, and somewhere to drain condensate to. Seems like overkill for a single room.
  16. If you're serious about it, I have some closed cell PE tubing left over from our MVHR installation, which might be of use as an outer housing for a tube-based unit. I think I have a length of 180 and another of 200 or 220. Happy to send it your way if of interest.
  17. Or alternatively, it probably isn't possible to summarise 70,000 years of history while also sketching out a new general theory of humanity in a single book, without a significant risk of over-generalising. Yup, that rings a bell. And during that period, people were murdered for heretical theories based on simple factual observations. The scientific method has a lot of flaws, but it's still the best approach we have (one of those "it's the worst approach except for all the others" situations). If anything, the problem we presently have is that the general population doesn't understand or accept much about science. If they did, then they'd do a better job of understanding science's limitations, and potentially wayward scientists would be kept honest.
  18. We're doing the same maths with our garden. We spent a lot of money on plants at the end of last Autumn. We lost a few to the odd warm-freezing-warm-freezing periods we had earlier this year, so spending some money on water to get us through this hot dry period makes good financial sense. Most of the plants should be well established by the end of the summer and shouldn't require much watering from next year. It's also spurred me to start planning rainwater storage to be installed before the end of Autumn.
  19. Do you know what your water pressure's like @Temp?
  20. If they quoted 89%, it's counterflow. Anything with more than about 70% real world efficiency will necessarily be counterflow. Incidentally, counterflow is 180 degrees. It's crossflow that's 90 degrees.
  21. The first two drawings here show the difference. In a counterflow arrangement, the fluids move in opposite directions. Theoretical efficiency is 100%, although more than 90% in the real world is doing well. Crossflow means the fluids move at 90 degrees to each other. This simplifies the connections in a device like that shown above, but theoretical efficiency drops to 75%. A parallel flow, where both fluids are moving in the same direction, is at best 50% efficient. The one linked above is crossflow, but with a double-back path (blue arrows) that will tend to bump the theoretical efficiency up from 75%: To turn this into a full counterflow unit, you would change the divider strip layer to look like this, with the parallel dividers being parallel to the coroplast tubes: I'm not sure that a lack of sealing in the channels is likely to be a big issue, but I agree about the thickness. You could always use flat sheets of thinner material and alternate the pattern above with the pattern below: The problem is that anything thin enough isn't going to be very rigid, so might be annoying to work with. Some sort of jig would help, and once the first few layers are done it should stiffen up and make things easier. Sounds like a lot of work, but hey, it's not like you've a bathroom to finish @Onoff Another diy option is to make something like this, using thinwall plastic tubing: Make the (white) plates out of something like XPS (perhaps melt holes through). To be honest, I love thinking about this sort of thing, especially when I have a big bit of horrible work that I'm trying to get done today(!), but I'm less sure about relying on diy solutions for bringing fresh air into my home long term.
  22. Lovely, lovely stuff.
  23. Bear in mind that this is a hybrid counterflow/crossflow design (more the latter than the former). I'm not sure how you'd calculate efficiency, but I imagine you'd be lucky to get 60-65% in the real world. Not much needs to be changed to turn this into a counterflow exchanger, which would likely be at least 10% more efficient.
  24. I did quite a bit of research on sprinklers systems recently, and the Caber Colibri system looked decent for lawns. Jeremy has their drip irrigation system and spoke highly of it in my earlier thread. It's one of the options in PeterW's link above.
