Crofter
    11
Everything posted by Crofter
  1. I had fun with some timber merchants the other day. Managed to persuade one company (who have forklift offloading so for my site quite an advantage over the HIABs of the other guys) to come down to within £10 of their competitors. Then agreed to go with them and reminded them that I had several hundred pounds in credit with them. Thought it best to leave that wee nugget of information out until after the haggling was done
  2. Thanks for that, and welcome to the forum! Looks like a flymo is not the panacea I was hoping for. Will just have to wait until my son is old enough to lift the strimmer, hmmm that will be about 12 years or so
  3. I guess your location is fairly sheltered? Personally I would be looking to make the covered area more enclosed. It's definitely a rather complex design!
  4. Beinvenue and welcome to BuildHub! The details are definitely devilish. Why did you choose Normandy, by the way?
  5. Adding bottled LPG is no biggie- I did it in my last house. Paving slab to sit two 47kg propane bottles on, a chain to stop them falling over, and a hole through the wall for the CORGI guy to come and charge me £130 to stick a pipe through and screw it on to the cooker. The bottles lasted about 18 months each and cost about £50 to refill, IIRC.
  6. I'm likewise running off 100m of extension reels- have had no problems with the compressor but I forget what Hp rating it is. It's a cheap Screwfix 'Impax' one that was on offer at about £60.
  7. I'm sure I heard somewhere that farmers are encouraged/incentivised to cut crops in such a way that they leave an escape route for any beasties living amongst it- so start at one end and work in rows, rather than cutting the perimeter first.
  8. And I can happily report that it does run my (1400w) pressure washer. A wee bit underpowered but the gennie adjusts to the load quickly. It will do what I need it to do anyway.
  9. I've literally just fired up the Lidl genny for a ten minute test run. Compared to similar little 4 stroke gennies it seems to run very smoothly and isn't too noisy- then again I'm comparing it against various borrowed secondhand examples which were well past their prime, I've not had the luxury of a brand new one before. I'm away to test it with my dinky Halfrauds pressure washer just now, which is going to be borderline as it will probably be drawing too much power...
  10. Or leave the steak attached to the cow and problem solved. This thread is starting to go round in circles...
  11. Yeah but you're cheating, your island is *much* flatter than mine!
  12. The geese are no more, and very tasty they were too! 2016 is the year of the bairn and the build, so we don't actually have any stock of our own at the moment. I could borrow some of the sheep which are on the croft (they belong to the neighbour) but moving them would be more hassle than just getting the mower out. Too many fencing projects before we can get stocked up, so the croft itself is on the back burner. I have tried to gently persuade SWMBO that it could be her wee project, but apparently babies need lots of time. Who knew?
  13. My back garden is a PITA to mow. Very steep and undulating. I have tried tackling it with my normal cheap petrol mower, but just getting the thing up the banking feels like enough work for one afternoon. I could strim it all and put up with the unevenness and have to go around raking uo the grass. Would a flymo be a terrible idea? I do treat mowing the lawn as one of these things that should be done as little as possible because life is too short. So it is always like a jungle when I finally get around to it. Last year, I avoided the problem entirely and bought half a dozen geese
  14. Welcome aboard! You are right about things changing- most houses built 30 years ago might struggle to comply with current building regs. I know a few retired joiners who were surprised that I'm not just nailing plasterboard and plywood to either side of a 4" stud, as for a while that was the only way to build a house!
  15. In our previous house, we installed a 'B' grade range cooker that we picked up brand new on eBay for £500. Never found why it was graded stock- looked perfect to me. It was cheaper to do this than a smaller integrated cooker would have been, because we had fewer cabinets and less worktop to buy.
  16. It's an interesting concept, but my first thought was that those doors would never work in the winds we get up here! 175kg for a 3m door sounds quite light. My 2.4m door is 250kg.
  17. It's probably just fine. I imagine the engine is similar to a marine diesel, i.e. simple and robust. By far the most likely source of problems will be fuel. Old diesel can collect condensation from the air, and can get 'diesel bug' which produces horrible black sludge. So check the filter and the fuel. If it's white diesel, stick it in your car and buy fresh stuff for the gennie.
  18. The Lidl gennie is an inverter one, max output of 1200w, 1000w continuous. I don't know if it will come anywhere close to being able to run a fridge or freezer, I take it I won't damage anything by trying, though? We probably have more in our freezers than most people, as we are three hours from Inverness and tend to stock up. Hence a full size freezer in the kitchen plus a second chest freezer in the shed.
  19. This brings to mind the old adage about professionals vs. amateurs: "A professional does the worst job he can get away with; an amateur does the best job he can". I did my own percolation tests and my results showed that I couldn't successfully use a normal soakaway system, so I ended up ploughing about 17% of my total project cost into a proprietary drainage solution. Perhaps if I had contracted this whole thing out, I would have found a 'bloke with a shovel' who would have written whatever numbers he felt were best on the form, and then built me a conventional system... which would have backed up in the first rainy spell and left me with effluent flooding out of the ground. Mmm, nice!
  20. Our last significant power cut was last winter- 37hrs. The novelty of playing piano by candlelight and sitting around the woodburner was starting to wear thin. I assume that for houses with MVHR, you would just crack open a window or two? I have just bought a dinky little petrol generator from Lidl which would at least give us some lighting. Have yet to test it on anything bigger like the freezer- it's surprisingly hard to find information on the wattage of these things.
  21. Looks good! Is the PV for the shed itself or is it on FiT connected through your house?
  22. Did I catch a glimpse of your hut on Landward the other day?
  23. The 3mm gap is actually printed on the boards. I found, though, that the OSB was slightly undersized and it all worked out just fine. So don't use the OSB as a template to build the wall- use a tape measure!
  24. Welcome aboard. Three projects at the same time? That's impressive
