Everything posted by Crofter
Have finally decided on a treatment system- a solvent based preserver followed by an oil based protective layer. Was medium priced but, crucially, a low cost per litre. My rough sawn boards are now stored indoors and I reckon they will drink up as much treatment as I can be bothered brushing on. I reckon that some of the more expensive options could have gone nowhere near far enough and I'd have ended up buying additional tins, so I got a bit scared of the potential cost. Anyway, next question: I'm currently sorting through all the boards to grade them. Some are perfectly good but have sizeable resin pockets which detract from their appearance. I expect that these will eventually melt away in hot weather, but how are the boards going to take to their preserver and oil when they have so much resin in them?
Thanks, I'm inclined to go this route as even though it might look a bit rough, I would expect the larch to last longer than e.g. dressed pine or cheapish ply. To do it in marine ply would be a couple of hundred quid which I have not budgetted for.
Is there anything wrong with just using a polythene vapour barrier?
Revisiting this as I need to make a decision soon. I was mulling over the idea of just doing the fascias in rough sawn larch, the same stuff that I am cladding the building in, and will likely also use for the barge boards (well, the little bit of board that will visible beyond the steel L-profile that finishes off the roof ends). The rough sawn larch will also be used around the windows as reveals and header. I'm treating everything with a two stage system comprising clear preserver and oil top coat. I'd have to join two of my cladding boards together to get the required width- I have a rather underused router that I could maybe use, or maybe I should just buy a biscuit joiner thingy? Or of course just tack a joining plate onto the hidden side of the fascia but that's not so neat really. Or maybe it will look a little bit too rough n ready and I should use something else?
If you take it to its logical conclusion, consider how well a heating system would work if all the water in the pipes was replaced by air. In theory energy in is energy out, but we all know that is would simply not work well at all. Efficiency matters.
Does it improve the heat capacity of the water, therefore boosting efficiency?
Wooden Window Frames - which wood?
Crofter replied to LeanTwo's topic in General Construction Issues
Planners are not interested in enforcing building regulations- that's the job of building control, who are a completely separate entity! Hence as you say the requirements pull in two different directions. 'Modified' timber means an almost semi-synthetic material, which started life as some form of wood but has been treated either through application of heat or via a chemical process (e.g. naturally occurring oils, acids etc). These are a fairly new invention and could be a big thing in the future, but they are expensive. Engineered and cross laminated timber are a completely different beast, being normal wood that is shaped and glued together to create something stronger and more dimensionally stable than a single piece of wood. -
I vaguely remember some shenanigans around the time that the first SNP government tried to introduce LIT, and that a big chunk of money was going to be lost out of Barnett if it went ahead. Maybe somebody can remember the details. At the time I recall the Lib Dems also supported the concept, and I was personally a big fan of it. Shifting taxation towards income seems inherently quite appealing as it avoids the problem of e.g. the little old lady in a big house who has no income... and on a practical note, those with income *can* pay, whether they *should* pay is a matter for personal opinion!
I think that statement could be a bit misleading. The OP has already said that he would be adding internal insulation as well. Also, do you mean 'too small to pass building regs' or too small to meet some other standard? And of course it depends on what type of insulation is inside that frame. (Not having a go, but just wanted to point out that there are a lot of variables to consider).
I wonder if people from different ends of the political spectrum could get behind 'build to let'? Replace the sold off council houses with new builds, capital comes not from the LAs (who don't have any money) but from the private sector (where there are cash-rich people getting 0.1% interest on their savings). This is fundamentally a more sound approach than 'buy to let' as it enables creation of new housing.
Welcome to the forum. The insistence on separate little panes is going to be a pain (sorry...) as it will cost more and leak significantly more heat. I'm no expert of different species of wood, but the list you give is a very wide range in terms of cost. Pine, redwood, and douglas fir will all be comparatively cheap but less durable than, say oak, which will be much more expensive, in my experience. As an aside, I wonder what your planners wood make of a modified wood like Kebony or Thermowood? -
I did ask my mate for a loan of his planer thickenesser, but when I told him how much I needed to do he went all sucky-teethy-shaky-heady and muttered a lot. So I got the impression that it wasn't feasible. Then again, I've never used one. There's about 35m to do.
I had been hoping to obtain some planed larch for my fascia boards, but unfortunately this is proving tricky (BM will not get me the small quantity that I need). The rest of the house is to be clad in rough sawn larch, which I think will look a little too rustic for the fascias. The windows are alu-clad and the roof is to be steel. What are my options? PVCu is probably out of the question as it will look wrong, IMHO. I understand that aluminium is an option, but I have not obtained prices for this yet, and I have the feeling that it is designed to overclad a timber board. I did look for steel, as I thought it would work well if I could get it to match the finish on the roof sheets, but have not found any yet. What about dressed pine? I guess it would need a very good treatment system to give it any sort of useful lifespan. WBP ply? I have a vision of it going all wobbly between each rafter, but maybe it would be OK?
First flooring sag - what is acceptable?
Crofter replied to readiescards's topic in General Flooring
Assuming it is 22mm chipboard, it should be OK up to 600 centres. But, as others have said, that amount of water is NOT OK. -
Like any problem, costing is easier if you divide it into chunks. Site specific services etc- absolutely no point using someone else's figure here, you need to get quotes from the elec, water, gas etc as applicable. For sewerage, I think you mentioned that you would be off mains, so you need to dig some holes and do some percolation testing to get an idea of what options are feasible (my system ended up about double the budget that I had hoped for, entirely down to my ground conditions). Also, access/driveway- will you need to buy in material, how long will the drive be, etc. Will you need special founds like a raft or piles, or will normal strip founds do. This is the hardest bit to cost out. Basic shell- this is easier to cost out, and you can read up for general ballpark figures. Depends largely on construction type, and how simple the design is. Fit out- this is where the spend is entirely up to you. Some people spend £50k on a kitchen, some spend a couple of grand. But the costs are pretty much under your control.
Welcome aboard- you're in the right place! Quite a few of our members here bypassed architects altogether, some went for architectural technicians instead, others not even that. Stick to your guns with what you want, especially on the technical side. Good luck and keep us posted
I did a back-of-envelope costing for a 4.8x6m garage, built in 2x4 framing, galv roof, larch cladding same as my house. Came to about a grand for the materials, plus whatever base it would need, plus door. You could use a cheaper roof, and cheaper osb in place of the larch.
Interesting topic. My wee house will have no boiler or central heating etc, so instant electric is the way to go, I think. Question is just whether to fit a single Stiebel Eltron and tee everything off that, or to fit an elextric shower and separate units for the basin and kitchen sink. Veering towards the first option as it will be cheaper and probably simpler, but will it constrain me to a max water temp of 38deg, which is a bit low for the kitchen sink?
I'm going to make a shed out of pallets.....
Crofter replied to ProDave's topic in General Self Build & DIY Discussion
Very good. Puts to shame the one I threw together in a day to house some geese (I ate them, and it now houses a lawnmower, which is relatively safe as I do not have a big enough oven for it). I was fortunate enough to find my roof out on the hill- a piece of steel roofing which had blown off someone's shed and travelled half a mile or so. It was a bit bashed about, some denzo tape sorted the leaks though. Have you painted that shed with something? -
Potentially daft idea... I wonder what it would look like if the first layer of boards were black (either scorched or painted with barn paint), then the top layer treated with a clear oil. So you would see 4" of wood, then a 2" 'gap', repeated as a pattern of vertical stripes.
Afraid I have to agree with the others. I've got a Yardmaster steel shed/garage which was certainly a cheap (c.£600) way of getting a decent bit of covered storage, but it was an absolute pain to put up, very flimsy, and leaks like a seive! I could probably have built the same sized one in wood, with a galv roof, for half the cost.
Wow. Your ground floor is over ten times the size of mine.
Of course, technically the lower powered the kettle the more power it uses to boil a given quantity of water, because you have to consider the standing losses. It only works if you are trying to modify behaviour, by making kettles so slow that people stop putting in more water than they actually need.
Health risks associated with passive houses
Crofter replied to K78's topic in Energy Efficient & Sustainable Design Concepts
This is a really interesting discussion with a lot of experience on both sides. Hence plenty of anecdotes to back up points either way- which is natural, given the huge number of houses that are out there. It seems to me that passive houses which are either built or specced wrongly are entirely possible, but perhaps the biggest danger is that the occupants do not understand the house and equipment like MVHR. However, it also seems likely to me that such people are unlikely to be on this forum and participating in this discussion, so what we do have is people who have thoroughly researched their projects and feel defensive of the concept as a whole. -
Old pallets are a nightmare, rust twist nails do not want to come out. In the past I've resorted to using a small hole saw to drill around them and just leave them behind- it does make it look as though you have a mouse infestation though. if it's just for firewood, the best technique is to bounce the whole thing off the ground, hitting each corner in turn, until everything is so loose it just falls apart. Them fire it all through the table saw (mind those nails!) into the waiting wood basket. I can turn a pallet into an evening's firewood in about five minutes this way. The only problem with burning pallets is that I keep coming across bits of wood that are too nice to burn...
