Help me pimp my eaves please!
MikeSharp01 replied to ToughButterCup's topic in General Self Build & DIY Discussion
Not 100% sure I can see what bit of the drawing refers to what you have photographed I am assuming we are looking along the rafter in the drawing view (rafter to SE spec...). Is that the gutter we can see the top of the photo? Sounds like insect mesh is going to be the solution if you need ventilation but you would need to create an approximately flat run to pin it to. -
Stop-valve key - trying to source and Intex 2 spare
MikeSharp01 replied to ToughButterCup's topic in General Plumbing
Traffic -on your lane or did they install the meter in the middle lane of the M6? -
Urgent MVHR help needed
MikeSharp01 replied to vivienz's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes between papyrus and instagram. -
Try leaving it off for a longer period, couple of minutes, just in case some residual voltage is lurking about in some capacitor in there. -
No Best leave it unless there is a clear reset button on the outside. -
Has the main unit got a reset button / switch hidden behind a tiny hole somewhere. Although looking at the message it implies that some communication blockage has occured there are no switches (network) anywhere in the system - is the panel wired direct to the main unit? -
Has it got / is there a flat backup battery somewhere and its lost its settings? -
Welcome to THE forum for self builders and like minded individuals. Sketchup is the best for the job you are looking at and can probably take you all the way, so give that a go.
Is a fixed Delta of 7deg really what is required I wonder. I would have thought that once you reach steady state I think I would expect Dt to be much less than that wouldn't I?
Is there a link somewhere.
I guess the trick is to show that times move on and that they accep things today they would not have accepted 20 years ago- although I can only speculate what that is. Seeing it another way it may be that such measures might be made mandatory so they form part of building control.
Has anybody thought to offer a technology led solution to this, and similar problems. Round here we have dozens of mirrors on trees opposite driveways which is a low tech solution but video could be used with screens and a very wide angle lenses or lidar and the like. On one of our cars the cameras have wide angle lenses that allow me to see both ways down the lane with bumper only a few mm out of the drive. I appreciate the challenges of making this sort of thing possible in all circs but I cannot see that it woukd not be able to help in many places.
Yes the camera takes up one pixel of the screen, so you don't notice it but it could be mega pixel itself although the basic tec is indeed single. Have a look here: https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.osapublishing.org/viewmedia.cfm%3Furi%3Doe-27-3-3731%26seq%3D0&ved=2ahUKEwiBwrK0lt3lAhXJUBUIHVFuBR0QFjAAegQIARAB&usg=AOvVaw1SgP7BXGnZWSlzlJAFifX8 It means you can look directly at the screen rather than a camera of to one side or above. I dimmly recal they are now working on multi single pixel which would make things even better.
Looks like fun what is needed is the 1 pixel camera in the middle of the monitor to make a great digital mirror.
Gottcha! .... about two years too late....
MikeSharp01 replied to ToughButterCup's topic in Insulated Concrete Formwork (ICF)
Is it about extrapolation or some such? Cos you know that correlation does not mean ..... -
Sorry what was the question again? -
As long as your services are in ducts, IE you can replace the cables and water / gas pipes without digging the whole lot up I cannot see a problem. You dont want to have to dig up your drains to get at the water pipe below or even dig up the water pipe to get to the drains, although I assume the drains will be above the ducts, do you!
We used a 300 wide trench and all our services are in duct. I did bury the water on the left, then back filled with 100mm soil and then laid the other three on the other side of the trench gas, comms, electric (left to right). The separation thing feels a bit daft as at each end they all get brought together in the building.
Heating System Basics...
MikeSharp01 replied to Mulberry View's topic in New House & Self Build Design
You have almost all the guidance you need on the heating system above, just the Sunamp or similar (not much) option to look at, but the Architect is another matter. We provacated a lot about our long list of architects. We wanted a passive house standard of build - loads of insulation, 3G Windows, very good air tightness etc. The problem we had was that all the PH experianced architects seemed to be designibg with a limited pallet and we wanted a modest home that makes a statement. l felt I could handle the energy calcs, I went on a PHPP training course, and that allowed us to engage an architect who had not done a PH before but who was prepared to let me be the PH consultant as it were. We are nowhere near finished but I am confident we have a great standout design that will meet the PH standard. -
Can you cut it or cut out a portion, use a joiner as the bracket or fit a clip and use two joiners to put the cut out bit back (might not look perfect but might get the job done)? Also you might find self adhesive gutter liner a help.
I have had some success with mole grips. You squeeze tight on the head and twist them out. I have a small pair for just such jobs.
