lizzie
    20
Everything posted by lizzie
  1. I spent a lot more than £2000psqm ex plot.....our budget was £2000sqm ex plot
  2. @Ferdinand good tips thanks @NSS can the sageglass be retrofitted into the Internorm frames?
  3. Lots of blind suppliers about but not come across these.....see they have a retrofit option that works on solar no mains wiring required.....I might explore that a bit thanks.
  4. Nice job well done
  5. I have TF with Larch clad and a couple of render walls too. All on the frame no block
  6. @Amateur bob its a bit like groundhog day! I think answers to the questions you are asking here have already been given in your earlier posts? I think you need professional advice about the timing of the plot transfer. Go and speak to your lawyer and accountant. Then when you see the way to go (and for your father the financial implications of how and when it is done) you can go forward to consider how to approach it and raise funds to build. Just as an aside personally I dont think you will build a 200sqm house for 200k budget to include everything.....planning and drawings, services etc all out of the 200k?
  7. Yes professionally done.....I spotted things that seemed a bit odd and questioned but was reassured, all cobblers. I should have probed further.
  8. Nice.....dare I look I dont actually need anything but I might just want something......
  9. Yep I found that sort of thing in our garage....and the inside of the fridge was the pits...so glad I didn't get one of those swanky welfare units installed would have been mightily upset. Interesting item on Radio 4 earlier, student housing....the comments about the use and abuse of nice property by students would equally apply to the builders welfare facilities iIMHO.
  10. In our area you just ring the refuse dept and ask for bins and they drop some off. Doesn't seem to tie in to council tax registration as we had them before and so did our neighbours doing a barn conversion further up the lane (they were living in a caravan)
  11. My calcs were messed up...nightmare...too late by the time I found out, yes I did question but was assured all was ok. I would have done external blinds as part of the build had I known. The film we fitted is helping no doubt about it but it irks that I had to do this instead of getting it right first time. Having been idly chatting about fitting aircon in some areas if not all..........not progressed further than idle chat at the mo.
  12. +1 for fitting the (automated) exterior blinds and retaining overhangs. I wish we had blinds but it is very difficult for us to try and retrofit them now.
  13. So pleased you have at least the beginning of the end in sight.
  14. Better than my lawn!
  15. Its looking lovely @Moira Niedzwiecka well done.
  16. @Onoff is this the measurement?
  17. If you have a hob with built in extractor e.g. Bora then you should be able to claim that.
  18. @Scottlchipsandpeas looks good - who did the tf?
  19. It was the the heat on the laminated glass that caused the issue for us with choice of (external) film. Lots of different films and different ones from Solarglass in the Sentinel range. We could not have 70 only 50. Its best to get your glass properly assessed if its anything other than the regular toughened.
  20. I had only one option due to laminated 3g windows. My supplier was excellent they went to a huge amount of effort to ensure they go the right film for us....other suppliers just said use anything but (high) risk is yours or dont use film at all...the guys I used went the extra mile or 10 for me. It is a film made by Solarguard who are part of St Gobain. It was the specialist dept at St Gobain that advised our supplier. As I understand it St Gobain provide the glass for Internorm. Luckily the one and only film for us also came in an extra wide roll so no joins (would not have had film if there had to be joins, no join is invisible) This is my spec sheet from manufacturers.....this film is for laminated glass, if you have toughened then it will be different film but this is the sort of thing suppliers should send you with the sample of film. Sentinel-Plus-SX-Silver-50-Sample-Page-0314SSX50OSW.INT_.pdf
  21. @JSHarris I agree with you on the overheating!
  22. Great idea, I look forward to following progress....love those glamping pod frames!
  23. Ive just noticed I have this black stuff starting around my mvhr vent. Its on white render so easily spotted. Is it Ok just to leave or should I try and clean it off? I have a metal grille fixed over the vent hole and would need to remove that to get at it. Vent is in the back alley so only visible if you go and look at the grille.
