Game, set and match.
Git.
Ok. With regards to screeds then I think you may get away with just screeding the lower floor ( kitchen / dining / living space iirc ) as there is little room to insulate AND screed. The subfloor is iirc 100mm concrete / B&B and we have about 60-70mm to play with on top. As @Hecateh is retired i'll favour turning that into a big storage heater seeing as the house will be 'lived in' rather than 'visited' eg not empty 9-5, this would be a better approach IMO. A nice comfortable background heat which will lend itself to the entrance level via the open staircase. Tres Bien. For the entry level floor I'm going to suggest either an 'overlay' UFH system or possibly ( cheaper option but still effective ) to lay battens, UFH aluminium spreader plates ( with 25mm of rock wool sat underneath to make the plates distended for good surface contact with the P5 ), UFH pipes, 18mm P5 flooring and then final covering ( Tile / Vinyl ). No wet stuff and no drying time = flooring down in record time. For the screed downstairs it'll just have to be left to dry, but we can use a semi-dry S/C ( sand and cement ) screed so drying time is minimised. My screeder is ok to travel so ill pull a favour and drag him out for a day . Not a huge problem as the kitchen will need fitting and finishing after screeding, during which the screed will be drying out naturally. If 3 or 4 of us go crazy I recon we could first fix the wiring in a day tbh, so just a team effort for that and job done. 'Start at 8, pub by 8' should be the drill me thinks. What more incentive would one need eh? Plumbing will be a doddle as its not exactly Downton Abbey lol.
Depends on how smelly you are when you get in from work cockles
Insulated block n beam.
Nickfromwales replied to Russell griffiths's topic in General Self Build & DIY Discussion
Yup. Some vital bits of info missing from the OP Deffo a good choice for B&B imo. Certainly WAY better than what I've seen to date. Any additional depth under the void where you could add more insulation to the underslung element ? I recon these would largely be down to poor fitting / failed observations of the basics. With a thicker screed ( concrete would be my preference ) you could easily fit a 6mm mesh into that layer to mitigate against cracking and also to give it some serious weight for the laying and compression aspect. Dry S/C screed wouldn't really cut it at such a thin layer as you could only fortify that with fibres and hope for the best. So. @Russell griffiths whats the depths / heights etc please !! Edit : you could possibly use a stainless mesh with thinner screed maybe. Are you having UFH pipes in the 'screed'? -
It reads ( to me ) that hot and cold pipework is customer supply, radiators already known, flow and return pipework is customer supply, and same with soil stacks. Everything should read 'supply and first fix' as all other supply items are stated clearly where its encompassed in the quote. Where there is a supply element its clearly and repeatedly stated. Time to double-check and get that re-worded accordingly?
What are your fabric and ventilation heat loss figures? Two I've just spec'd have worked out better going all elecric via PCM58 cells. No ASHP to buy / install / maintain / replace, no noise and no antifreeze to dump and replenish every 5 years or so at ~£500 a go. Oh and you don't have a big wart on your outside wall either. The SA are still a very good option if you compare closely what you get for your money. They're recent removal from sale of the PCM34's is a bit of a game changer for anyone with / intending to fit an ASHP I agree so they need to get that crease ironed damn quickly, but the PCM58's are still ( to quote a member ) "a very elegant" solution. 3-4 times the capacity for size compared to cylinders. Far lower losses. Modular boxes ( the 9kW and under fit under a kitchen worktop ) and no moving parts / components. 38,000 cycles and 3.8% degradation is bloody good from where I'm sitting. @Simplysimon Get the calculator out and see what your figures would look like if you needed no ASHP and could manage on E10. Reduces the cost of the SA units then to . You can buy a lot of E10 with the total savings !!
What size units did they quote / qty ?
It's an unanswerable question because of the quote being made up of mixed disciplines TBH. Ask for a quote for the oddities and the plumbing etc as two separate items and then we can work out what's what. Architects are wonderful folk, but when they put things out to tender it's usually via the straightest route. Not always the best route.
You can get all the advice you need here. Draw it out and study it, or Wunda ( for eg ) will design it for you for.........bugger all. Use the money you save to buy beer. A very important component of any build. Dilly Dilly .
I think they're just referring to normal soldered joints. If it were different it would say push-fit / press-fit / compression, but the method of soldering copper joints uses what we call "end-feed" fittings ( just regular copper joints to you and I ) so that what I believe they are offering. E.g. a pukka job. £20k for that doesn't sound crazy tbh, but very strange for a plumber to quote the guttering. Lead maybe but again a bit odd. Who is actually going to do that work ? The plumber or a sub-contractor ? If the latter then can't you get quotes direct to you instead of via a 3rd party? Ultra mods beat me to it, not in the quote so labour is a LOT of the quote. Where did you get the £45 figure?
Is a single block inherently air leaky?
Nickfromwales replied to epsilonGreedy's topic in Heat Insulation
@tonyshouse blog will serve you well with the old heavy / wet build approach. If im ever lucky enough to build, there won't be a brick or block in sight. A decorative stone facade maybe, but no block internal layer that for sure. -
You need a bend and then the branch, or the branch then the bend. Don't use the branch to make a 90o turn in the run as it's a stalling point and a big no-no. -
Pressure testing is a no brainier. ? -
Could have yes, what with the short days and spare time we had
Exactly. Cut out the middle man .
Had a £13k showroom kitchen for less than £6k. That beat the customers B&Q quote of £9.6k for a bag of shit kitchen with stinking Chinese appliances.
Magnet or magnet trade ?
Source your granite independently too, there are some great independent suppliers around.
Howdens is bread and butter. Can be made to look nice but there is better about for not bucket loads of cash. Magnet trade will sell you anything that's in the retail showroom at a whopping saving off list ( even though their list price is of course for folk with more money than sense ).
Temporary propping for demolition
Nickfromwales replied to willbish's topic in Roofing, Tiling & Slating
Plus 1 on the second support on the mid purlin. Whats is the floor construction that these are all sat on? -
Boiler, buffer, thermal store or UVC? UFH with PV
Nickfromwales replied to oranjeboom's topic in General Plumbing
Ok I'll try and summarise... SA ( for PV storage ? Sound like you've got a decent chunk of that, so that's down to sizing the SA units accordingly. Gas: Cooking. Boiler. You can squeeze the SA's nearly dry, and then lean on the gas boiler as a last resort. It shouldn't come on at all during the 'sunny months' so sized properly this should be a nice solution. With a combi you may want a thermostatic hydronic diverter which, at a certain temp, divert DHW from the SA away from the combi and send it directly to the outlets.- 60 replies
Select the neighbour you dislike the most and buy yourself a long-handled shovel. Tally-hup......"Incoming!" Did that with one neighbours dog in a previous abode, back doors opposite each other. Their dog would shit on our back door step. Wife lost her rag and piled up a load by their back door. Then made me put a fence up. Oh, and he was a night-club doorman who finished work at 3am, and would insist doing a 3-point turn to have his car parked the right way for the morning. Wouldn't have been a real problem except his Rover 220 turbo coupe had no exhaust, and for good measure he and his missus would then argue loudly for an hour or two to add the cherry to the cake. Throw your shit at the annoying neighbours. They'll soon smell the coffee......or maybe they won't
Wetroom Formers and Wastes
Nickfromwales replied to Barney12's topic in Bathrooms, Ensuites & Wetrooms
If you get formers which don't need to be fully supported then the ones over timber will be an hour or two a piece to install dry. Give a fitter time to unpack, eat and pack away, but expect two of the timber ones done in a day with the wastes connected and tested and the proprietary sealing of the trays done too. A good bit of reading here... and here.... and ?loads here. Ill add a bit more on the UTH ( under tile heating ) later ? -
2 over timber and 2 on concrete? 3 and 1? Drainage in place ?
