Nickfromwales
    346
  1. Not exactly what I said. So, to further clarify; As an installer and a person who has an active interest in SA I have put myself forward as an installer. As an installer I have deemed BY MYSELF that there is an effective workaround to the 'issue' that only @JSHarris has currently highlighted ( please inform me if there are others who have stated this EXACT issue as I am not currently aware of any other like instances ). I have not been told to do this by SA and they do not see an issue at this time. I have had an agreement from SA that it is always best to be cautious when sizing for capacity, so the above is MY take on how the units should be sized and implemented. SA have not 'recognised' anything of the sort and I very much doubt they'll change the entire fleet over what is from their perspective an isolated case. What the facts are and how this has been identified as problematic extend to my comment about the perfect storm. That is apparent in many technologies and is simply an instance here as highlights a weakness created by this 'feature'. For you tin hat I say what about all the others in, working, and without complaint? I oversize everything in all things I do, because incrementally it's a safe bet. If someone is to give £1600 for a 6 which may just do it, then I would not entertain fitting it unless they went with a 9. same goes for the 9, if its borderline then I'll recommend a 12. I do the same with radiators and gas boilers, as you can turn a big radiator down but you cant turn a small radiator up.
  2. Pretty much. That statement I made was a little 'broad', as I have made no such consideration in the instance of the property with both a 3 and a 6 ( as they were already on site when I was asked to go and fit them ) and the 3 is currently. However, I will add that those units were being fed by grid electricity on demand and when the client gets around to fitting his PV diversion controller which I think is now done tbh I shall be in contact to get some feedback ( if they don't contact me first that is ). In fairness, if @JSHarris had a teenage daughter and 3 showers were drawn every morning / nigh time then the likelihood is that this thread wouldn't exist. It's only because the sizing and the usage of DHW have created the perfect storm that this is apparent, so is actually focussing on the weakness not the strength of the SA controller. Take for eg the install with the size 9, with two adults and one child, who I have not heard one peep from since leaving. They clearly live the other side of the 50% difficulty and Jeremy lives t'other. I wonder if there is a way to convey the fact that there is export occurring to trigger the timeclock / low current interrupter so that it bumps the SA into 'hunt' and it would then scoff up any excess.
  3. Yes, all chat to date has been about air to water HP's. The one that's described above, the r-prefix, takes F-gas directly into the SA heat exchanger to melt the PCM directly with the energy produced by a dedicated HP. The idea being that the whole setup doesn't suffer the losses of going air-water-HEx eg the losses of the conversion in the HP and also the losses downstream of the hydraulic circuit in between the two units. In honesty I have not asked recently if these units are to market currently. I shall enquire though as I did like the idea when I was made aware of the principle some time ago. The PCM58 needs a flow temp in excess of 58oC to melt the PCM, so a 'regular' ASHP is no good, as it's probably going to max out at 58oC at the HP ( at which point the CoP would be in the gutter ), and then the losses in the hydraulic circuit will see less than that actually arrive at the SA. The SA's I've seen working with HP's so far have all been high-temp heat pumps which give 650C to the SA. These HP's have also been doing space heating via upsized radiators with some iirc storing off peak produced energy for space heating between off peak events. Like I said, tin hat
  4. Exactly the conversation I had today. It needs to be implemented to make good use of it's capabilities, and today I told someone that it would be best to simply switch it off for 3 or 4 months of the year where there would be insufficient PV to charge the AC batteries AND offset the house base loads eg during peak winter.
  5. I've sat outside these exchanges for a while as I have fitted a number of SA units and wished for the 'whole picture' to be freely discussed without my interjection. I think that's been exercised so time for a spanner in the works...…. For the majority of commentators, there is a wide knowledge and understanding of how the unit works, vs say Mr & Mrs Smith who know zero and just want hot water. So, I have fitted these units ( PCM 58 btw as PCM 34 is currently removed from sale until the bench test unit achieves the required number of cycles that will confirm it's longevity / robustness ) for a good few Smiths and so far so good. I have fitted ones for pre-heat to combi boilers, one's which replaced a copper vented hot water cylinder and one's which do space heating & DHW combined. All I can do is offer my honest, impartial feedback to this exchange in order to answer the OP's questions, so FWIW; One unit, a PCM 58 size 9 Hw+I, is in and working and has been for about 5 months. This is for a family of 3, and the SA is their only means of producing DHW. If there was any issue with this I would be the FIRST to know. I have also fitted a size 6 and a size 3 in an architects house, ( the 6 doing the family bathroom / utility / kitchen and the 3 doing the ensuite only ), and likewise, as their only means of producing DHW, again, if there were issues I'd be getting shouted at accordingly. I am being shouted at by neither, and both have given me testimonials for both the units and my services in fitting them with the latter asking me to go back to undertake further work there. I felt I should comment to give some balance, and it should also be noted that I fitted the 2 units at @Barney12's home where he has had nothing but grief from day 1. Where the issues may possibly lay is in the history of these units meeting the 'adopters', where some folk were dealing with a company still in development, whereas now they refuse point blank to sell to the public, nor to respond to the public as they should have done ( or not done ) from day 1. Because they now only sell to resellers the buck stops with the installer, and the only installers permitted to buy and sell these units must prove their worth to SA and gain the necessary accreditation to boot. My point being this; that to specify and install these units you need to know how they work, what their USEFUL capacity is, and which unit is to be selected correctly for each instance. For eg; I have been asked to specify one for a client to replace a copper DHW cylinder and on paper a size 9 should suffice. As it will be heated by PV I have subsequently viewed the 9 as a 6, so at 50% depleted it would not have sufficient capacity to fulfil the needs of the household, so I have selected and subsequently recommended a size 12 unit for this particular instance. That unit will be fit and forget, and I will ever hear from them again, of that I am sure, but that is because I know how to specify these correctly. Simple. The controller 'issues' are something that are best described as 'quirks', but are known and should have be considered by SA when stating the equivalent capacities in their installation manuals, especially when they knew they would end up in the hands of folk who couldn't decipher them properly. That point is NOW moot however as the units now being distributed should only be coming to 'the Smiths' via an approved SA installer so the 'thinking' would be removed, the quirks not causing any sleepless nights, and as above they should be fit and forget. The only remaining 'issue' then is the cost, where the client may consider this approach an unnecessary expenditure, eg where a size 9 on paper should suffice, and I recommend a 12 ( so an uplift in cost of ~£300 ), and the client has to bear that uplift for me to be able to recommend a SA...…..BUT...…..they'd never be aware of that mechanism as I would just be quoting for the size / type of unit which I calculated would be suitable for their needs and they would simply either accept or decline the quote. Ultimately SA is 'the loser' in that situation as I would have to make their product look expensive where it could / should be cheaper, but all this is early days in the grand scheme where most here probably do not know that SA have now pulled away from the public as aforementioned, in recent months, to ensure this kind of error cannot happen anymore. Credit to them for raising that drawbridge, albeit a little late in the day, but as the saying goes "pointless locking the stable after the horse as done a bunk" so they ( SA ) should really have been making more effort to remain in constant / constructive dialogue with their "early adopters" which it seems they haven't. @recoveringacademic; Should you be snogging this box of salty yogurt? I'd prefer not to have to bleach that image from my mind.... @mrsRA would be a bit pissed off if there were another in your marriage.... Avoid? No. Specify properly and install to suit? Yes. Tin Hat suitably super-glued on and awaiting the flack...…..
  6. Has it got the black plugs in the ends of the pipes? ( if you have it yet ).
  7. 100% do not drop the manifold below the UFH loops. The flow rate is a trickle, circa 2-3 litres per min is the average, so unlike mains pressurised hot and cold you’ll never vent the air out. ?
  8. Not quite. I have found that there is a slightly higher flow rate with higher temps, strange as it sounds, and as the heat loss is slightly higher at higher temps they seem to work fine when not set to minimum. More plumbing voodoo for you FWIW I do not fit the conventional blending valves any more, and instead I'm sticking to the Ivar kit as posted above. So much easier to commission and far better degree of temp / slab control vs the conventional types. They do not rly on a return flow to function so are IMO a no-brainer. For higher temp / mid energy consuming installations the conventional type should suffice, but if the target flow temp is at or very close to the lowest setting of the TMV then you shoud change types to mitigate against this problem.
  9. Wunda sell their pipe pre-pressurised and cap ended. I don't know what pressure they do it to, but I cut into one and nearly followed through. Good idea.
  10. Its running too close to its stated tolerance IMO. When the return temp gets close to the flow the valve tries to go into 'anti-scald' and squeezes partially shut. That's where the noise is emanating from eg the water squeezing through a nearly shut valve. Open the valve up to 10oC more allowance and the noise will stop temporarily, but then will start again when the new flow temp is achieved and the return catches up.
  11. It the shitzen hits the fan, it's one of these you'll need to replace it with.
  12. Its because the flow temp is set too low for a conventional blending valve, and the return temp is coming in at a point where the acceptable ratio for hot / cold is outside its acceptable working parameters. When I say too low, I mean you need it to be that temp as opposed to you using it incorrectly, and the only real cure for you, short of changing the pump / blender arrangement will be to turn the pump down to its lowest setting and seeing if that will still have acceptable flow to the floor loops ( eg it'll still maintain room temps ). The flow gauges will drop off but you'll still get flow, so don't automatically think it wont work just run it and see. Turn it down, run it for 48 hrs and report back here
  13. Agreed. Is there any writing on the body or head of the white cap?
  14. Warm up time is easily managed by setback / advance of heating on / off sets points, so don't get hung up on those. The issue is with folk who are not conversant with these 'technologies' stating Chinese whispers and causing undue worry amongst folk who hang on those 'professional opinions', howsoever generalised ( or even flawed ). If you are building to a good standard ( our UK building regs are utter ? so please don't go by those ) then your home will never actually go 'cold' ergo your 'warm up time' is massively reduced because the heating has far less work to do to get you back to your perceived comfort temps. How far the house drops to between comfort events is easily managed by deciding how 'cold' you're willing to let the house drop to and setting the setback ( aka economy ) temp accordingly. Look at it as "how hot and when" as opposed to "when will the heating switch on or off" where you set comfort and economy temps to be maintained rather than times for the heating to come on / go off. This only needs to be strictly observed for ~4 months of the year in reality, so base your decisions on that If they use proper Pex-Al-Pex pipe then you'll only seriously damage it if you take a hammer to it. My screeders regularly run barrow-fulls of screed over the pipes and then one of them will up-end the barrow on partially visible pipes but still with no ill effect. The stones in the concrete are of absolutely zero concern I assure you ( and I've been here more than once over the last 23 years ). Adding the fibres would be a cheap assurance and will be of no detriment, but they're usually only used in a non-reinforced slab where the mesh isn't present, to avoid cracking. You'll be fine.
  15. Prob just an airlock then, or a mixture of that plus semi-knackered tap.
  16. Makes all that digging worthwhile. Basements rule!!!
  17. Any specific areas predominantly populated by blond volley ball champions? Purely out of curiosity.
  18. One assumes Ian would have had to have planned in advance, structurally, to have tea and biscuits out there ? And probably have planning too. @recoveringacademic, the horizontals...…..are they staying one-piece or stop / starting? One assumes that adding the verticals in to suit would be far simpler. Or do I have the wrong end 'ut stick?
  19. I mitigated against that by being involved from early on in the build eg before it was even started. A few penetrations needed to be made in the main steels, so that was all pre-planned on annotated CAD drawings to / from the TF supplier. Other key penetrations made at that time were for small bore plumbing, and a few letterboxes for the main drag of cables. Worked a treat with just a little fine-tuning here and there.
  20. Or hose to a spare outside tap which gets you backwards to 1/2"
  21. Chuck a hozelock fitting onto the end of the hose and that gets you to 3/4". one of these screwed into the HL fitting some barrel or other then one of these ?
  22. Just go and buy them? A hell of a lot easier and quicker than digging all day ?!? What about a suction pump and try pulling the blockage back to you?
  23. To be brutally honest, I would first work out what you'll spend and what you'll ACTUALLY generate and do some maths. It doesn't sounds as if this array is going to produce a huge amount of power plus it'll have degradation ad service / replacement of inverter(s) to factor in. The sums are often quite difficult with smaller arrays, and become questionable altogether if not 'south facing' with zero shading etc. What is the actual pitch / orientation and how many m2 please?
  24. FWIW, I would avoid the larger bore series run systems ( personally ) after seeing how ducts and soil pipes would become quite problematic at junctions / crossovers ( eg a crossover would be near impossible ). Doubling up to 2x75mm ( 82mm O/D iirc ? ) to single inlet - extract point / locations are seems excellent insurance against audibility at high / boost rate. To better clarify, on the current project we have put a single outlet either side of the large living area with a single duct run to each outlet, where the alternative could be to run 2x ducts to one 'double-barrel' outlet ( all outlets were supplied with the ability to connect 2x ducts to a single outlet, with one open and one with a factory fitted, removable blanking disc which you remove and dispose of to connect 2x ducts to 1x outlet ). Putting multiple outlets with individual radial runs to each is favourable if that's is feasible, as there is a better spread of lower airflow over the whole space vs one double-barrelled outlet trying to do the lot at one point / location within a space. One person I spoke to was advised by a reputable MVHR supplier to beef up their posi-joists and go for a large bore series system. Naff results, difficult to balance ( as reducing at the last plenum slightly increses flow to the plenums upstream and vice versa ) and an uplift in cost for the posi's of over £4K !!! Plus then you have the constraints of rigid ductwork, so when your posi's are in, you cannot traverse the house perpendicular to the joists without introducing lots of cuts and joints. No ta.
  25. @Russell griffiths, if it gets anywhere near hot enough to do bacon and eggs I'll be straight round Chuffing diet is the word DIE with a farking T on the end of it.
