The point is moot, as a 10mm pipe will clear a 40m dead leg in less than a minute. If you use the Grundfos Comfort pump then maybe a bit longer, as it's a super low energy / flow pump which crawls the water around ( based on strategic use / utilisation ). I've several projects where there are basins and sinks run in 10mm supply pipework ( no hot return circuit ) and the flow rate is adequate for filling a sink etc. 10mm is more than 'man enough' for this application, plus lower CSA and lower losses too.
Big issue is how much DHW is drawn off and when though? Would suggest the TS is serviced on demand if the extra independent heating zone is added plus DHW is required 'on tap'.
? Don't you mean that it does not control the boiler directly? With a TS which is servicing DHW too ( assumed ) then the cylinder stat controls the boiler and primary pump and he timeclock decides when. Therefore you would need a separate zone valve tee'd off the heating output from the TS which can command the boiler ( override the timeclock ) independently. That wouldn't be so problematic if you only want to use the annex in parallel with the current 'heating on' times? An idea of how you time heating and hot water ( DHW ) would help
When the Zone valve brown is energised the motor creeps to the open position ( 8-10 seconds will elapse ). When the valve head reaches the 100% open position, it presses against a micro-switch inside the zone valve which is over the orange and grey pair of cables ( 5-wire ) eg to switch on the boiler and pump ONLY when the valve has fully opened. You do not need the switching pair, and you could have just fitted the 3-wire version. Not an issue, but just to help you understand what they do
OK. Green / Yellow = Earth Blue = Neutral Brown = Live to motor ( which opens the valve ) Orange = Common of call for heat switch Grey = Switched live out of call for heat switch Connect the blue and G/Y to the same terminals shared by the heating system supply. Split the 230v feed to actuator / zone 3 output from the Heatmiser and connect that to the brown. That will get the motorised valve to open and close with the actuator. That should be all you need?
Hi Keith, and welcome. Isotex in the title so have you made your mind up on ICF? Also, one bed....does that mean single story or 2 storey? Type of roof etc? Info, and more info
Manifold system versus hot return system
Nickfromwales replied to Russell griffiths's topic in General Plumbing
Beware the regs / good practices on the lower temp ‘dead legs’. Ideally you should be putting lower temp TMV’s at the point of discharge rather than point of origin. With 50oC set point at source, is there really any reason to lower the second group? At that temp you have little to zero risk of scalding and I assume your outlets will all be mixers anyway? Seems a bit OTT tbh. -
How does the Sprinkler Law work in Wales?
Nickfromwales replied to Ferdinand's topic in General Self Build & DIY Discussion
We fitted sprinklers in one large job, but tbh I could have got away with not fitting them. As the egress routes were quite convoluted it was mutually agreed that they were a good idea. BCO was happy to see them go in, but indicated that they were not mandatory in that specific instance. Confusion reigns still. Piss-takers still take advantage. Loopholes offer such opportunities -
Not too shabby Bruce. ?? -
Cold feeds for outside taps should be off the rising main, before the domestic stopcock, rather than fed from the internal plumbing setup As for the rest of the runs, stick to your guns and don’t worry about the number of runs. It’s a far better setup than series plumbing, and bums do twitch when the numbers start getting to what some would see as ‘silly’. Are you doing hot returns to basins / sinks? -
https://www.walesonline.co.uk/news/wales-news/thousands-new-homes-wont-sprinklers-13684910 -
Smart heating control options
Nickfromwales replied to Declan52's topic in Central Heating (Radiators)
£6k installation fee. ? -
Then I’d say the mat may be omitted over that then. Is the plywood top layer glued and screwed well?
Were all the layers bonded to the sips / between layers? Eg no movement when you walk on the floor?
Fixing a mirror to plasterboard wall
Nickfromwales replied to canalsiderenovation's topic in General Construction Issues
Ah, yes. Apologies. In bathroom mode atm. Still disagree with trying to glue ANYTHING into a cut hole in PB. It’s only the paper face, and the paper face alone that you can get any tiny bit of purchase with, so no, and no again. If it’s a true stud wall and there is a cavity, then the collapsable “toggle” fixings reign supreme. -
Nothing sticks to cut gypsum in the core of PB It’s like trying to glue something to talcum powder. No sale. -
Absolutely not. They work themselves loose, and the mirror will be moved a bit during each wipe down / polish. It’s a bathroom, not a corridor, so cleaning will be much more frequent / vigorous -
Do NOT use those scabby corkscrew ones. Great back in the day when nothing else was available, but now pretty shit tbh. Edit to add; I’d fortify this with two big blobs of clear CT1 100mm in from each of the bottom corners to stop this flapping about when wiping down. Fear is of it lifting off those and crash-landing on the basin / tiled floor. -
Click and collect today. https://www.screwfix.com/p/gripit-plasterboard-fixing-25-x-14mm-8-pack/682GK?tc=ET2&ds_kid=92700048793290424&ds_rl=1249413&gclid=CjwKCAiAirb_BRBNEiwALHlnD8I-BBfC7hs_wBI21bKybD1MPEd4UTd3C-6aaCs3zAID7D1cfg6CQRoC5zwQAvD_BwE&gclsrc=aw.ds -
I’d be worried about tiling straight onto the Egger boards over the overlay UFH system as that’ll usually be running a higher flow temperature. I would either use a mat or overboard with a 4mm marine grade plywood glued ( PVA ) and screwed with screws on 120mm centre X & Y minimum. If the Superflex is 2-part then you may get away with it directly onto the deck boards. Are they 18mm or 22mm ?
The link from manifold to manifold needs to be removed and dropped lower on the diagram eg so it is directly after the WH pump and returns straight back to the WH’s. That setup as shown would ‘boil’ the Willis heaters. You have also omitted the cold ( return ) connection to the mixing valve.
Eyyyyyyy-uppppp!?! Where the piss-stain coloured grout gone? ?. Ive just uploaded them pics to me “How ( not ) to” YT channel. MUCH better. ???
None of it gives any consideration to thermal convection, eg if a window is cracked open on night latch to allow “purge ventilation”, then the likelihood is that cold air + ‘au du shat’ will be pulled into and through the dwelling. Disgusting. Fit a fan ffs. ?
Yup, but the thermal time constant will be conducive to heating once a day during Octopus Go’s 5p/kWh / 4hrs plus maybe one more midday nudge in the Baltic times. ? Tres bien, Rodney.
Coring through load bearing wall?
Nickfromwales replied to LA3222's topic in General Construction Issues
