Nickfromwales
    346
  1. Lol. ? Victory is mine !!
  2. You are worrying about a problem that won’t exist. Chill out An in-line restrictor fitted in the shower head and handset in minutes will sort this instantly. Available in different Lpm ‘sizes’ to suit each outlet.
  3. A single pump over multiple satellite manifolds is a sack-of-shit solution, you know it, and I know it Every single one I’ve come across set up like this is either struggling or hasn’t worked properly from day 1. ??
  4. Live and learn etc, but there’s little that can’t be fixed relatively easily
  5. Yes, hence.... All go hand in hand with a full manifold / pump / TMV arrangement.
  6. Still struggle to understand why manifolds are still going in with no local pump and blending set. Bypass would be integral then, plus a set / specific flow temp is achievable via each TMV, essential when there is a mix of disciplines like rads + UFH.
  7. If the zones were closed then there would be no call for heat signal from the manifold wiring centre, ergo the pump would be off
  8. Not accurately, and they’re all quite noisy when they get used like that. Just use flow restrictors at the individual outlet and keep the isolators for.........isolating
  9. I have re-read, and yes, confusion reigns.......
  10. The OP states the actuator rail gets hot first ergo they’re the wrong way around. The flow meters are like a flap / paddle over a tube end, so correct direction of flow promotes that paddle being pulled away to make way for the unhindered flow of water. Reverse flow actually pushes those paddles against the tube end and the higher the flow potential, the firmer they get shut. Things will improve when the manifolds are in the correct positions, and the loops have been purged. Get those done and order the eggnog
  11. Which of those is flow? Eg which rail gets hot first? The rails are reversed, and flow gauges should be on the flow.
  12. They’re not blocked, they’re air-locked. You need to use cold mains to force water through the loops, come off the cold feed to the boiler for that, and then a hosepipe to outdoors for draining. You connect the hoses to the valves at the end of the manifold rails. And make sure the manifold isolation valves are shut first. The UFH needs to be commissioned properly, and very few installers bother, instead assuming that the manifold pump will circulate the water and bleed all the air out. Wrong ! The water flows very slowly through the loops, and air remains in the pipe and eventually causes an airlock. That what your issue is here. Do you tinker, or do you need / can you get the installer back to commission it properly? Anything else is a waste of time and effort, and I’d recommend doing every loop to be sure this issue goes away and stays away.
  13. It’s hard to find a reliable / robust inverter over 10kW as you’re then up at around 50a. For 18kW you’ll need to go 3-phase with a 3-phase inverter. 18kW is academic until you’re told you can fit an array that size......so cart is waaaaay in front of the horse atm. You can self consume everything that the inverter throws out. “Export limitation” is exactly what it says it is ?. Get 3-phase connection is the bottom line. AFTER you get permission to install / fully utilise it that is
  14. What is the size of the inverter and what is its maximum throughput? Without that info there can be no answer yet
  15. Mickey Mouse tools can also knacker genuine batteries so just buy genuine or cut things by hand I had my big recip off eBay, nearly new, for £60. Still going strong after 3+ ( maybe more ) years of rigorous abuse.
  16. Big question is then over warranty issues with a Tom, Dick & Harry installation. Panels are usually warranties for 25 years but you have to get the agent up there eg provide scaffolding etc ( which needs to be put up by a certified scaffolder with all tickets in place ) and then if the installer is at fault then you have to pay that agents fees plus the required repairs If you’re a self employed / qualified trade with building and electrical competency then crack on, if not think twice.
  17. Prob a lot less than 4.5 in winter!!
  18. You want to export little or nothing back to the grid . Consider not getting the battery system as you’ll own a very very big battery on wheels if you have or buy an EV. 6kWp array will deffo not be big enough to satisfy that lot, and you’d have to strategically utilise the PV to maximise the benefits. Has your MCS installer done a survey and generated numbers yet? If not, you need to do that eg before considering anything.
  19. Might block the filter material up a bit too quickly?!?
  20. No chance!!! Get him on video and send us the YT link.
  21. I’d be more worried about painting the inside of that splenderific item with a few coats of oil based paint.
  22. Dave. We’ve put flues through baffled sections of non opening windows before, blanking them with non-combustible material and intumescent mastic type seal to complete the picture. The reason they don’t show a non-opening window is because they don’t care about a non-opening window. Carry on with the 47’s and tell your BCO to suck it.
  23. Export limitation can be employed to limit the max amount that can go to the grid. Some DNO’s will allow it, others may be particular or refuse.
  24. It’s based on the array, and the panic is if the inverter fails and dumps the max to grid. Been there a load of times and its bloody annoying and crude.
