Nickfromwales
    346
  1. Panasonic Aquarea 9kW for a sniff over £3,100. Telford 400L UVC = change of £1600.
  2. At that price, a heating company would go bust. It's 2023, not 1990.
  3. Steady, chaps! 🙄
  4. Just cover that power point properly first.
  5. If there is a mechanically fixed plasterboard and plaster layer, you need absolutely zero additional mechanical / fire clips / support. Those are the facts. On my full wiring jobs I encourage my sparks to run through the posi-joists where the two lower webs meet, but even that is just me being OCD. For the OP, there is no need whatsoever to use metal clips anywhere on this job. They would only be required above a pvc ceiling, or above a suspended ceiling where there is no other means of arrest. Same way that metal clips need to be installed within pvc trunking. Furthermore, this only needs observing in areas which form a means of egress / preserved fire zones ( halls / stairs / landings in a 3 storey or non single-compartment dwelling ). I've had this out with the regulatory 'bods' as I need to preserve my own indemnities also vs just take the word of my ( excellent ) 1st sparky, even though he was annoyingly right about most things We really do not need to add conjecture to the OP's plate, as it's full enough!! Metal clips / banding NOT NECESSARY here.
  6. Yup. With 200mm you could go in the top face of the lower 100mm layer, with 28mm Hep2o pipe ( run point to point with zero joints in the slab ) and insulate it with 13mm wall Armaflex insulation. Simple choice is to go under and rise up where required with the Duo. Depends on your multi-tasking skills / sequencing etc, but can be done either way ( just DEFO NOT in the screed ! ).
  7. Tape isn't suitable for anything other than uniform surfaces with complete access, plus there's a much higher chance of them not adhering 100%. Foam, foam, and thrice, foam.
  8. I buy 12 or 24 at a time with the amount we go through on full installs. Every project is an airtight house so this stuff is brilliant at sealing penetrations etc. Foam. KISS. Get a spray bottle and apply a fine mist of water immediately before foaming, working with the process - spray 1m, foam 1m, and keep repeating. The whiff of water makes the foam cure so much better / faster. By the time you finish going around, you'll be able to use a padsaw or similar to cut the first section of foam back flush with the wall.
  9. "The power is in your hands". Go kick their arses, and then cancel your worthless cover plan.
  10. Does "being unhappy" then magically provide a full set of plumbing tools and the experience / knowledge of how this should be stripped and rebuilt / re-plumbed? Tough crowd!
  11. The best option is to cut into the black pipe and fit a solvent T with a reducer to 21.5mm ( condensate pipe ) glued into it. Those retro-fit connectors are shite tbh. This would be fit and forget then. 30 min job at most. Can't you get the boiler installer / plumber back to do this?
  12. Undo the white nut, below the solvent weld elbow. Have an old towel stuffed in there to catch any water trapped in the pipe. The nut should be a little over hand tight, so you should be able to remove this with relative ease. Get a pipe cleaner or similar and then insert it down and around the elbow fitting ( white bit connected to the black pipe ) as I know British Gas for one fit a stupid and unnecessary ( plus problematic ) non-return valve at these junctions. You should feel an 'obstruction' in the elbow, and if so you will need to get the non return guts removed and then just re-fit the nut and pipe back on. That will be the end of the problem I think. I've been out and removed loads of these tbh with identical symptoms. BG even install these outdoors, uninsulated, and as they harbour a little residual water at the lowest part of the pipe, they then instantly freeze!!
  13. In a nutshell, yes. Nothing will 'build up' in the void filled by the foam, as it will be filled up by the foam! If it's not porous or adversely hygroscopic then it's suitable for preventing damp bridging. It is imperative that you have prepped this meticulously, and have cleaned and primed the surfaces well.
  14. All the ducts need to be subterranean, and brought up through the slab. I hope you've allowed for at least 150mm of insulation? 200mm is optimum. Do not run these through such a thin screed, as you'll end up with hot spots and very little residual cover over them ( by the time you fit at least 9mm of Armaflex over them. They'll get significantly warmer when servicing DHW don't forget! Install some pre-insulated pipe for the ASHP, such as... https://pipetek.co.uk/products/32mm-microflex-duo-heating-pipe-kit?variant=29979663466614 ...which is what I use on almost every ASHP installation we do. You can install this yourself prior to contractors coming in, so you can save some labour here, plus it will be a better job. Bury this at least 400mm deep in the ground if possible. Run 2x 50mm ducts alongside it for 230v power and low voltage signal cables.
  15. You want to ditch that cheap foam ( open cell ) and use Illbruck 330 ( closed cell ) foam. Goes off much harder, and won't bridge anything, is air and moisture resistant etc. https://www.dortechdirect.co.uk/catalog/product/view/id/5664.html?gclid=Cj0KCQiArsefBhCbARIsAP98hXQJH_IageT-_cHrAyRaxDPZS_RQ6DaqHGqAD-Koxv5kvgILSWaz7hgaAk8SEALw_wcB I don't use anything else these days. Excellent stuff, and ideally suited to your current requirements
  16. Misrepresentation of goods act? Anybody? Indeedee.
  17. Ah, yes. I'll chalk that one down to the good people at Beavertown, and their delicious "Neck oil".
  18. Don't let the door hit you on the ass on the way out Medium rare, no less. 🙄
  19. This is what was used for heave on my current project. https://www.google.com/shopping/product/1?q=cordek+heave+protection&prds=epd:18157365360563409597,eto:18157365360563409597_0,pid:18157365360563409597&sa=X&ved=0ahUKEwjbmqKwsaD9AhWRTcAKHWvhAnEQ9pwGCAU
  20. His blood is 67% potato, corned beef and onion, plus 22% pastry. It doesn't conduct heat very well. Such a shame when they get this way.
  21. ? Clearly not. I'm more concerned about the vanishing airbrick??
  22. You're a god-damn legend. Pasties are on me.
  23. Structural engineers aren't going to do anything more than structural engineering, and nor would you want them to Your general builder 'could' become your principal contractor, but they'd need to agree to officially adopt that role, otherwise it will land in your lap. Read up here, a lot, as there is an absolute wealth of info here regarding this subject
