tap flexible connector fitted with a loop
Nickfromwales replied to Question's topic in Bathrooms, Ensuites & Wetrooms
You would have had a proper tap connector. These clowns took the lazy route, and just started cutting pipework for no good reason. Fill valves in the cistern have an industry standard connector, and replacements are manufactured to allow an 'alteration-free' replacement. Tossers. Get this changed for free, then cancel. -
Cancel it. Put the money into a glass jar each month. IF or WHEN you NEED something doing you'll have plenty of money ( of your own ) to appoint a company which isn't a sharky shit-show such as these legalised thieves. British Ass more like. Dyno Rod are drain un-blockers, not plumbers. Why the feck would they not have cut the pipe lower down and used that to absorb the length of the flexi. OR ( drumroll please ) just have used the exiting tap connector which would have been a like-for like swap?!? Cancel your contract, and save a boat-load of money over the next x number of years where nothing breaks. Biggest scam ever, and if your boiler fails they'll just cancel your contract for you, stating that the boiler is obsolete, and give you a massively inflated price to replace it. -
65C top-up water for a bath?
Nickfromwales replied to puntloos's topic in Air Source Heat Pumps (ASHP)
When my "outy" goes to an "inny", it's time to get out -
To Tank or not to Tank? bathroom advice required
Nickfromwales replied to TryC's topic in Building Materials
£40 is the cost of a tub / kit. You buy multiples to complete the area. I've posted over the years in huge depth regarding this. They don't call it "tanking solution" for nothing !! Tanking is via a liquid or a membrane, but almost always a combined effort using both is the 'norm'. Eh? -
I’m surprised you can remember that far back lol
Not accurate. Tanking can be done, very effectively, with the cheap liquid ( paint on ) solution, with excellent, long term reliability. Other systems like Impey utilise a very expensive self-adhesive membrane. Not necessary, just an option that is out there. Further disagree, massively. Tanking solution applied correctly means that you are "tanked", end of. This is dependant on it being applied according to the manufacturers instructions. I did a wetroom in a house, over timber floors, on the 2nd floor. This was for two ( careless ) teenage daughters of a wealthy couple. Clothes and water everywhere. I spoke to the client about 3 years after installing 2 full bathrooms, the aforementioned included, and he said to me, "I wish I had you do the others, Nick" as they let him down. 'Mine' are still in and being used, hassle-free, some 9 years later. -
Solar Quote
Nickfromwales replied to bob the builder 2's topic in Environmental Materials & Construction Methods
GSE would be in-roof, which means cutting into / interrupting the standing seam roof to suit. If a standing seam roof is below a certain pitch then the roof must remain continuous to stay weathertight. I've seen a couple done, but the roof installers were platinum level installers. I've seen one done badly where it was blown off. Going for the vernacular is often the safest / most sensible route tbh. Cooling is academic imho, as even in-roof has a decent air gap behind it. Yup. You're spot-on. -
Bugger. Apologies for my hit-n-run reply. Just very busy atm with about a billion new enquires. I doubt you are alone. Let me explain. With 3-4 bar of incoming pressure, many folk would be jealous of you. Having stonking showers off an unvented hot water cylinder ( UVC ) is easily within your grasp. If you have multiple occupants then you may want / need to consider fitting a cold mains accumulator, but if you are just yourself and the better half then you can discipline yourselves to avoid this cost / space requirement ( for another cylinder the same size as the UVC ) by choosing when to shower / run the dishwasher / washing machine etc.
Beam & Block Detail for Nudura...
Nickfromwales replied to Mulberry View's topic in Insulated Concrete Formwork (ICF)
Superior to what? Insulated where, and how? Back up what you say with some facts please. When did you last hear of a typical internal domestic home wall freezing? Can you give an instance for this, including those which are non-insulted cavity wall dwellings? I've been in / around the construction industry for 3 decades, and not come across this phenomenon yet. How can you defend a foundation which has an under-belly that is continuously purged with an abundant supply of freezing cold air? It has a place, but "superior", definitely not?! -
Really? The water wouldn’t be fit for human consumption! The idea is not sound, so buy a few 25L bottles of mineral water and put them somewhere cold and out of sunlight. This one is defo a very bad idea / complete waste of money imho.
Shower tray cracked around where the trap is
Tbh, this is the best course of action, unless Dr.Evil had no further use for his “giant laser”. 😵💫💥 -
How do you value this slab? And do you mean an insulated raft? Or a slab over strip founds? -
2nd worst foundation on the market, after just dropping trenches in. Cheap and nasty IMO, cold-ventilated all winter, a choice of the bean counter, only. The beam is 100% insulated 360° round with these products ( Beamshield etc ) including the underbelly, so the ice cold whistling wing blowing continuously under your heated floor for the nasty 3 months of winter won’t be a problem. Bare B&B is complete shart, sorry. Even with trenches the slab won’t go lower than ambient geothermal temp, but b&b will easily go down to freezing temps. Ask a client if they’d prefer to buy concrete blocks or insulation to achieve the same result ( physically). Then ask them if they’d prefer a thermally broken foundation or one which will act like a fridge. If folk are budget constrained then a b&b may be their only choice, but why would you not then improve it any way you could, given that the cost of the blocks / labour / grouting would be in your back pocket to go towards the insulated slab system? -
I put a thermostatic mixing valve on the hot outlet of the cylinder, set to 550C, and if the bath tap is not thermostatic, another TMV has to go in to cap the bath at 46oC. "We have the technology" -
Single SolarEdge inverter for two buildings?
Nickfromwales replied to ringi's topic in Photovoltaics (PV)
Optimisers go on the panels. This allows each panel to function independently, and for any shaded ones to never interfere with overall maximum efficiency. Are you looking to DIY this? If not, it's probably a good idea to get an MCS accredited designer to run an eye over your ideas first. You can get these done for free, so well worth the money -
Err, "No". @Question, how did this damage occur? -
Gravel and/or weed membrane SIPS garden office on ground screws
Nickfromwales replied to tomdc's topic in Garages & Workshops
Mine is exactly the same, and only has weed / growth issues around the perimeter tbh. Gravel, for my instance, would probably make things harder to maintain. -
ICF below ground finish / protection
Nickfromwales replied to Andrewb's topic in Insulated Concrete Formwork (ICF)
You will need something that you are happy with aesthetically, for the bits above ground, and uPVC seems to not attract Roland and his band of merry rats. Below there, you could fit a stainless mesh I suppose. https://www.robinsonwirecloth.co.uk/online-shop/Stainless-woven-12-mesh-1-56-mm-aperture-p52090270?gclid=Cj0KCQiAxbefBhDfARIsAL4XLRqOMHuS0vydAnPgYkfzelJLtknW_PqPk32AoOoBwDIH9EVEe-8IcSAaAmhPEALw_wcB I think paranoia may be worse than the event, but the above would offer some 'protection', perhaps. Whats stopping them coming up under the type 1 / sub-base? -
The one thing you regret not doing
Nickfromwales replied to Pocster's topic in General Self Build & DIY Discussion
Shirley, you can't be serious -
This entire thread summarised in one sentence. If the bath moves, it leaks. I always fit ( fitted ) battens to the rear wall, often with additional support where deemed necessary, and I've never had an issue. @TryC Check out suitable products here; https://www.thewetroomstore.co.uk/wet-room-tanking-kit/ Cheaper than shoplifting. -
If your boy has to sell the Cossy to make your bail money, give me first shout lol. -
I try explaining this to clients, some smell the coffee, some don't. Thanks for posting this! -
And you should know better -
You're a changed man. I'll apply a gold star to your profile.
