Continuous operation as I read it in your screenshot means it just doesn’t attenuate flow temp a-La weather comp. Not that the boiler ( heat generator ) would run continuously? Was there a WC’p outside sensor installed also when the boiler was installed? If not, then that’s why it’s set to that. I would have thought room temp setting would have been the one, with the room stat dictating this? FYI, I’ve never worked on / been around an install for one of these.
Is this the correct part saniflo coupler?
Nickfromwales replied to Tennentslager's topic in Waste & Sewerage
@Tennentslager Yup. Defo swap to solvent where you’re half in / out of the wall. You need some sort of rubber / flexible connection on the discharge side, immediately before it picks up the solvent weld. Don't forget to clean that pipe before you pick it back up in solvent weld, as that will be contaminated now. -
Ok. So you’ll only need one manifold here. Can you explain the above a bit better please? 😊
Fixing into plasterboard
Nickfromwales replied to Temp's topic in General Self Build & DIY Discussion
Breakout behind? Not in front ( which is what I am saying to avoid. Surface is cosmetic, but the plasterboard behind is the functional bit. I think that’s the bit the Gripit people offer / say to use? That’s due to the size / splay of the Gripit wings, me thinks. -
Put the drill on very high speed. Drill a small hole, then a larger and then the final, without pushing on the drill whatsoever. If the plasterboard blows out behind, then these fixings won't hold very well. -
Have you wiped both sides to confirm this is inside the glass 'sandwich'?
What I am looking for tbh.
All depends on whether this is one screw or multiple screws into one small footprint ( base area of bracket )? If a single fixing will do, the Grip-it all the way, as long as the hole is covered by the bracket / other. -
Are eco joists the same as posi joists
Nickfromwales replied to CalvinHobbes's topic in General Construction Issues
Why do you think he’s offline here now? -
Bird is the word. 👊
Discount Offers of the Week
Nickfromwales replied to Ferdinand's topic in General Self Build & DIY Discussion
Well spotted lol. I need glasses 🧐 -
That depends on whether it's an airtight dwelling or not. AT detailing is done on the interior, and weatherproofing on the outside. Illbruck 330 foam is your friend for AT work, plus whichever brand of AT tape you prefer. Drilling through AT houses is unavoidable, unless you're a micro-managing super-human, so panic yea not I drill through each clients dwellings probably between 5 and 20 times, sometimes more, but AT test results always come in ( on MBC's stuff anyways ) at sub 0.4 ACH, because I make VERY good, each hole I make.
Why Zoning of heating is Bad Practice
Nickfromwales replied to Dave Jones's topic in Underfloor Heating
You mean impossible, surely? -
Yes, but I'd then tell you how horrible the internal units are to live with, and where best to hide them so they don't piss you off Monoblock is 2 pipes, and a couple of wires. I'm not sure I'd tell a complete DIY novice to go for that type of install, but I've eaten so much humble pie I can't fit into my little black dress anymore. Up to you how confident you are, in a nutshell.
Hi, and welcome! I would seriously consider having the "builder" do the building, and then have kitchen and bathroom fitters / installers do the 'nice stuff'. If all has gone well with the TF, then you should have enough marbles left in the bag to choose, and direct, your own downstream trades ( for these individual spaces ). Depends on your nerves / balls / confidence, but with support here you should be able to add your own input / signature to the rooms which need this type of personal input.
Complete and utter horse manure. The internal fit is typically much longer with a masonry build. With a TF build you can be weathertight much, much sooner, and with staggeringly good results from insulation and airtightness, which are inherent from that type of build system. Masonry is a real pita to achieve the same with. MBC leave you with all walls and ceilings battened out and ready to accept plasterboard, with all woodwork ( within sensible reason ) installed at 300, 400, or 600mm centres, meaning the internal fit is DIY'able with ease. Ask someone to dry-line their own build and you'll see less people able to DIY that volume of work / have the necessary skill-set. MBC PH TF or Nudura XR35 ICF for me.
Short and sweet Straight through the wall, sleeved, insulated, and job done. You'll be in the pub by 3 Are you referring to a monoblock? I assume so.
MVHR is Largely Bogus
Nickfromwales replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
There is no "running cost" of a kitchen?! Do try to say something relevant, it helps a lot -
Enough screed to support weight of car
Nickfromwales replied to Post and beam's topic in Garages & Workshops
Very expensive to do twice. I’d put 100mm down, impregnated with steel fibres. Not a huge difference in cost, but a huge difference for the end result. -
Yup. From the bottom up. I snip the lighter gauge steel to the same size opening as the shutter, and then back fill retrospectively. It seems like a lot at this stage, but trust me, once the pour is done and you have to get in there to alter, that becomes very small very fast
