airtightness/insulation and consumer unit
Nickfromwales replied to irishhouse's topic in Consumer Units, RCDs, MCBOs
I wouldn't get too upset, as most trades know little or nothing about airtightness, in fairness. To solve this, all you need is a squirt of Illbruck 330 foam and it's job done 10 minute fix.- 1 reply
CT1 is still the bomb, and Sikaflex will be around long after me I expect For a tray on legs, you have to go to town on it. Bonding the legs down is the norm, but I also install a rip of plywood along the X & Y edges which I glue and screw in place. You dry fit the tray and level it, and then draw a line under the tray with a sharpie, and have the plywood ( 18mm ) sitting on the floor and just stopping shy of the line. Set the tray into wet CT1 ( detail as per the other threads ) with a generous amount on the upper edge of the ply, plus on the wall, and also run a bead along the X & Y edges of the tray ( on the rear not top ). Push and wiggle everything into its final place, and job done. The belt and braces approach is to follow the previous recommendations and make a base and lose the legs altogether. Just needs some good woodworking skills to create a space for the trap, support in the right places, and an escape route for the pipe run. Have baby wipes to hand to clean up, and use loads of them to keep the mess at bay.
UFH - zone not heating up. No flow...
Nickfromwales replied to Newbuildnewbie's topic in Underfloor Heating
I have, once or twice -
Only that this is exactly what to see / expect The slab is porous, and will suck the diluted primer like Gillian Taylforth, so nothing to worry about there, just keep lathering it on until the floor gets as saturated as you can get it. I always get the SLC down over the floor whilst the diluted primer is still wet ( so not technically cured / left to dry ) which I find leaves the SLC to flow far more readily. Also, if it's a 2-part SLC with the 5L of addmix, I always throw a 1/4 pint of water in to the mix immediately before pouring. And whatever you do, don't run out of SLC 🤣
Got full planning granted today !!!
Nickfromwales replied to Post and beam's topic in Planning Permission
Get cracking then! 🙄 😁 -
Inflation is killing my build
Nickfromwales replied to farm boy's topic in General Self Build & DIY Discussion
Glass half full time There are many, many people worse off than you. Struggling a bit to build your own home is par for the course. Just sit back and enjoy the ride, as you can't get off until it's ended. Buy materials now, if you fear they may go up, but then repent at leisure if you find they then came down instead, or something better came out. Timber and inert stuff won't really matter, but if you extend over time then your salary(s) will chip away anyways. You will need an electrical completion certificate, same ventilation and drainage. You'll need a very basic kitchen with an oven and hob ( free-standing crap 2nd hand electric job will suffice ) and one bathroom. That's it really. Heating can be via plug in radiators etc but sense should prevail around what you 'don't do' before occupancy, as moving in when massively incomplete is progress-suicide. It is what it is, so preserve the bathroom(s) and flashy kitchen for later down the line, possibly funded by a remortgage post completion? Concentrate on the fundamentals, and leave cosmetics for now. Function instead of form, and invest wisely in the infrastructure as it will be daft to have to redo anything such as heating or hot water. Run cables for PV, install later etc. -
which will have 20% VAT, which you can reclaim. -
Your logic is flawed here, IMHO, and gets worse the longer you intend to stay in this property. Lets delete solar PV from this equation for simplicity, as in the winter it will have little to no effect on heating, ( unless it is a considerable array ). Installing wet UFH into a slab you're already having, is a way to introduce ridiculously low heating costs, so in order to "justify" it, just get a calculator out and do the maths. Look at the costs of heating, coarsely, with grid cost 1:1, and then look at doing the same with a HP at 1:3.5 - 1:4. That's a 1/3 of the costs minimum, and the cost ( and inconvenience ) of panel heaters ( which you absolutely will NOT be able to sit anywhere near to ) and the VALUE of how you will live with each choice in your HOME. Then suffer furniture plans being definitive, and that's the end of the choices then, for me, anyways. Then factor in load shifting for an off-peak tariff like E10 etc ( 3x per day ) via the HP ( multiplied by the CoP ) and you should see running costs as low as a few pence p/kWh. Your proposed heating arrangement would soon be up at 50p/kWh eg 10x the cost. Now can you justify it? THEN, factor in slab cooling for the summer which you will get for free as a side-effect ( aka bonus ) of owning an ASHP, plus putting you furniture wherever you want. Also, the heat emitted by UFH in a low-temp slab is a thing of complete and utter beauty. The heat emitted from IR panels is, IMO, "ugly" by comparison. A colleague of mine recently installed the smallest IR panel he could buy, in his small home office, and after suffering skin issues ( he said his eyelids were literally cracking ) he has had to remove it and go back to an oil-filled panel heater. It matters not one tiny bit what you decide to go with, just my 2 cents. FWIW I have been installing space heating into passive houses ( or thereabouts ( or way above also )) for over 8 years now, and I would never ever steer away from wet CH, nope / nil / nada.
Not to be pedantic, but everything you've just said is completely true of an standard UVC, minus pumps / flow switches / plate heat exchangers and the huge losses they promote, other than they heat quickly ( as they're not off-setting those losses and are purely pumping heat into the cylinder only ), and heated water is always "instant". This is reinventing the wheel, but making it more 50p shape so it is 'unique'. FYI a 300L UVC typically has 2x immersions for heating directly from electricity, and only indirect models have 1.
It gives more energy per m2 but is just a ball-ache and a one-trick pony. In summer it just gives you stupid amounts of excess heat energy which you then either cannot use, or you have to run a pump to dump it to a heat loss radiator. Still cannot get over how many new builds have a mix of PV and ST on the roof!!!
With cold mains they pass. But yes, direction of flow should be observed to not damage the flow gauges.. Poster stated they have non return valves, which they don't. -
I've never seen a manifold with non return valves. Do you have them on yours? Not had one on any manifold I've ever fitted, over the last couple of decades, just flow gauges and the attenuators where the actuators connect to switch each loop on / off. -
Attaching a batten to a steel lintel
Nickfromwales replied to RachelGodfrey's topic in Brick & Block
Infill the web of the steel with rigid insulation and then affix timber over that. If you attach the wood to the steel you'll transfer a big cold bridge to the back of the plasterboard, undoing all your hard work. I would simply use 3x2 timbers to span horizontally between each vertical 2x2 ( the ones either side of each opening ) screwing sideways into the ends of the 3x2. Have one at the lowest point ( the head of the window where the plasterboard will go ) and another at ceiling height, but the one at the ceiling can also be noggin'd to affix to the 1st floor joists. That will fully secure the upper one(s) and then the lower one, which will have some movement, gets its rigidity from the plasterboard that form the head of the opening reveal ( head ). That will be insulated plasterboard which you would bond on to the underside of each lintel ( as you really do not want to have bare plasterboard affixed to the steel around the window reveals at all. Around each door / window opening will be where you have no scope for thick insulation, so perhaps look at bonding 20mm Compacfoam to the heads and reveals and then bonding plasterboard to that ( if you want to avoid having cold / damp / mould regrow in these areas ). The risk you have here is making nicer warmer walls on the main runs, but then having adversely cold sections where you need them the least, as around the windows / reveals will be naturally colder already. Fill any gaps between plasterboard and block / steel of the reveals with Illbruck 330 foam, which won't bridge damp and is airtight ( closed cell ) so is great at draft-proofing also. It would be a shame to go to all the effort and then still have these issues around each opening Plan ahead and do the job once, and well -
Maximum garden room size no longer 15sqM?
Nickfromwales replied to dance621's topic in Garages & Workshops
https://www.planningportal.co.uk/permission/common-projects/outbuildings/planning-permission "No more than half the area of land around the "original house"* would be covered by additions or other buildings."- 1 reply
Here are some good threads, Have a read through those and see what questions remain. .
That will be very expensive to run, and quite crude. If you do an insulated raft and install UFH you can heat the place for pennies, long-term. The cost of running crude IR panels will soon add up. Electric UTH and towel rads in bathrooms is fine, but space heating from IR panels is the last thing I'd ever recommend for any of my clients. Zero sustain, no medium to load-shift, and they heat what they hit, literally, so you'd need multiples of smaller units to spread out heat. The surface temps are also very occupant-unfriendly, and not good for children.
The Thermino is a Sunamp, rebranded, eg the same device from the same people. I'm not a fan of the Mixergy tanks, too much complication / faff / additional components / additional heat loss from the PHE / cost of running and replacing the pump and so on. For DHW, simply follow the KISS rule. Adding a second low slung immersion in a well-insulated UVC is all you'll ever need, and you wont ever convince me otherwise. Just an unnecessary over-complicated re-invention of an already time-proven wheel.
You'll probably just have to make this up with cement, and bench it in. Prob best at the height of summer when the ground is driest.
It'll be down to the settings / commissioning. The heat-pump clearly has permission to work harder for DHW, so it could be given the same permissions for CH too I assume. The curve for the CH operation may also be set too low, so a bunch of options are probably open to you here.
If you want to buy a cylinder, contact Trevor from cylinders2go and mention my username and the forum for a discount . He can price you for an additional immersion too. Many on here have bought from him ( Telford cylinders ) and the stainless steel ones have a lifetime warranty. Their all I have fitted for over 20 years, with zero issues, ever.
Not quite. What I was saying is that if you have lots of excess one day and not the next, you'll will have stored as much as you possibly can each day and have some 'spare' capacity to see you through. Quite coarse 'maths' here as I'm flying blind . All cylinders will come with an immersion, but you may benefit from adding a second one, by choice, so the PV can be fed in as low down in the cylinder as possible, eg to heat the whole tank with any excess. With a large tank, the PV will be topping you up vs hating you from cold, and heating from cold ( recovery ) is a big ask, whereas topping you up is a doddle.
Could you elaborate? A pv design will work out your net generation vs known self-consumption ( base loads ) from your bills. The excess ( what % is deemed as export ) will go towards hot water via immersion. Most of my clients have completely free hot water for at least 6 months of the year, so the boiler 'hibernates' for summer.
Storing more on a sunny day, where you may not then have such a sunny day the next. These are assumptions, as I don't know how big a PV array you'll adopt, but with the bigger tank, you then have the gs boiler only heating it to 55oC which makes a big difference in the amount of waste / latent heat loss per hour.
