Nickfromwales
    346
  1. Agreed. Please continue in the original thread, as linked by @ProDave folks! Thread now locked to new / further comments here.
  2. Absolutely. Yes, but for safety sake. Indeed, as you wouldn't want to get zapped when working on something that had defective / incorrect cabling downstream of the CU, and you come to then work on it as a 3rd party. Switching 'off' the front of house RCD or main switch should give double-pole isolation of the entire electrical installation from both sides of the incoming supply.
  3. The 'tripping coil' is kept in absolute equilibrium, regardless of direction, as power flows through line and neutral in equal 'quantities' in normal conditions. So in theory it will work with these reversed as there would be no pushing or pulling, just a constant current along both, ergo no potential present in the tripping coil. The RCD / RCBO gets tripped by the difference of potential created when line or neutral becomes partly compromised by being 'shorted' to earth, with there then being an electromagnetic flux thus created from this imbalance and that is collected ( detected ) by the coil ( a-la a CT clamp ), hence the name Residual Current Device. It's why you can get an RCD / RCBO to trip by shorting neutral to earth as well as line to earth. It's the reason birds can land on HV power lines and sit there, not becoming toast, as the left foot is at 132,000v, and the right foot is 132,000v so the difference between 132,000v and 132,000v is absolute zero. Poly happy. But, if they decided to sit in a row, and it was raining and the last one got his wet wing to ( or near to ) the earthed metal structure, then it's "en-flambe" for the lot of them. The 20 live birds who were sitting there energised at the line voltage ( 132,000v to 400,000v but have no current passing though them ) happily minding their birdy-business suddenly just got grounded, and the difference of potential is then 132,000v. Bye bye Polly.
  4. Not necessarily, just where they're running flat out etc / defrosting like crazy etc. Poorly implemented / poorly selected etc vs just crap workmanship
  5. Nope, just drilled the slab when cured, made an oversized hole so we could get hands in and dig down. Your plumber could be right if an ASHP is installed in very adverse conditions, which most, sadly, are.
  6. Not if the ground is permeable. Waste of time/ money. The Stiebel Eltron unit we've just installed has a condensate outlet underneath which is simply dripping down in a 150x150mm cut-out in the concrete plinth to ground. I've dug down about 700mm and back-filled with 10mm gravel as a soakaway. Works perfectly well. @markharro, dig a hole where the condensate will fall, fill it with a hosepipe flowing at 0.2 l/p/m and if it doesn't back up, end of.
  7. Yes, I was referring to a retro-fit, as would injected foam be. Cavity batts always number one choice in a masonry build, with cavities as big as you can facilitate / insulation beefed up to suit. All goes out the window ( literally ) though, as these types of builds are just so inherently, massively dogshit for ventilation heat loss vs fabric heat loss ( with the former an insulation killer ).
  8. Yup. But its all about pushing back and standing your ground for a better "tomorrow". The BCO's I am meeting on my PH ( or thereabouts ) builds have not got the slightest clue of what they are looking at. Most are very curious though, and usually spend most of the visit marvelling at this new 'phenomenon' vs doing any BC content. They do a few laps, smile and nod, and then leave. And then we all look at each other and say, "nice chap, why was he here?".
  9. I wouldn't put it in cavity walls tbh. Blown in, bonded beads for that AFAIC.
  10. Defo. I should have said that. The builders on one of my 2x PH M&E projects in Leicester are absolutely mustard, an absolute breath of fresh air. The other project not so. After seeing F-up after F-up, after F-up, I simply went to the clients and asked them to sack him. Which they did. We managed to stop the poor work, covered up property damages etc left in his wake at circa £35k. If anyone wants to know which builder to actively avoid in the Lutterworth / Leicester area, PM me. Absolutely some of the worst work / work ethics I've seen in a few decades. Of course, his website looks absolutely stunning, shame they don't know which side of the saw has the cutting edge. It's not very often that I am stuck for words, as were the building control officers, drainage & groundworks engineers and others.
  11. almost always POA after a survey. U-value similar to PIR sheet format, but if the spray company try to cut corners and do too much in one go, it ends up like swiss cheese and will have cavernous pockets of air everywhere. Just seen one example of this, what a crock of crap they turned out Took days to rectify.
  12. Yup. I used to look up to these professionals, after 5 years of being a PH M&E, and listening to the majority, I look sideways and down. It would be a breath of fresh air to hear / see these types of prfessions stating what they do / don't do, and what for them to just excel at what they're best at doing, eg designing great houses. And just stop there!!
  13. Posi's and a bit of additional timber to get you up / around 350-400mm depth, and blown-in cellulose wins the day for me. Just one days work for one guy, chilled out, and staggeringly good performance for both insulation AND sound-deadening. For the OP, I'd seriously consider getting spray foam in, but only if there's a robust interstitial condensation mitigation plan in place. Did you cap the open cell layer with a layer of closed cell, or did you go for an internal membrane instead? In talks with one client atm to go down this route ( vs membrane for AT plus obligatory's ) as the roof space is nigh-on impossible to get a man into, let alone cut and fit insulation AND ten cut and tape an AT / vapour membrane. A very bust attic trussed roof indeed, and just looking at the planning for insulating it "manually" was making my brain bleed. Worse than that was the assurance that a builder would just put a 'decent labourer or two' on it, and the results would be dire at best.
  14. That's what I'm doing for 2 current clients ( both having 3ph Zappi's ). Biggest thing in a PH is the induction hob tbh, so what's the point in 3ph'ing the house? If net metering is robust, then balancing the phases becomes far less of a consideration, if any at all. On another project, 3 stories plus swimming pool in basement, I've installed ( in the process of finishing off this month ) 3x heat pumps ( house / swimming pool / A/C ), a whopper of 3ph solar PV + batteries + 3ph EV charging. It also has a self-contained annex into which I've installed a 3ph 27kW Stiebel Eltron instantaneous water heater ( size of a large shoe box, performs like a 30kW gas combi!!!! ) . As the annex gets fed from DB1 it was a no-brainer to go to a 3ph domestic install, but for my other projects there is simply no need to go to a full 3ph configuration for the house, in honesty, ( IMHO ). Maybe time to think of the validity, and consider what @joth says.
  15. My bad, I meant single tails, which are PVC / PVC so wouldn't need containment? Same re number of cores. I need more sleep / fewer kids. Thanks for the observation! I'll get my coat....
  16. The house may well have had timber windows there before the PVC was installed, and then the "cracks appeared". A lot of shit window companies mistakenly removed timber windows with central mullions which were load-bearing and incorporated into the load for the spans. Yes, a cause for concern and may be tricky to fix retrospectively. Try and negotiate a discount for this work, at least £5k, and also ask for the building regs paperwork for the room in roof, or the house needs to be valued minus that room ( so it would then only be classed as a ( valueless ) attic / storage space and not habitable space ).
  17. Spoke to them ages ago about thermal stores for a log gasification boiler job I had on at the time. Seemed knowledgeable and helpful, from what I recollect, but I had to go with a turnkey supplier eventually as the RHI small-print meant the commissioning agent had to be direct to the client. Get a quote, no harm, no foul?
  18. Assuming tails kept at 50mm depth, or more, of course.
  19. Singles OK with PME, vs SWA? 25mm2 4C SWA is a whopper. Would 3C SWA suffice ( if singles not allowed ) with a separate 16mm PVC earth? EDIT: This was supposed to read 5C is a whopper. Would 4C SWA suffice. Already getting my coat, you'll see.
  20. If the're letting drafts in, then defo upgrade.
  21. Not suffering from that particular ailment....yet.....
  22. CVC Systems for me, every time. Brink Flair units plus the 'new' Air Comfort ( AHU for tempering ) work brilliantly and extremely quietly for my clients. I'm not a fan of large bore series run ( branched ) systems, due to cross-talk and the sheer size of the ducting. VERY unaccommodating to get the rough the fabric of a build. The radial 92mm ductwork is a doddle by comparison, eg to get through joist voids / confined spaces etc.
  23. Just because @SteamyTea is only virtual here, does not stop him from being an eyesore.
