Where is the PRV ( pressure relief valve ) located? And where does it discharge? It may be part of the group where the topping up aka filling loop is mounted ( as these usually are made up of a filling loop / pressure gauge / PRV / EV as a "pressurisation" kit. Topping up daily shows a huge problem / leak. I'd say one loop is leaking ( without first knowing if the PRV is passing ( allowing water to escape )).
Ok. I assume you mean the system pressure, indicated on the gauge at the filling loop ( the bit you use to top it up ) keeps returning to zero and not the pre-charge in the gas side of the expansion vessel? This is probably not how things are. Does the water enter into the bottom of the expansion vessel ( EV )? Is it mounted vertically?
Internal walls aren't "structural" per-se, so you wouldn't be factoring in deflection etc. Are you referring to all internal work here?
Insulhub Isotex Voluntary Liquidation
Nickfromwales replied to Surfiejim's topic in Insulated Concrete Formwork (ICF)
It's not sounding very positive atm, is it? Especially after reading the previous post. There's holding out hope, and then there's; -
Engorged dividends, or directors loans, big expensive house and big expensive car are usually the tell-tale signs of syphoning funds off for personal gain. Quite easy to see lifestyle before / after, and that's what HMRC would focus on....but not sure about what diligence the receivers exercise. A winding up order can be blocked by other creditors. -
Probably a good idea to quash the digressive joviality here, as it's a bit like laughing at a funeral -
Do you think he / they will show up there for a public flogging? One would assume he will go to ground?, for the foreseeable future at least. -
How will that help? This isn't breach of contract, this is a hit and run! -
https://en.blocchiisotex.com/contact-us/ ? Give that a try. -
Block and Block with 180mm cavity instead of Isotex ICF
Nickfromwales replied to Chanmenie's topic in Brick & Block
The longevity of wet layers ( plaster / render ) over aerated blocks is dire, as they are dry as a biscuit and crack a lot through settlement etc. Get the structure as your #1 focus, and don’t lose track of what can and can’t be retrospectively addressed / upgraded / altered. The structure is one such thing. Have a look at this again, and defo stay focussed. Nudura offer a thinner system also, 67 - 150 - 67 iirc. The XR35 is their beefed up block. Isn’t your cavity superfluous? -
PIV vs sound insulation within the apartment: can't have both?
Nickfromwales replied to Garald's topic in Ventilation
You'll have a gap anyways, having one slightly bigger is neither here nor there, totally negligible. Never been an issue for any of my clients ( all MVHR adopters ). -
Ok. Probably best to just stick to the facts here, as a lot of people are affected and they don't really need conjecture atm. -
That would be public information? Does it say that? -
I think @PeterW has put this to bed. Read his posts a few back -
It sounds as if they have made this offer very soon after 'the event'? They mention folk affected specifically, so have they not just done what you say, prioritising those affected. Has anyone asked if they have offered speedy dispatch for those affected? If they have, then great. These big companies should have to offer a parachute to the end consumer, of course, if they allow someone to set up a money-making franchise. But if a client signs an agreement, with the understanding that there is no such mechanism, then you can't go at the supplier for any ( retrospectively deemed ) short-fall in their business practice. You can, however, ask. If you don't ask, you don't get. Dovista, the window / door group, however, did get involved when a window company went bust. And they sunk their teeth into the supplier, got the clients money out of him, and then worked tirelessly with me to get the matter concluded on the clients behalf. Big thanks to Ryan. -
Yup. I wonder how much stock is in the UK at Insulhub's premises? Assuming not much or any, but worth asking the receivers what is available, especially for anyone is mid-build and short of materials and is now on stop because of this? Isotex will not want to lose face, so hopefully they'll facilitate speedy delivery to site for anyone who takes them up on the discounted offer. -
Mad idea for DHW retrofit based on Mixergy?
Nickfromwales replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
Agreed. But long-term benefits will be notable afaic. My comments about latent loss extend beyond your PHE etc, and outward to the rising pipework and CWS tank etc. Plus, I just wouldn't ever want to be bathing / washing dishes in the water which has come from the CWS. Open-pipe systems have a lot of 'negatives' but are kept "because it's worked fine for us, up until now". The MCS markup will likely pay for the UVC change. -
And god help you ( your wallet ) if the copper cylinder is already on borrowed time. You can very rarely tell from the outside! Ask me how I know. -
I disagree about the upheaval. Have you asked a plumber to quote for the swap, or are you looking at this from a novice / DIY PoV? The second you bolt that PHE to the cylinder you have just added a constant miniature radiator to it, massively increasing the latent / standing losses. The second the ASHP stop giving heat, the process will reverse and all of the bolted-on retro fit stuff will leak heat like a pig vs a new, much better insulated and encapsulated UVC. -
Yup. They can write anything down in their claim and it's almost impossible to defend yourself if you hadn't stopped to get quotes out, get them signed, and then did the work. -
I think you'll spend all of that money, and get a poor result. Looks horribly over-complicated to me, hugely inefficient, maintenance hungry and I would still recommend that you reconsider the UVC option. Just my 2 cents of course, and I will offer any help / advice I can if you decide to go to the wonkey-wheel option -
My moral compass told me not to go under when folk were invested in my company ( life savings / earnings etc ), so I just bit down even harder and weathered the storm(s), and some utterly disingenuous scrotes of clients to boot. I'm still owed north of £40k, but ain't going to see that ever again. All of that went out of my account and into these snakes new builds. I can only thank them for me now having a proper and robust billing system, where things get signed for, agreed, and then done. Never go on faith and smiles, is what this had taught me. I was quite a happy-go-lucky guy, but nowadays I'm far more weary of leaping before looking. There are defo two sides to these stories, but this one stinks. -
Thank you for posting this, and it may be of huge interest to anyone mid-build!!! -
Indeed. Just odd how money has been requested, more than once, so close to pulling the doors shut? For £100k, that steel building would have been chopped down on a bank holiday Monday. -
Amen. This is not a thread for giving false hope to people who are already emotionally compromised. If anyone would like to offer advice or support here, please only do so with the accompanying, current, facts that their statement is based upon. A-la, the above Thanks. Mods.
