Nickfromwales
    346
  1. What was the cost of a cube from the dry wagon, if you can recall? Saw one in action in Ilford, was quite impressed by the concept.
  2. If you've 2 mixers on site and 3 bodies you can mix and pour for a small DIY job like this. Don't choose librarians, get some guys with thick arms and strong backs, as the pace will be relentless for an hour or two. I guy feeding the next mix into the empty mixer, 2 guys supporting/hand-balling the mix into flexi-tubs and into the ICF. If you're on site to help out even better. Don't attempt this on your own btw.....
  3. He's not doing a build, this addition IS "the build"
  4. Get them listed on BH marketplace?
  5. Don't put in fan coils, or don't.....put in fan coils instead? Reads both ways, so just for clarity plz
  6. Any gaps would have to be filled as even with the underlay the lino will show everything under it, as would LVT.
  7. DIY it in EPS ICF blocks? You'll have issues with rain penetrating if you just use aerated block, unless you can render externally?
  8. You mean you'll ask them to do it as 'makeup' ? They should finish this so your external finishes go up to their makeup, if being left exposed for any length of time.
  9. 1) In practice, these people would be bound by a jacket that ties up at the rear.... 2) If I hadn't already had 3 beers, I'd drive there right now and apply the back of my hand to you, sir. Absolutely NOT on your NELLY! All of our work has clearly been in vain.....close BH, turn off the lights....the message just isn't hitting home. It's your AVCL!! 3) Why? And be honest. Lack of confidence, or other?
  10. This is Buildhub mate, you'll need to specify length, width, type of stitch used in manufacture (with a link to the manufacturers specs for the needle), the ambient temp and humidity of the factory, and what day it was made. I just hate it when people post without sufficient information 🙄
  11. "Ladies and gentlemen....please place your bets for the 53rd national Kentucky washing machine derby"...
  12. I almost got sucked into the vortex of looking at the many different screws I could buy and put into organisers, that may possibly get used, maybe,.......but I'd have them, lol.
  13. .....evening boss, sorry I'm late! Ok, so the real elephant in the room is the AVCL. If they miss, then they'll withdraw the fixing, and go again, making lovely holes in your airtightness layer; a crime punishable only by a slow and painful death afaic. This is the real crux here imo.
  14. If it's in the hole, put a load in and rinse then spin. Proof/pudding
  15. You could fit 4x 1000L cold mains accumulators in an outbuilding, and keep a reserve of 2000-2500L on site; these don't fill completely, so you won't get 1000L of water in each vessel. You can have an alarm that notifies you when the incoming pressure drops or disappears, so you know you're on 'rations'. You can gauge consumption and then maybe increase the number of accumulators, if needed. These take pressure from the static cold mains and recharge with pressure 'borrowed' from the network water. I'd try with no pump at first, and then see how you go, and add a suction pump if so necessary. You could also do 1 or 2 of these for potable, and then one more fed from 3-4000L of water held in some IBC's, pumped out to do everything non potable.
  16. If you're going floor to ceiling glass, I'd want the extract in the shower area, at the end opposite to the shower head. Others will say it's not supposed to be in the shower area, I say it makes zero difference. I'd want the shower area to have the most amount of cross-flow as possible.
  17. You'd push EPS down into the cavity, then you'd create an insulated upstand against the outer skin of masonry, with the XPS board, and then you'd fill the cavity with cement, level with the reduced celcon. Then you would use the XPS backer board to stop the cold rising connection, and then SLC.
  18. The XPS backer board would be the closer then.
  19. If it's going to take foot traffic, and then LVT, you ideally need to multi-tool the celcon blocks down by -22mm, install a 12mm XPS backer board (defo do not use cement board as it'll cold bridge like crazy), and then pour 10mm (min) of SLC to the required height to take the LVT over ply. Multi-tooling the blocks will take an hour or so so that's easy enough to do.
  20. So, in summary, it's too late to add a basement is what you're saying yes? lol.
  21. Where are they installed?
  22. Self level the slab before you start to get it nice and flat/level, and have zero screed? Check how out of level it is and fill to get it dead flat. Lets assume 10mm of SLC goes down. Just put down PIR and then top it with 2 layers of 18mm P5 deck boards, staggered joints and glued and screwed, and then put your finished floor over that. You'll be surprised at just how solid a floor this gives. The SLC prep makes the sub-floor flat and level, so don't skip that bit! Levels are achieved by mixing 2 layers of insulation at different thicknesses to get the height you need; 170-10mm = 160mm to fill, so allow for 1x18 +1x22mm=40mm deck, then 2x layers of 60mm sheets of PIR. That's 170mm total build up. 1x 120mm PIR sheets sounds faster and simpler, but won't conform and settle down as well as 2 layers. DPM/DPC's as required.
  23. If you want problems, then go for the gaps. If, however, you'd like a solid slab with no cracks or breaks, do NOT do as you state. On a 140m2 L-shaped MBC raft, with only 100mm concrete depth between intermediate beams, we tiled that with 1200x250mm porcelain and not a single issue for the 12 months it was down for whilst we completed the rest of the job. No decoupling membrane etc, just flexible tile adhesive straight down. Just "NO"
  24. The cross battens will be visible, and after placing the 100mm PIR you'd just run a marker to show where to put each fixing. I think this is an overcomplicated question for a simple install, and will become apparent how simple this is once these start going on. Basically, AFAIC, they can't miss? If the chippys are installing this then I'd suspect a bit of micro-managing is creeping in lol.
