Temp
    43
Everything posted by Temp
  1. Never done tarmac but as usual the prep is probably the most important part. So what do you currently have and why does it need replacing? Try the index/tarmac pages.. https://www.pavingexpert.com
  2. For some reason I can't copy and paste a link on this phone but search for the thread.. CIL exemption revoked due to lodgers
  3. I'm not very familiar with AirBnB but aren't there two types of letting on most platforms... One where you have the whole place to yourself and one with a live in landlord? It might be important which you advertise is as. Personally I wouldn't risk it unless you can get a definitive answer.
  4. Many just come out horizontally.
  5. I wired mine to the ceiling light which uses a switch outside. But mine is just a light not a shaver socket or USB phone charger etc.
  6. If you really must tell your lender I would tell them that... Your survey showed Guard Rails on windows have been removed since it was originally certified by Building Control but you intend to replace them.
  7. We accidentally built our house with two windows with low sills. The BCO picked it up but said he would pass it if we fitted window restrictors. The Approved Documents are only "one way" to comply with the Act which gives BCO some discretion. The seller doesn't have to do anything. You buy houses "as is" or at best "as represented". However you are free to use this to try to negotiate a better price. Just as they are free to say they already factored this into their asking price.
  8. There is this for houses but I don't think it covers outbuildings.. A "similar appearance" rule is part of the General Permitted Development Order (GPDO) in England, specifically regarding roof alterations. Under The Town and Country Planning (General Permitted Development) (England) Order 2015, Schedule 2, Part 1, Class C covers: "Any other alteration to the roof of a dwellinghouse." "The materials used in any exterior work shall be of a similar appearance to those used in the construction of the exterior of the existing dwelling house."
  9. Can't you just sign and witness a copy of the S106? I thought they were legal documents.
  10. Advises against using asphalt products on EPDM.. https://www.elliottroofs.com/article/steps-to-repairing-a-patch-of-damaged-epdm-roofing-membrane
  11. If you want led strips on all shelves I would put a strip of matching timber on the underside of each shelf and hide them behind that. Something just thick enough to hide the LED light strip/fitting and stop it shining in your eyes. It also gives the shelves a more solid look. You can also get recessed extrusions to put led strips in.. https://www.downlightsdirect.co.uk/advice/led-strip-lights/illuminate-your-shelves-with-led-shelving-lights/
  12. If you really get stuck perhaps you can cut down large brass Parliament hinges and drill new screw holes in them
  13. +1 just check you can get a branch for the WC above it without it being too high.
  14. It's always been the case that the self build reclaim is only for people building a house to live in themselves or for a relative. The bit about letting is not widely known but there are websites that mention it. It's down to a difference between Exempt and zero rated. One can reclaim input vat and the can't. The bit about need to live near your work is new to me and seems crazy.
  15. Lot of solutions.. Fix something like a 2"x2" batten to the wall then clad upto it. The soffit fits to the underside of the batten. If the cladding is already done then fit a strip of cladding upside down and that will give a vertical face to fix the square 2x2 batten onto. Either that or run 2x2 through a table saw to put the correct angle on it. If you need a ventilation slot where soffit meets cladding... Ive seen someone fix "triangles" to the bottom of the rafters to give a horizontal edge to fix to. You might already have enough bits of scrap rafter left over from cutting them to the angle at the ridge.
  16. To spec the cable you need the total power or current draw and the length of the cable not just the trench. I would put SWA cable and a draw rope in a duct. Put the rope and cable in the duct before burying it.
  17. I was told our electric co was fussy about ducts and it had to be a smooth bore solid wall pipe printed with some standard on the outside (at least for the bit from road to house).
  18. If they send someone to measure you can always offer to hold one end of the tape.
  19. You can hire conveyor belts for this sort of thing. Not used one myself. Perhaps they drop some?
  20. Some sort of foam to raise the mesh onto the slab.
  21. Perhaps a self tapping screw through the joint on the top would be enough to stop it coming apart? Or a bit of PU adhesive like Tigerseal.
  22. Can't two 45 bends be joined and rotated to give the required angle with a slight side step.
  23. Can't tell much from the photo but it looks like they just put a layer on top of the existing?
  24. I think it will be fine. Similar to what we have.
  25. Google tells me they operate on 868MHz which is also used by some burglar alarms. I don't think having a burglar alarm on the same frequency should cause a problem but I suppose it might be something to check.
