Temp
Everything posted by Temp
The usual recommendation for insulation is as much as you can fit in or afford. Perhaps 250-300mm in this case I think I would fit a vapour barrier (plastic sheet) below the insulation and then plasterboard.
Door linings: narrower than the opening
Temp replied to Post and beam's topic in Doors & Door Frames
This. I would hold the lining in place flush one side then run a pencil using the wall itself on the protruding side to mark the lining for cutting. That way if you have walls that aren't uniform thickness it's taken care of. -
Stamp duty and Council Tax
Temp replied to IanB's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
You might be able to find a rental that includes Council Tax but they are rare. My son is currently in a shared house that includes Council tax in the rent and the landlord is listed as responsible for paying it. -
Can we ask what your total budget is for the bungalow, both what you would like to pay in an ideal world and the absolute maximum? Also how many square feet/meters the approved bungalow has? If possible post your approved plans/elevations. Is the roof "complicated" with lots dormers or just a simple pitched roof? Have you considered selling some of the garden to a developer or is it totally impossible to get planning for a other house to finance yours?
Washing Machine waste - options for a pipe at height?
Temp replied to low_and_there's topic in Waste & Sewerage
Could you fit a trap to the right of the "fixed" section? I'm not sure of the rules on tun dishes but ask your plumber if it can be to the right of the tun dish for the heating. If so that would stop smells getting in via the tun dish as well. -
What's the existing house like? Would it make more sense to renovate and/or add an extension? Move house to a bungalow?
Perhaps you've seen it but there is quite an extensive guide here on what you can/can't do without planning permission.. https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance See page 41 onwards.
Paving slabs... cleaning and filling gaps
Temp replied to Kells's topic in Landscaping, Decking & Patios
Until yesterday my India Stone patio hadnt been cleaned for 15 years and was worse than the pictures in the OP. Some were completely black. My small pressure washer would hardly touch it so I looked at renting a big one that would do 3000psi. Ended up buying a Pollor brand 7HP petrol model for not much more than they wanted to charge to hire one. After washing of the dirt with the pressure washer there was still loads of black, white and even some green patches Then hit it with 15% Sodium Hypochlorite diluted 50:50 with water. Instructions said to apply it to dry stone so I waited overnight for it to dry after pressure washing. That made an amazing difference. There are still a few black spots but it's come up great overall. Following day after the Sodium Hypochlorite had dried I hit it with Wet and Forget (Ammonium Chloride based) diluted 5:1 with water. Apparently that stuff helps stop it come back. Time will tell. -
The gaps are wider at the top than the bottom. So either... a) The area where the cracks are has risen or b) One side of the crack or both has sunk. Where are the trees in relation to the wall? Removing trees can sometimes be as bad as leaving them. Its not unusual for builders to skimp a bit on the foundations for garden wall, although the existence of a expansion gap suggests the builder has some knowledge or can follow plans. After 10 years I doubt you have any call on the builder or NHBC. I'd take @George's advice.
How to restore 12 year old laminate floor tiles?
Temp replied to David001's topic in Wood & Laminate Flooring
You might be able to sand or scrape the paint out of the grooves but go carefully. That might well leave the fibre board exposed which will need some form of sealing. This American video mentions a sealer for laminate floors but that will seal in anything you leave on the floor. I've not tried it. There might be a similar product in the UK. -
Even "without" sleeping accommodation things like the electrics and possibly the plumbing (?) are notifiable. Typically your electrician will notify LABC about the work he does on it. When the BCO visits to check on your house best tell him the pod just being used as a site office and hide the airbeds 🙂
I'm not @Nickfromwales but.. Typically you set the top of the dishwasher stand pipe as high as you can under a worktop allowing room between the under side of the worktop and downpipe to hook the washer hose in the top. Then run a horizontal pipe from the bottom of the stand pipe along the wall to the outside with the appropriate fall. Somewhere along that pipe you insert an upside down T and vertical pipe for the sink. Normally the trap for the sink is close up under the sink.
If its got a bedroom I believe Building Control Approval is required. https://www.labc.co.uk/news/does-my-new-outbuilding-need-building-regulations-approval Note Mobile homes and caravans don't need Building Control Approval but this doesn't sound like it will meet the rules for mobile homes?
I believe the water co is now responsible for "shared drains". In this case the bit from the inspection chamber to the main sewer and from the Inspection chamber to your neighbours fence. However some sites like this one in Wales says this only applies to sewers connected before 1st July 2011.. https://www.ccw.org.uk/faq/who-is-responsible-for-my-drains-or-sewers/
If the walls are already up to height I'd put the rafters on top. You can fit joist hangers to a wall but they normally require a minimum number of brick courses on top of the hanger (to prevent the forces prying the hanger out) so this is normally only done for the first floor in a two storey house or two storey extension. Alternatively you can bolt a wall plate to the side of a wall and put rafters either on top or flush using hangers. Again I'm not sure it's wise to bolt so close to the top of a wall? Another option would be to notch the top of the wall with an angle grinder to allow rafters to be inserted at the right height. I mentioned headroom issue because Permitted Development rules limit the eaves height of an extension or outbuilding near the boundary. Think its limited to 2.4m?
Yes sure you can put the rafters on top of the beams if the headroom isnt an issue.
We're also on a single track road in a quiet village. Our builder did the base right to the edge of the road and got a contractor to do the tarmac. Don't think he bothered with a road closure. As our drive sloped down to the road he decided to put a metal linear drain along the edge of the road running into a piped ditch. That would have involved cutting the very edge of the road.
For the mid span ChatGPT suggests a UB 203 x 102 x 23 with 3m C24-grade timber joists 47 x 170 mm at 400 mm centres. I would shot nail or bolt a timber infill either side of the shear web and use joist hangers. Probably long tail joist hangers wrapping the tail up over the top of the UB and down the other side. Nail both sides. I'm not a structural engineer though!
We used the Eclipse on a bathroom ensuite door, although ours has timber architrave around it. The Eclipse works well for us but I would avoid sliding doors anywhere subject to frequent use. They are just so much harder and slower to open and close. Beware sliding doors also reduce the opening width by quite a bit. For example the whole door can't go into the pocket. Nor can handles on the door. There are also stops to prevent your hand/fingers being trapped between the handle and the frame when you open the door. So you need to start with a bigger opening especially anywhere Part M applies.
There are different ones for joining sleepers end to end in the middle of a wall.. https://www.aafencing.co.uk/products/rsj-railway-sleeper-post-raw-steel-intermediate?gad_source=1&gad_campaignid=21969916683&gbraid=0AAAAAprPxhDFXMV1bmBp3GKe2A1QdfyEr&gclid=CjwKCAjwl_XBBhAUEiwAWK2hzhe1gySsQvH_494A0E-RH3DyJF19IegcNOGjkPMJk5YEj36gQ4DwOxoCdg8QAvD_BwE I can't immediately see what you use for a T joint. Perhaps you have to bolt two of the above together?
VAT 'edge cases'
Temp replied to Alan Ambrose's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
There is a list somewhere of things that you can/can't claim the VAT on. Its on the government Web site. If you are in Tesco buying Paint and Lunch you can't reclaim the VAT on your lunch so you cross it off and put the revised figure on your spreadsheet. Ditto consumables like sandpaper and tools. I believe a cabinet to house a temporary electricity supply is not zero rated. However I've not heard of anyone being asked to prove that all the wire they purchased was actually used inside the house. There is a section in 708 which exempts things necessary to allow the construction of the house. That's intended to cover things like water main diversions or demolition.
